07-06-2010, 11:28 AM
#1 |
Pro Turd Polisher
Oddometer: 523
Removing Two stroke piston ring index pins?
On our Aermacchi SS250, we have run into the dilimma with having to machine down the top groove of the piston about .020 to accomodate the OEM rings (we have a aftermarket or later piston).
If it was a normal 4 stroke piston, you would think, " just throw it on a lathe and machine it down, simple as that!" Problem being, this two stroke has indexing pins (one in each groove) to keep the rings in a certain position. The pins appear to be pressed in the groove, and they would have to be removed so then one could machine the groove down. Any help would be appreciated
Jerry ____________________________ Great forum and Resource for 1st and 2nd gen Honda V4s SabMagIntercept www.v4hondabbs.com |
07-06-2010, 11:40 AM
#2 |
Vesperado !
Oddometer: 1,255
Is the groove wide enough to get some needle nose vise grips on the pins?
If not you might want to grind them off with a dremel cut off wheel. But then the remains might fall out later.... Try yanking them first
Laromo '91 Vespa PX 200E "Lusso" '05 KTM 640 ADV "Fatman" '99 HD FLHRCI "Leviathan" |
07-06-2010, 11:42 AM
#3 |
Pro Turd Polisher
Oddometer: 523
That is an option, just filing them out, but then what one replace them with
07-06-2010, 02:02 PM
#4 |
whats a cagiva
Oddometer: 2,454
I would not touch the pins , they are criticle to the life of the engine . I have seen the totaled engine that is a result of the pins coming out . I had a rash of pins come out on some small engines I deal with several years ago , the rings rotate till the ends break off in the ports then destroy the bore and the piston . Make every attempt to replace the pistons with new or good used . SEYA
David H 00 Cagiva GC 04 9 fiddy 05 ST3 duck 07 KTM 450 EXC 86 Goldwing my geezer ride |
07-06-2010, 03:17 PM
#5 |
Oddometer: 153
I don't think the OP was going to eliminate the pins. He just needs to remove them to machine the ring groove.
They are pressed in. The best way to remove them with minimal damage is to heat the piston (alum expands more/faster than the steel pin) to about 350 degrees F and tap sharply on a wood block with a cut-out in it. The pin might fall out. If not, gently use some needle nose pliers.
2001 KX 500 2001 KDX 220 - Both CA plated |
07-06-2010, 03:42 PM
#6 |
Pro Turd Polisher
Oddometer: 523
Thanks Barry, I think the above poster misunderstood me.
I was almost guessing it would be a "heat and pull" kind of thing. I just didnt want to alter the alloy or heat treatment of the AL alloy, in case there was some other super uber-duber trick to getting it out. I do have a junk piston I will try it on before I attempt it using the lone remaining good one. I also have an Infared heat gun, which should make it easier
07-06-2010, 06:19 PM
#7 |
Oddometer: 1,583
One other problem or concern pistons are not "round" most are cam ground egg shaped longer in the thrust direction shorter across the piston pin
this is more pronounced at the skirt and can vary...........
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X 1971 CT90,1981 C70, 1986 TRX 250, 1993 TRX300 4X4, 1987 XR250L |
07-06-2010, 07:03 PM
#8 |
Pro Turd Polisher
Oddometer: 523
I do realize this, but I have a very hard time believeing they used a weird ellipse-turning lathe to make the ring grooves.
07-06-2010, 08:07 PM
#9 |
Oddometer: 1,599
if you have to, set them up in the vertical mill and drill them out,if you end up with a larger pin-hole then machine a stepped pin for a press fit
07-06-2010, 09:40 PM
#10 |
new orange flavor
Oddometer: 1,068
Another option is to get a hold of a ring manufacturer. I have had total seal make some rings for my ducati. They might have a ring that will fit that piston without having to machine anything.
-John
An Elefant never forgets. 2012 Baja 1000 www.Raceforthewounded.com Help us race the 1000, and double the value of your KLR by buying a t- shirt |
07-07-2010, 01:32 AM
#11 |
Oddometer: 43
In some cases (though all the cases I know of are old Briddish stuff), the holes for the pins go right through the piston. So you can poke them out from the inside. can't usually get a drift in, but you can lever with a bent punch.
Troubled by squids polluting the gene pool ? Use Gene-0-Kleen®. In the large economy size bottle. "Evolution you can see". |
07-07-2010, 10:58 AM
#12 | |
Oddometer: 1,583
He stated a bigger concern is the ring grooves on most pistons are not straight but cut on a angle of any where from one to three degrees. The grooves are cut in a single pass with a perfectly ground tool to the exact width. The pistons are chucked on the inside on machined bosses and there is a lathe point on the top of the piston during the process and that point is cut off later. That ring groove angle is not easy to measure or check, and if not correct ring sealing, wear, friction and breakage can be the result. Also rings and grooves can be "keystone" on some engines but more easy to ID. His comment was find rings that fit the groove and grind the ends to fit the diameter. Good luck
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X 1971 CT90,1981 C70, 1986 TRX 250, 1993 TRX300 4X4, 1987 XR250L showkey screwed with this post 07-07-2010 at 02:59 PM |
07-07-2010, 11:28 AM
#13 |
Now with TURBO!
Oddometer: 5,534
Just FYI
A buddy machined some ring grooves for a Toyota mini truck to do what you are (mostly) This was over ten years ago and the truck is still going strong. However, not a daily. And not a 2T I'd just buy a piston/Cyl. combo and install it. There are a lot of NOS things available for this engine.
A fight to the death between zombies has a few inherent problems. |
07-07-2010, 01:43 PM
#14 |
Pro Turd Polisher
Oddometer: 523
Hey Cory
I checked with both Moto Italia and Charleston Cycle, both of them do not have the standard bore anymore ( the factory had a color-code system, going from blue-pink-green-brown, etc) Th cylinder is a "blue". This is a chrome bore, so it isnt like one can just have the cylinder bored out as with a sleeved 2strk. Both my father and I are looking on Ebay for a NOS blue piston, no luck so far If worse comes to worse, we can get the next oversize (which is still availible), and have US Chrome do a Nikasil job. But, its a bit $$$$. Still going to try pulling one of the pins out on our junk pistons, to see how easy it could be. WWGICD What would the Guys in Cuba Do? (Think of the Harlistas)
07-08-2010, 08:29 AM
#15 |
What could go wrong?
Oddometer: 4,985
If i was in your shoes I dont think I could ever sleep again knowing I removed and reinstalled that pin, my luck loosening it would be the doom of the piston, cylinder, rings and beyond.
Is there no way to source a matching set
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd |
