Old 11-19-2004, 02:19 AM   #16
overlandr
Dystopist
Oddometer: 5,899
Mermites anyone?
Don't forget the mermite boxes available from various ex-army surplus stores in the US. Cheap for those there (most of you guys) but freight makes them impossible for anybody overseas. There is a longish thread for a KLR with them on and they give it a kinda military look!
The other factor to consider is sacrificiality! When one is in a major ding (accident), it may be better to have a pannier or pannier support absorb the impact, yield or even break before the serious failure of something far more expensive like, say a subframe. My 03 640 adv had a pair of Zega's on it and was in some sort of accident (previous owner's - I bought it at a salvage auction cheapish) which almost completely caved in the outer face of the 41 litre box. The 5mm bolt that screws into the RHS top subframe bent and only slightly bent the top subframe say 5mm inwards and gave it a twist of approximately 5 degrees anticlockwise - easy to fix!. New Zega is likely to be cheaper than new subframe in worse case scenario!
Cheers
overlandr screwed with this post 11-19-2004 at 02:24 AM
overlandr is offline   Reply With Quote
Old 11-19-2004, 12:03 PM   #17
Tim
Tim's Avatar
Oddometer: 2,362
Good point about the width of the KTM rack and the plastic Gobi bags Mack. I was looking at the width of the KTM rack on the 950 at the bike show and noticed that that too had alot of "wasted" space but I guess that that is allowing for the plastic bags alongside the hot cats.
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying........."Damn..We F*cked Up" - Anon.
Tim is offline   Reply With Quote
Old 11-19-2004, 08:49 PM   #18
jambie
Oddometer: 290
Markjenn,
If you're looking for a rack with "standoffs" for soft luggage,
check out www.promotobillet.com. I bought their rack setup for my KTM 625 SXC (same mounts as LC4), and it is one sweet piece of workmanship. I'll try to get a pic uploaded, but in the meantime, consider it a Quality piece of kit.
Cheers,
Tom
jambie is offline   Reply With Quote
Old 11-19-2004, 10:00 PM   #19
markjenn
Oddometer: 10,456
That promoto stuff looks nice, but the full rack/pannier protector combo is $260, too pricey for my blood. The protectors are more reasonable at $75, but I don't know if that is per side and it sure looks like they need the rack to attach to. I may give them a call.
- Mark
Old 11-20-2004, 09:32 AM   #20
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,239
Originally Posted by G.Kennedy
What is the consensus on Pelican size? Are those 1600 or 1550?
I would PM jimjib or scottcolbath (sp?) the new owner of that bike. Or measure how big you want them and pick the pelican cases to fit.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 11-20-2004, 05:05 PM   #21
scottcolbath
scottcolbath's Avatar
Oddometer: 7,090
Originally Posted by meat popsicle
This is my ideal setup. This is jimjib's setup, now owned by someone else here (speak up!):
That be my bike now. When I got it from Jim, it only had the side cases. Just this weekend, I decided that for daily use I did not need the side cases, and instead I put one of them on the luggage rack and removed the side case frame and hardware. Pic below.
I mounted the Pelican by drilling four holes in the case (sorry, I hate the word "pannier" and using some steel straps I found at Ace, I put those beneath the bars on the rack and ran the bolts up to the bag. It appears sturdy. I may ride Box Canyon tomorrow for a test.
S.C.
scottcolbath is online now   Reply With Quote
Old 11-20-2004, 05:22 PM   #22
G.Kennedy
G.Kennedy's Avatar
Oddometer: 1,850
Hey S.C., What size are the cases you are using? I am thinking of getting 1550. The 1600 seem like they would be overkill, if I have the space I will fill it, if I don't I will streamline the kit. Also, I have used pelicans for carrying camera gear on airplanes, but have never picked up an empty 1550. Do you think these are heavier than a comparably sized aluminum case?(ie Jesse or Happy Trail)
'00 R1100RT
'05 525EXC
'08 Hypermotard
IBA#11791
G.Kennedy is offline   Reply With Quote
Old 11-20-2004, 08:43 PM   #23
scottcolbath
Oddometer: 7,090
G., the cases are 1520s. They sure seem light to me, but I can't compare to anything else. What I will say is that I wouldn't worry too much over a few pounds. A big breakfast and a full gas tank probably make a bigger difference. :)
S.C.
Old 02-03-2005, 06:21 AM   #24
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
S.C.
HT has weights listed
I think it was 9-10ish lbs depending on size
Surly
I pray that you dont look at me
I pray I dont look back...
Where is Surly?
Surly is offline   Reply With Quote
Old 02-03-2005, 06:41 AM   #25
meat popsicle
Ignostic
Oddometer: 14,239
the pelicans are probably heavier than any true pannier available
but they are infinitely more impact resistant
that makes the weight worthwhile
Old 02-03-2005, 07:34 AM   #26
SRG
SRG
SRG's Avatar
Oddometer: 1,288
I have a set of the KTM (factory) pannier racks that came with my new/used '02 640. I was thinking about cleaning them up and putting them in the Flea Market soon when I saw this thread. They need some minor repair (one broken weld from vibration, not crash) and maybe a repaint. I was going to do this before putting them up for sale but if anyone wants to save me the trouble - make me an offer.
SRG
Lazy Traveler
SRG is offline   Reply With Quote
Old 07-14-2006, 11:03 AM   #27
meat popsicle
Ignostic
Oddometer: 14,239
New Pelican Top Loader
Pelican 1440 Top Loader
They run a tad over 2000 cubic inches inside, or about 33L; more than double the 1430, which everyone wanted to see larger. Whoop, dere it is!
Here is one source:
http://www.pelican-case.com/1440-black.html
$124.95 ea.
Old 07-14-2006, 11:28 AM   #28
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
you cut and paster you
Surly
Where is Surly?
Old 07-14-2006, 11:30 AM   #29
meat popsicle
Ignostic
Oddometer: 14,239
I Love
Old 07-14-2006, 01:26 PM   #30
Airhead
More human than human
Airhead's Avatar
Oddometer: 2,099
I've converted over to soft luggage for the 640...right now I have an HT rack, but I just use it to keep my Ortlieb soft bags off the muffler and tire. I don't think I will ever go back to hard luggage for my off-road bike...the Ortliebs hold plenty, are secure on the bike, are totally waterproof, have survived (too) many crashes, weigh less than 1/4 of what most hard cases do (which helps to keep the bike handling well), and you can buy 5 sets of them for what most hard luggage would cost you...
Just my $.02
'05.5 KTM 950 Adventure
2008 KTM 450 EXC-R
All Orange, Baby!
Airhead screwed with this post 07-14-2006 at 01:42 PM
Airhead is offline   Reply With Quote
Times are GMT -7.   It's 10:05 AM.
