Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 07-19-2011, 07:54 PM   #7306
jphish
Oddometer: 618
Romulux - glad you're ok! ATGATT probably saved some skin and perhaps more - Smart! The 800 aint that badly damaged. Mine has a few scratches too (low speed tip over) I would get any weld cracks remedied though - dont want any rust / corrosion in there. j
jphish is offline   Reply With Quote
Old 07-19-2011, 07:56 PM   #7307
av_mech
Risk Taker
av_mech's Avatar
Oddometer: 1,143
Originally Posted by Romulux View Post
Low sided the Tiger last Friday on the way to work. First time I've been down (had my motorcycle endorsement for 4+ years now).
It was basically a section of road that forces a U-turn. I have taken this road a hundred times and while I've noticed it can be slightly slick (lots of oily trucks as it's a necessary section of road to enter the highway), it was my fault for travelling slightly too fast and turning too aggressively.
I was going between 15 and 20 miles per hour and the crash was about as mild as a crash can be. I was turning, turning, and then sliding. I don't believe I touched the brakes or blipped the throttle, just applied too much (counter)steering. Not sure if the front or rear was lost first. I slid a few meters, the bike kept going straight across the road and "gently" bumped the opposite curb with its tires. I got up, picked the bike up, and went to work. My damage was a quarter sized abrasion on my arm and mildly poked my index finger. Wear your gear.
I foresee trouble for a lot of owners with the rear footpegs. The crash couldn't have been much gentler unless I wasn't moving at all and the rear left footpeg is tweaked slightly. The weld joint has slightly fractured the powder coating so that it's flaking a bit around the weld.
Other damage includes plastic abrasion, small crack in the plastic, left cover abrasion, clutch lever broken and clutch pedal abrasion, left front turn signal broken, the "friction plate" that keeps the rear footpeg locked in the up position broke so it won't stay up. Side stand, foot peg, bottom chain guard, left handlebar mirror and end slider abraded.
I'm replacing the turn signal and clutch lever. The rest I'll leave for now as a reminder to not be stupid.
Crashing sucks. There's nothing worse than seeing your wonderful bike sparking and skidding away from you. Photos here.
On the upside, my Micatech luggage shipped and will be here Thursday!
I had my first crash the other day too. I got a little happy with the throttle on wet gravel. Bent my rear brake up a bit. Good on ya Triumph for making a steel lever as opposed to a cast one!!
Photobucket
I wear ATGATT religiously. I HIGHLY recommend a Thor Impact Rig. Awesome under the jacket and even better with no jacket to stay cool.
Photobucket
Get some big ass crash guards like the ones that Happy Trails made for me. They'll be on sale soon.
Photobucket
Bottom line... Glad you're OK!!! Seriously. Crashing sucks. Really happy to hear when someone walks away.
2011 Triumph 800 XC
2007 Honda CRF 250X
1994 Kawasaki KLX 650R
THE ADVENTURES OF TYSON AND HOBBES
THE BACKCOUNTRY PURSUIT- Boise, Idaho's consignment specialist for ADV gear!
av_mech is offline   Reply With Quote
Old 07-19-2011, 07:59 PM   #7308
Deano955
Insatiable
Deano955's Avatar
Oddometer: 4,039
That stinks! At least it was just a flesh wound...
The welded passenger pegs will surely be redesigned in my opinion. The demo bike at the dealership I bought mine from was similarly low sided and resulted in a bent right side passenger peg and frame. The salesman told me that the bike could be totalled for the bent frame.
Fix yours up and get on with it. At least it's running!
BTW I went to WMU in Kalamazoo. One of my best buddies is a Kalamazoo Public Safety officer (K-9 unit). How's things in the zoo?
Save $5 off your smugmug account with this coupon( 1qoLJk8tfsGWM )
COHVCO, AMA, ETC...
Deano955 is offline   Reply With Quote
Old 07-19-2011, 08:10 PM   #7309
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Deano955 View Post
What strikes me is that there are many with this sort of issue with their brand new Triumph Tiger 800's. I'm not alone with this issue although that does not give me comfort. Given that this is a great forum to discuss motorcycles, I'd like to continue to bring up issues with mine.
Deano,
Many of us are watching and waiting ... and hoping for a good outcome on this. Summer is short ... it's a shame your bike is spending prime riding months in the shop.
You are not alone. Indeed, the brazen ladies of Canada doing the AK trip on "borrowed" Tiger XC's also appear to be having stalling issues ... but they are continuing on ... so maybe not too bad an issue. I would not want to be in AK ... or Mexico ... or Peru' to discover these problems. Shake down rides are the way to go.
Fingers crossed for good luck and good vibes coming your way.
Old 07-19-2011, 08:22 PM   #7310
Adv Grifter
Oddometer: 6,128
Crashing sucks BIG TIME! Glad you're OK ... that is what is important. Hang in there ... painful as it is now, the bike can be brought back to like new. Bikes are cheap and expendable compared to unrepairable body parts. Tomorrow will be a better day!
Old 07-19-2011, 09:34 PM   #7311
Vzuke
Vzuke's Avatar
Oddometer: 148
Hand Guards aGain
Johno33772,
I wish I would have known about the brackets that you had for your Cycra hand guards, those are sweet!
Looking through the web site I think I found the ones that you have:
U-Clamp ‘08 Pro Taper/KTM OEM Renthal Taper/Neken – (#1156-02)
Did you special order those separately or were they apart of a “kit”.
av_mech,
I believe they take into account the decreasing diameter of the bar for the clamps. Just as long as you order the diameter of the handle bar that is at your handle bar mounting point.
I ordered the PROBEND CRM – 1 1/8” BARS COMPLETE RACER PACK from the CYCRA web site. They came with the Center Reach Mount.
I guess the Tiger bars are too wide for this set up because the center reach mount did not make it to where they are in the picture. That is what threw the hand guard bar mounting angle off since it was further up the bend in the bar.
The other problem I had was, without spacers at the end of the bars there wasn’t any clearance for the clutch and brake levers when they were pulled in. You could move the controls inward but then you would have to cut/file the pins off the switch modules.
I voiced all my concerns in the comment section when I ordered them but I don’t think anyone reads that section.
By the way the replacement Barkbusters went on with little effort. They provided a 1/2” round spacer at the end of the bars for lever clearance.
Vzuke is offline   Reply With Quote
Old 07-20-2011, 02:17 AM   #7312
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,870
Originally Posted by Mercury264 View Post
BT - what's the scoop on the 95 limit - is it some ECC (fecking retards) thing ? Is it due to some tiered licensing sort of thing ? I know there was a reason Triumph kept it below 95 and I always assumed it was down to some legislation....
It is to do with tiered licencing. At the moment we have to pass the main test riding a bike of at least 47bhp and the EU is proposing another level at twice that. Hence 94bhp for the Tiger.
I'm not too well informed about all this because it doesn't really concern me having had my full licence for 37 years. So I don't know the full details.
Triumph has a history of this with the Tiger955i which is rated at 104bhp. France introduced a limit of 105Ps some years ago and the Tiger fits nicely. However, there are moves afoot within the EU for complete uniformity so they're trying to persuade France to scrap that limit. BUT..................now France is introducing all sorts of other shit like having to wear hi-viz.....................don't get me started!
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 07-20-2011, 02:37 AM   #7313
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,870
I've read on numerous occasions that you guys in the US fix your own bikes after a spill like this. Is there a reason that you don't claim on your insurance especially in view that the frame might be bent?
Old 07-20-2011, 03:02 AM   #7314
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,263
Ah the good old EU....where about the only country that plays by the rules are the Brits
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-20-2011, 03:16 AM   #7315
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,870
It's worse than that. Our civil service, the idiots that back up the government, actually "gold plate" some of the directives that come from the EU. That means they add their own bits to it. God help us!
Old 07-20-2011, 06:02 AM   #7316
scottie boy
Homebrew Guru
scottie boy's Avatar
Oddometer: 1,775
It depends on the severity of the damage. American insurance companies generally view a claim for an accident that was your fault as a mark against your record regardless of size. In their eyes, its better to make one $10,000 claim than three $500 claims. Unfortunately if you make too many claims, you run the risk of cancellation or at least increased policy rates.
Lets say for example, you had a minor accident that did $1,000 in damage. Usually you will have a deductible of around $500 which diminishes your reimbursement. You then have to ask yourself do you want to possibly have your insurance rates raised for several years for a measely $500 check from them.
sparkyairracing.com
scottie boy is offline   Reply With Quote
Old 07-20-2011, 06:13 AM   #7317
Midpack
Midpack's Avatar
Oddometer: 127
Jesse Luggage
JPHISH, Al didn't say. He's has a lot going on. Tuesday/Wednesday his South African distributor was showing up. You can tell he's really into his business and motorcycles. My father owned several machine/manufacturing businesses so I can tell you Jesse Luggage Systems is one quality operation..
Midpack is offline   Reply With Quote
Old 07-20-2011, 06:16 AM   #7318
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,765
Triumph has determined by way of their ability to access my bike's ECU via the internet that it needs a new throttle body assembly. The throttle position sensor will not stay in adjustment and one other part that I can't remember is affected as well. All of these parts are grouped into the throttle body assembly and therefore, mine needs to be replaced.
I believe this assembly is made by Keihin; sounds like Triumph received a batch of faulty parts.
I hope your replacement part comes in soon!
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 29-31, 2015
markbvt is offline   Reply With Quote
Old 07-20-2011, 06:52 AM   #7319
av_mech
Risk Taker
av_mech's Avatar
Oddometer: 1,143
Originally Posted by Vzuke View Post
Johno33772,
av_mech,
Great info! I'm sure more people here appreciate that info than just me. No CRMs from Cycra. I'll just wait to get confirmation from Johno or somebody else that the U-mount clamps are part number 1156-02 and order today!
2011 Triumph 800 XC
2007 Honda CRF 250X
Old 07-20-2011, 06:56 AM   #7320
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 4,130
This is from an older Tiger.
This bike (not mine) was "totaled" by insurance company. Re-purchased by residual value, now has salvage title. A weld job, and it is back in business.
Expensive insurance... because welding a frame is critical according to their eyes, bike has to be totaled. Inefficient transaction, in my eyes, but this rule blanketing frame issues has been in effect for many years. What surprises me is that Triumph has been on this business for a while and they should have thought about a solution to this. The obvious one is to have sub-frames on these bikes, which would circumvent the rules and allow for such small damage to have an easier and less expensive fix.
We all pay for this on our insurance bills.
Lion
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR is offline   Reply With Quote
Times are GMT -7.   It's 01:46 AM.
