Old 07-08-2010, 05:16 PM   #1
YukonTracker OP
Ride your Way
YukonTracker's Avatar
Oddometer: 249
Your Broke Down Bike (and dignity)....
In total controversy with tradition I will not start with a photo. Simply because none of my bikes have ever let me stranded so far. C'mon push aside yerr pride and share some shame or tears....
.... oh and I hope this can be a "bash free zone".
MotoDrifters Rentals & Tours
ryan@motodrifters.com
http://www.motodrifters.com
YukonTracker screwed with this post 07-12-2010 at 11:08 PM
YukonTracker is offline   Reply With Quote
Old 07-09-2010, 04:57 PM   #2
astrofil
Oddometer: 111
Broken cluth on the way to labrador
I will start big :)
astrofil is offline   Reply With Quote
Old 07-10-2010, 12:47 AM   #3
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,737
Sweet Jesus man
2012 Triumph Bonneville
2006 Suzuki Vstrom
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 07-10-2010, 03:33 AM   #4
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,387
My bike never breaks down.....
Hole in radiator, overheating
Top bushing on rear shock worn through
Headgasket (because of radiator in first picture)
18.000 km chain and sprockets toally shot. Kept throwing chain.
Wheel and sprocket carrier bearings siezed up. Possibly due to riding in water/ mud and also having to ride about 1000 km with chain as tight as possible so it would throw it.
Waterpump
Overheating (possibly due to first time radiator was shot)
Headgasket shot, ride over. 1350 km from home. Thanks (Super) Dad for coming to my rescue
Going to fix it and if there's time do some diving. There wasn't
Replaced
  • Waterpump
  • Valves w/ all parts
  • Headgasket
  • Bottom gasket
  • Piston rings
Rode 450 km and blew the headgasket again. Had the head skimmed 0,25mm and put it back together last weekend.
Removed the seized sump plug at the same time. Now have about 380 km on it since the latest headgasket failure....crossing fingers....
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 07-10-2010, 03:42 AM   #5
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 6,492
Chasing down an electrical short on the second day of a 5 day rally...thankfully I was at Whitehorse Gear and they allowed me to use there shop.
PWRCRZR is offline   Reply With Quote
Old 07-10-2010, 09:41 PM   #6
johnnyadventurepants
johnnyadventurepants's Avatar
Oddometer: 490
I just don't like this thread! It scares me! I still haven't even had a flat tire yet.
2008 WR250X/R
johnnyadventurepants is offline   Reply With Quote
Old 07-10-2010, 09:50 PM   #7
Bob Tosi
Bob Tosi's Avatar
Oddometer: 1,593
When you're lost in the wild and scared as a child. And death looks you bang in the eye, and your sore as a boil, its according to Hoyle to cock your revolver... and die. But the code of a man says "fight all you can" and self-dissolution is barred. In hunger and woe, its easy to blow... Its the hell-served-for-breakfast thats hard........Robert Service
Bob Tosi is offline   Reply With Quote
Old 07-11-2010, 12:09 AM   #8
TwinDuro
Befuddled Adventurer
TwinDuro's Avatar
Oddometer: 255
Speaking of flat tires...
Here's a photo from a few years back of me fixing a flat on my Dad's CT110... Which occurred at a 76 station within the first 3 miles of a day-long ride
As you can clearly see, I'm practicing the sacred art of "tire whispering," in which you put your Van Gogh up to the tire as your rotate it and listen carefully for it to reveal it's dirty little secrets.... This one fell to a 1" long brass nail...
Luckily with two tire irons, a small bicycle pump, a patch kit, a Crescent wrench, a Leatherman and a hardy assortment of cuss-mumbles, we were good to go in less then half an hour.
You've never battled a tire until you've been put up against the massive sidewall strength of a 70/100-17 4-ply Honda CT110 tire!
TwinDuro screwed with this post 07-13-2010 at 10:20 AM
TwinDuro is offline   Reply With Quote
Old 07-11-2010, 12:17 AM   #9
Dread Pendragon
cows happen
Dread Pendragon's Avatar
Oddometer: 1,741
In the mountains by Bear Lake in Idaho, here's Rick fixing a hole punched in by the gear shifter.
- Mike -
Unce . . . Tice . . . Fee Tines a Mady
Mesquite Area Ride
Hot Springs Ride
Dread Pendragon is offline   Reply With Quote
Old 07-11-2010, 12:18 AM   #10
Waco
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,896
I've had a battery die and a hose came loose inside the gas tank. I have no picture from either incident.
Support the AMA.
Waco is offline   Reply With Quote
Old 07-11-2010, 12:21 AM   #11
Waco
Waco's Avatar
Oddometer: 14,896
Originally Posted by astrofil
I will start big :)
Damn, I probably would have had it hauled to the nearest dealer. That's getting a bit deeper into the bike than I usually go.
Support the AMA.
Old 07-11-2010, 12:26 AM   #12
sidetrack one
Boss STAG
sidetrack one's Avatar
Oddometer: 3,724
The day my 1150 became a 575! Burnt out valve at 18,000 Kms
I live more in 5 minutes on my motorcycle than some people live in a lifetime...............
My last ride started badly,steadily got worse,until it ended in disaster, but apart from that it was excellent!
sidetrack one is offline   Reply With Quote
Old 07-11-2010, 12:57 AM   #13
Gravel Seeker
Thomas
Oddometer: 3,387
I'm surprised so few are answering the call
Gravel Seekers.com
Hey !
Old 07-11-2010, 01:22 AM   #14
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,238
Send a message via Yahoo to wibby
Steering head bearing felt slightly notchy
Two fugging days of pounding, heating, cussing and it finally fugging came out
Tranny started making a funny noise in second gear
Needle bearings?
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 07-11-2010, 05:43 AM   #15
dch
Rock Chalk
dch's Avatar
Oddometer: 235
Hey, whats' all this oil all over my bike?
This is not good!
Well, this is the end of this trip. This is a friends bike. We made it to Evansville In. got off the bikes and saw this. John called the BMW dealer in Louisville, they came and got it the next day. Ended up being a cracked breather tube or something.
This was back in 08, Ironically, Johns bike is back in the shop with major engine damage, due to a timing chain problem.
dch is offline   Reply With Quote
Times are GMT -7.   It's 04:44 AM.
