Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 05-27-2013, 10:07 AM   #17131
cug
Oddometer: 4,861
Originally Posted by blacktiger View Post
Your method might well allow you to move the risers but it still leaves it torqued incorrectly as by torquing the small bolt first, when you torque the big bolt second, the small bolt will end up over tensioned and you could well snap the clamp (I've seen it happen).
As long as you bring the front to a slight torque, that's not quite correct. The "slot" stays with the small bolt, the big one takes only torque to the bolt and the mounting surface if you had it flush and slightly torqued before torquing the small one.
cug is offline   Reply With Quote
Old 05-27-2013, 10:56 AM   #17132
BlackBeast
BlackBeast's Avatar
Oddometer: 934
I tried to install my Rox this w/e and boy are they difficult and trying to follow either Cug or Blacktiger's direction has just got me all confused.
Has anyone done this successfully correctly and being able to torque with the larger and smaller bolts as of the life of me, can't figure this out. FWIW, I was never good with solving puzzles either.
BlackBeast is offline   Reply With Quote
Old 05-27-2013, 11:27 AM   #17133
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
If your not picky about the Rox riser position, then it's easy. Just position the risers to allow access to the bolts. You can use the socket as a stop & it makes it easy to set both risers exactly the same. Torque them down & install the bars & top clamp. If your picky about the riser adjustment (like me), then you'll need to make adjustments from there. I loosened the big bolts, spun the risers, & retorqued the big bolts.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 05-27-2013, 12:10 PM   #17134
vintagebob
Oddometer: 156
A set of these really helped.
I'm fighting with my Kaoko/Barkbuster installation right now. The throttle and cruise control don't seem to work if I tighten the end bolt (using the screw provided with the Barkbusters, not the one provided with the Kaoko).
2014 BMW R1200GSA
2013 Honda CB500X
vintagebob is offline   Reply With Quote
Old 05-27-2013, 12:37 PM   #17135
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,749
So now you've changed your tune and not torquing the small bolt to spec. Make your method & mind up! Anyway, I don't care any more.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 05-27-2013, 02:45 PM   #17136
cug
Oddometer: 4,861
What the f are you talking about? Seems that you just don't understand it and therefore think it's wrong. What about reading and thinking?
Front (normally big bolts) first. Flush, so that you have solid contact. Then small to spec. Then big to full torque. You'll get to proper spec on both. If not you're doing it wrong.
Old 05-27-2013, 03:08 PM   #17137
cug
Oddometer: 4,861
There are two types of Rox for the size that fits the Tiger best. The matte ones have a hole in the lower part of the clamp that holds the bars. The "machined finish" don't. Most people want a bit higher and back, so they can put the hole over the back and put the allen key through it.
Old 05-27-2013, 03:13 PM   #17138
marty_uiuc
moran
marty_uiuc's Avatar
Oddometer: 280
I don't understand all the fuss about the bolt torque procedure. Why isn't German torque on all 4 bolts good enough, and why does it matter where the slot is?
Sent from my DROID RAZR HD using Tapatalk 2
the D in your DEMOT
marty_uiuc is offline   Reply With Quote
Old 05-27-2013, 09:11 PM   #17139
cug
Oddometer: 4,861
Torque setting of "handwarm" is likely fine. The importance of where the slot is comes from the fact that there is an 8mm and a 10mm bolt on each clamp. 8mm is specified for 26NM, 10mm for 35NM (from memory, I'm on a trip at the moment).
If you tighten the 8mm first, then the 10mm, you put the higher torque on the 8mm due to the fact that the 35NM are are meant to be set with the upper and lower clamp flush, meaning you put the torque on the bolt, tread, and sold metal connection. Not on the smaller bolt that isn't specified for that value and, more importantly, also not on the handlebar itself.
You can see it as 35NM connects the clamp assembly to the triple tree, 26NM holds the handlebar. And that is only correct if the "slot" is at the smaller bolt and that one is set to 26NM.
I use a torque wrench just to be certain I get the setting right and to get a feeling of "how tight" certain settings are. On the road I don't take the torque wrench, but I bring my memory ...
Old 05-28-2013, 03:00 AM   #17140
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,749
No mate I read just fine. The problem is your memory. Here's what you wrote originally and you say to torque the 8mm bolt. NOT a slight torque as you changed it to later.
An install note:
1) Take off handlebar.
2) Put risers in
3) Tighten 10mm bolts so that they are installed flush
4) Tighten and torque 8mm (I did that through the opening of the risers) to 26NM
5) Now torque 10mm bolts to 35NM
If you do it the other way around you torque the "open slot" of the clamp to 35NM and that one is supposed to have only 26NM. So, be careful about the order when you install them.
Anyway, as I said, do what you want. It's not my handlebars that are going to fall off.
Old 05-28-2013, 06:48 AM   #17141
cug
Oddometer: 4,861
"A slight torque" or a "tighten the front to be flush" is just about the same thing.
Seems you're still not following (reading, thinking, understanding?) what I said. But so what. I don't care about how you tighten your handlebars.
cug screwed with this post 05-28-2013 at 06:38 PM Reason: Typo
Old 05-28-2013, 06:38 PM   #17142
cug
Oddometer: 4,861
FYI: Left front rotor warped
Right now I'm on a trip through the Western states (California, Nevada, Utah, Arizona, maybe we put a foot into New Mexico and Colorado).
When we were crossing Death Valley (basically at the gas station in Furnace Creek) I noticed a strange grinding noise and also that braking at slow speed was "bumpy". Found out that the left side front rotor is warped enough that the ABS sensor was grinding against the ABS ring on the rotor ...
As we were just 600 miles into our 3.5k miles vacation trip, we decided to press on and had to figure out a preliminary solution. I didn't have anything with me to use, but was actually quite lucky: the bolt holding the ABS sensor bracket has a washer. It's supposed to go: fork leg - bracket - washer - bolt. I moved the washer between fork and bracket, that created enough distance so that the sensor wasn't grinding anymore. Braking is still a little bumpy at slow speed but not to the point that it's a risk. ABS is working fine (tested).
Unfortunately the rotor is ~$250 ... Not happy.
Has anybody seen good aftermarket brake disks for the Tiger 800?
Old 05-28-2013, 06:43 PM   #17143
ducnut
Oddometer: 3,305
This doesn't make sense, as the rotors float and the ABS ring is solid mounted to the carrier. Hmm.
If you're out of warranty, I'd call Brake Tech.
http://www.braketech.com/
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 05-28-2013, 07:04 PM   #17144
cug
Oddometer: 4,861
I can see that the brake disk isn't flat, it's "moving" (How do you call what?) from side to side a little when I look down along the fork leg when riding.
Just the left side with the ABS ring. I might bring it up with Triumph. The bike is still in warranty.
Old 05-28-2013, 08:04 PM   #17145
Kawidad
Kawidad's Avatar
Oddometer: 4,805
Undiscovered damage from your crash?
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Times are GMT -7.   It's 09:41 AM.
