Old 06-04-2011, 06:44 AM   #1696
McBoab
Fast side of farty
McBoab's Avatar
Oddometer: 277
Originally Posted by cul8rr View Post
Anybody have difficulty starting the S10 in cold weather ?
Not had a problem starting over the winter (when it was below zero deg C) but it is stored in a dry spot, however it runs a lot better in the warmer weather than it did over the winter, wondered if condensation was getting to the coils causing the odd misfire (seems difficult to spot if its intermittent on a twin plug cylinder) as it just felt rougher than it does now.
PS I also leave mine mine on a CTEK battery tender when not in use to keep the battery fresh, big Jugs do like a good battery from my experience.
McBoab is offline   Reply With Quote
Old 06-04-2011, 08:28 AM   #1697
cul8rr
busa no more
cul8rr's Avatar
Oddometer: 97
Originally Posted by dl20man View Post
How cold is cold and what time of day?
Left it for a week in a shed in Perth WA. Probably single digit cold.
Got it out of the shed cranked over fine, battery was fine, just didnt want to fire up. After cranking for a while leaving it, cranking with full throttle to bypass choke and clear out any fuel and leaving it, cranking again no throttle, 1/4 throttle , 1/2 throttle. Left it to get the tools to find out WTF..... Gave it another go with 1/2 throttle and it fired eventually... Hasn't missed a beat since..... GMF
It's better to burn out than fade awaaaaaaaayyyy....
http://www.advrider.com/forums/showthread.php?t=712478
cul8rr is offline   Reply With Quote
Old 06-04-2011, 01:47 PM   #1698
RogerJ
Waypoint Wanderer
RogerJ's Avatar
Oddometer: 222
Fork Seal Leaking?
Originally Posted by Bundu View Post
Below is a quote from the SA WildDog forum:
"After 16 000 km's of trouble free off roading a burst front fork seal and diff spilt all its oil on the way to the EC Bash, anyone had any of these problems ? Yamaha says they will fix the diff under warranty but not the fork seal and I have to take it to them.
The front fork seal I had to pay for, they said its not covered by the warranty which cost me R 530-00."
I had a front fork seal weep very slightly at 1500 kms and Yamaha got replacement seals "overnight" and installed two new seals the next day. Guess it depends on how long the seals have been in service and what kind of use the bike has had?
BTW, in a pinch I believe the R1's fork seals fit but check for matching part numbers.
Also, if some day there is a fuel pump failure the FJR 1300 fuel pump serves but, again, check for matching part numbers.
Thanks for the heads up about the preventative cleaning at the rear hub. Much appreciated.
XT1200Z; F700GS; F650
RogerJ is offline   Reply With Quote
Old 06-04-2011, 09:22 PM   #1699
dl20man
Oddometer: 19
I asked how cold because I don't the weather where you are. Our temps here are on average a couple of degrees warmer than Canberra. Mine is also in a shed. I usually start it outside the shed. Has started no trouble on mornings close to zero. Sometimes left for a week without starting but starts after a couple of turns of the starter. Hope it was just a one off for you. I have 19 000 kms on the clock.
dl20man is offline   Reply With Quote
Old 06-04-2011, 11:57 PM   #1700
cul8rr
busa no more
cul8rr's Avatar
Oddometer: 97
Got up this morning showing 8 deg. on dash and fired up no worries....
Probably a one off. Getting it checked out this week in town. Dealers keen to find out why as well. 19000k's also.....
Old 06-05-2011, 01:36 AM   #1701
thebrown
likes beer
thebrown's Avatar
Oddometer: 73
hi there
has anyone tried a Bags Connection Daypack II Quick-Lock Tankbag on their super ten
i thought wasp may have had a pic in this thread... but after going thru the thread a couple of times and getting distracted by pipes, lights and other things i think i must get for my impending s10... i must have missed it
thebrown is offline   Reply With Quote
Old 06-05-2011, 11:41 AM   #1702
Thagua
Let's go adventuring...
Thagua's Avatar
Oddometer: 354
My cockpit
View of my cockpit with latest mods ... missing is installing the GIPro shift indicator which I bought but don't know how to plug it ... lol
[IMG][/IMG]
Thagua is offline   Reply With Quote
Old 06-05-2011, 12:40 PM   #1703
dcstrom
Oddometer: 1,551
[IMG][/IMG]
Thaqua,
been looking at the HDB handguards - any fitment issues on the S10? Which model did you get?
Trevor
Super Tenere news and reviews
http://supertenere1200.com
dcstrom is offline   Reply With Quote
Old 06-05-2011, 06:14 PM   #1704
Thagua
Thagua's Avatar
Oddometer: 354
HDB handguards for S10
Originally Posted by dcstrom View Post
Thaqua,
Trevor
Hi Trevor ... the HDB handguards are the strongest in the market ... better and sturdier to the other known brands (Acerbis . Barkbusters) but they are meant to be used in Enduro bikes so fitting them to our S10 required buying a fitting from Acerbis to grab the end of the handguard to the handlebar plus a piece of aluminum bar as extension on the left handguard. These handguards came with the wind deflectors in white and black. They are supposed to be attached to the center handlebar fitting also sold by HDB but are 4 inches short.
Cheers,
Roberto
Old 06-05-2011, 08:18 PM   #1705
Wasp OP
Supa10 pilot
Oddometer: 1,062
[IMG][/IMG]
Good to see that you finally received it all Rob.
I have been thinking about the doubletake mirrors,, what are your thoughts compared to standard?
Do they vibrate?
Will they fold right inboard when offroad?
Offer good vision when lower to your fists?
Are they the low mounts or high mounts?
Greg.
The original WaspWorks S10 detail & evolution thread:
http://www.advrider.com/forums/showthread.php?t=595933
The NEW "Long Term" WaspWorks S10 detail & evolution thread:
http://www.advrider.com/forums/showthread.php?t=778809
Wasp is offline   Reply With Quote
Old 06-05-2011, 08:30 PM   #1706
combo
D S N
combo's Avatar
Oddometer: 301
Greg, High fender mod progress?
I don't know where I'm going but I won't be late!
combo is offline   Reply With Quote
Old 06-06-2011, 01:00 AM   #1707
Wasp OP
Supa10 pilot
Oddometer: 1,062
Working on a few things at once Combo.
I will be getting the Isoboard for pattern making in the next week or so, but have been waiting until I next striped the bike for a clean.
We were out on Saturday for a great ride through the forest and got nice and dirty, so I thought now is as go a time as any...
The professional side of life has put the brakes on the fun factor a bit as I have been on some fairly tight deadlines lately (hence the limited posts), but I have just completed one lengthy design job and am about two weeks from the end of design faze and start of proto faze with another. This normally allows a goodly bit of spare time as it's really only supervisory and consulting after design.
This is the area of the bike I am working on at the moment and will end up doing patterns for both ends at the same time... Not setting myself any time frame at the moment but it is happening.
Do it once and do it properly I recon.
You wont have seen this view of an S10 very often because it's actually a bit of messing around to strip to this point
Greg.
P.S - All cleaned up like a brand new bike again..
God I love this machine.
Old 06-06-2011, 04:00 AM   #1708
Shaggie
Unseen University
Shaggie's Avatar
Oddometer: 2,641
third LED light?>
hey Wasp -
firstly love YOUR thread and work!
can you point me to the update when you fitted the 3rd led light - i musta missed it....
cheers all
Shane
Shane
"We are not at home to Mr Reasonable" - Sam Vimes
NZ Touring pics:Brass Monkey 2009:Kiwi Sun:Tiki-touring: Daytrips in NZ
Shaggie is offline   Reply With Quote
Old 06-06-2011, 05:02 AM   #1709
Wasp OP
Supa10 pilot
Oddometer: 1,062
Originally Posted by Shaggie View Post
hey Wasp -
cheers all
Shane
Not sure that I posted it here Shaggie, but I may be wrong..
I did manage to find it over at yamahasupertenere.com and you will find it on this page: http://www.yamahasupertenere.com/ind...15867#msg15867
I didnt go into much detail about the install, but I simply designed the bracket and got it laser cut with a batch of screen adjusters then wired all the lights through a relay (high beam signal triggering the relay) with no switch rather immediately on with high beam.
Bloody great set of lights..! 2 x road width pattern and super white and bright for about 100/150 meters.
Greg.
Old 06-06-2011, 07:53 AM   #1710
Shaggie
Unseen University
Shaggie's Avatar
Oddometer: 2,641
cheers fella!
Shane
Times are GMT -7.   It's 11:39 AM.
