Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 05-24-2013, 06:45 AM   #17116
outagas
Oddometer: 19
tyres
Thanks for the info, mine is a 800 roadie (bloody fantastic bit of kit).
the Anakees3 sounds good, the last new tyre I bought was a 023 for my ZRX1100 but that was a heavy bike and i sold it shortly after.
the Scorpians are great in my opinion, im no knee scraper but i do get it over on roundabouts and long bends! id be happy with another set of Scorpians if they lasted longer?
good wet adhesion and long life from the centre of the tyre is paramount.
thanks for the advise on dual compounds however im fully aware of these tyres!
Rgds Lee.
outagas is offline   Reply With Quote
Old 05-24-2013, 07:24 AM   #17117
RichardU
Let's Ride
Oddometer: 903
Originally Posted by blacktiger View Post
It's designed that the 10mm bolt side is seated and the only "slot" is on the 8mm bolt side. Not every handlebar clamp is designed this way as some require a gap both sides but these don't. The 10mm bolt are what clamps the whole thing to the top yoke. So, you should tighten the 10mm bolts fully and then the 8mm. The 8mm bolts just clamps the handlebars.
Good catch.
RichardU is offline   Reply With Quote
Old 05-24-2013, 08:11 AM   #17118
cug
Oddometer: 5,031
My instinct is that you're doing #3 & 4 the wrong way round. It's designed that the 10mm bolt side is seated and the only "slot" is on the 8mm bolt side.
Think about it again:
1) Make the big bolt flush (not torqued).
2) Torque the small bolt (will have slot).
3) Torque the big bolt from flush to tight.
Slot is on the small bolt applying the pressure to the handlebar as it is supposed to be. The manual says "torque the big bolt first" but that has the downside that you can't rotate the Rox risers to the desired position anymore. You can completely follow the manual if the position of the Rox works for you where you can tighten the 8mm bolts through the hole in the Rox clamp.
cug is offline   Reply With Quote
Old 05-24-2013, 08:13 AM   #17119
cug
Oddometer: 5,031
Originally Posted by RichardU View Post
Good catch.
See my explanation. It's correct if you don't want to be able to put the Rox risers in the desired position - which is impossible with the front bolts fully torqued.
Old 05-24-2013, 11:54 AM   #17120
BlackBeast
BlackBeast's Avatar
Oddometer: 936
Thanks for clearing that up. I'm doing my rox install this evening.
BlackBeast is offline   Reply With Quote
Old 05-24-2013, 12:43 PM   #17121
Snapper
Snapper's Avatar
Oddometer: 2,517
Given the recent tire talk, I'll throw in my experience with tires on my Roadie, now with ~22k miles and I ride mostly tight technical twisties.
Changed my stock Scorpions at 5k - front tires hit side wear bars and "V" profiled badly and made for scary handling. Another example of fronts wearing out first and I've always worn 1.5 rears to 1 front in the past.
Next were Anakee2s in the stock size - fronts were reaching side wear bars in 2.5k! while the rears were absolutely fine. Michelin partially warranteed this front and I put on a 110/80-19 RADIAL Anakee2 instead.
Ran two sets of the Anakee2 RADIALs 110/80-19 and 150/70-17. Rears good for about 6-7k and fronts maybe 10k (back to 1.5 : 1 ratio) which is about as good as I'll ever get. I like to swap both tires at the same time for obvious reasons.
Love this radial front - haven't had a tire retain such a round profile to the very end like this. I generally don't comment on "stickiness" as I'm a pure street rider and rarely slide on clean asphalt (wet or dry) - so in that regard, all premium tires seem to "stick" fine for me. The most important thing for me are how long the tires last, and how badly they profile toward the end - "V" in front, flat spot in rear.
I have 110/80 and 150/70 Anakee3 radials on now (a couple hundred miles but will reserve comment to the end of life). I'm hoping for longer life while maintaining round profile to the end.
Don't know if my front "V" profile/excessive tire wear issues are due to bias-ply vs radial (Michelin only seems start radials at 110/80 size, not sure about the Scorpions), or as mention above, something to do with the narrower tires (contact patch should be the same size though - I understand determined by weight and air pressure alone).
Lateral G Junkie
Fear Deer
Snapper is offline   Reply With Quote
Old 05-24-2013, 01:44 PM   #17122
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,967
Originally Posted by Snapper View Post
Given the recent tire talk,.
I'm running the Anakee2 right now and the noise alone is enough for me not to buy them again. I like the rear tire feel but not the front. I got around 12k miles from the OEM tires (front could have gone another couple thousand miles) which is average for me. I expect the rear Anakee2 to at least last that long but can't see the front making it that far. The Anakee3 looks nicer. Lots of good tires to choose from for this bike.
swimmer is offline   Reply With Quote
Old 05-24-2013, 09:44 PM   #17123
marloweluke
The Flying Dutchman
marloweluke's Avatar
Oddometer: 149
That's amazing. I've haven't really gotten more then 8400 km out of a rear, that's just over 5k miles. You must have really smooth tarmac where you live, I suspect mine get chewed up by rough winter worn asphalt.
WITHOUT RISK........THERE IS NO ADVENTURE
marloweluke is offline   Reply With Quote
Old 05-25-2013, 08:05 AM   #17124
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,723
Not too many frost heaves and chuckholes in Tucson, I suspect.
Old 05-25-2013, 08:15 AM   #17125
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,967
Just checked my maintenance log and I removed the OEM Scorps at 13,333 miles. I am also averaging over 54mpg over the life of the bike so I am there is some correlation between the two. It's not that I am a slow rider. I have some track experience and have been to a track school, I guess I just don't find myself doing a lot of fast accelerations which is where rear tire wear (and poor mpg) are mostly going to come from.
Old 05-25-2013, 08:17 AM   #17126
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,967
The heat and lack of city budget must be enough to do the trick then because most of the roads here are in bad condition.
Old 05-25-2013, 05:40 PM   #17127
Snapper
Snapper's Avatar
Oddometer: 2,517
.... I guess I just don't find myself doing a lot of fast accelerations which is where rear tire wear (and poor mpg) are mostly going to come from.
I get no enjoyment out of acceleration in straight lines - just tickets. My experience is that riding lots of twisties at spirited paces kill tires, and straight line/slab riding is the easiest on tires. Twisties wear out the center of rear tires through engine braking setting up entry speed for corners and coming down mountains and simply the constant variations in speed, road grade and lean angles - we rarely use brakes. My riding groups occasionally head down to NC and WV for some great mountain riding, and with about twice as many corners as the Northeast, we burn tires in half the time, or about 3k for PR3s on liter bikes. I've worn out a few sets of rear tires on the sides before the centers as well.
Lateral G Junkie
Fear Deer
Old 05-26-2013, 06:39 AM   #17128
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,375
Originally Posted by vanjoosten View Post
That is a really nice item!
Another option is Harbor Freight. They sell a complete set of metric hex sockets for $12.99. I just removed the 17mm from the socket and keep 17mm wrench in my bag. The rest come in handy when working on the bike...
http://www.harborfreight.com/9-piece...7880-html.html
Untitled
I know this is late to the party, haven't read this thread for a while. This is what I use:
http://buy1.snapon.com/catalog/item....re&dir=catalog
Very compact, fits a standard 3/8 drive, and because it is shouldered it fits nicely and solid against the head of the axle nut. It also fits the fill and drain plugs on many VW/Audi transmissions, which is the reason I have one.
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 05-26-2013, 08:00 AM   #17129
Midpack
Midpack's Avatar
Oddometer: 133
Tire wear
I never had a bike wear out the front tire before the rear. The original front Trail/Battle Wing on the 800XC was gone at 7300 miles with a good 2000 left on the rear. I went with the stock sized Heindenau K60s for a more 50/50 tire. Have been very pleased with 7000 miles on the rear with channels worn creating a solid center strip. The front just starting to show minor brake cupping. I believe I'll get another 3 - 5 thousand out of the rear. These tires handle as well leaned over as the Wings. Last weekend did a nice two wheel drift keeping up with sport tourers on Hwy 191 on the eastern boarder of Arizona. For a 21" front this Triumph can handle!
Midpack is offline   Reply With Quote
Old 05-27-2013, 08:55 AM   #17130
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,898
As I'm not interested in ROX risers I'll bolt mine on the correct way. Your method might well allow you to move the risers but it still leaves it torqued incorrectly as by torquing the small bolt first, when you torque the big bolt second, the small bolt will end up over tensioned and you could well snap the clamp (I've seen it happen). And, as I said before, it could be that all the mating surfaces that the 10mm bolt should seat, won't be.
Still it's your bike, do what you want.
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Times are GMT -7.   It's 11:47 PM.
