Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 03-28-2012, 01:19 PM   #11896
dwoodward
dwoodward's Avatar
Oddometer: 5,566
Originally Posted by internalcombust View Post
I also riveted some bungees under my rear seat to hold a first aid kit.
I need to get busy and get a fuse panel installed and get some farkling done.
dwoodward is offline   Reply With Quote
Old 03-28-2012, 01:24 PM   #11897
dwoodward
dwoodward's Avatar
Oddometer: 5,566
ECU questions
1) How often does the ECU sample ambient air pressure (altitude)? I know some bikes only sample at startup, which has been problematic for riding up and down large elevation changes at a single go. (Think Colorado).
2) Which wheel drives the speedometer sensor? It'd be easiest on Triumph if it were the rear, since XCs and Roadies have the same rear tire, but on the DRZ400 Suzuki perversely does it off the front, so S and SM machines read differently if you swap to a different wheel.
Old 03-28-2012, 01:47 PM   #11898
RichardU
Let's Ride
Oddometer: 901
I used electrical eyelets for the rings
Very innovative.
Fuse panels take up a lot of room. You can accomplish the same thing and save a lot of space by using inline fuses which easily tuck into nooks and crannies.
RichardU is offline   Reply With Quote
Old 03-28-2012, 02:12 PM   #11899
dwoodward
dwoodward's Avatar
Oddometer: 5,566
There are lots of ways to do things. On the sport bikes, I tend to just use fuses, although that's more splices, more failure points, more ring terminals on the battery or a barrier strip nearby. On the bikes I will ride longer distances on, I prefer to use a fuse block, half switched, half constant. THe FJR has both- a barrier strip for all the lights (HID headlights + driving lights) and a charging plug; and a fuse block for everything else (heated grips, heated clothing socket, GPS circuit, intercom / radios, tankbag power)
Old 03-28-2012, 02:35 PM   #11900
RichardU
Let's Ride
Oddometer: 901
... more splices, more failure points, more ring terminals on the battery or a barrier strip nearby.
You should try Posi-locks which eliminate all of these problems. I have used them on dirt bikes, exposed to the elements and ridden hard for over 30,000 miles, and have never had a failure of any kind. I consider them superior to solder, (and I do know how to solder).
Old 03-28-2012, 02:40 PM   #11901
KildareMan
KildareMan's Avatar
Oddometer: 674
Sampling happening constantly.
Depends on whether you have abs or not. No abs - speed sensor above countersprocket housing. Abs bikes use the abs ring (front I think)
KildareMan is offline   Reply With Quote
Old 03-28-2012, 02:42 PM   #11902
KildareMan
KildareMan's Avatar
Oddometer: 674
A correctly soldered joint is the best mechanical connection there is. Takes more work but better.
Old 03-28-2012, 02:50 PM   #11903
syspig
Dog Scratcher
Oddometer: 97
Not necessarily. Eastern Beaver's 3-circuit solution takes up a tiny amount of space, fitting very easily next to the battery/fuses. And, for the vast majority of Tiger 800 owners - I'm willing to bet three additional circuits is more than enough.
syspig is offline   Reply With Quote
Old 03-28-2012, 04:01 PM   #11904
dwoodward
dwoodward's Avatar
Oddometer: 5,566
A splice is a splice is a splice is a... And personally, I hate Posi-anything. The shit just looks flakey to me, despite people having good luck with it.
Solder joints are stiff and subject to fatigue failure in high vibration environments.
Rider's heated gear, GPS, intercom/radios, aux lights, horns. Five. Maybe I might be able to reduce that by one or two, depending on how I might tap the auxillary and aux light circuits instead. Normally I'd do my own heated grips, but the previous owner already did the factory kit.
Besides, the installation is half the fun.
Old 03-28-2012, 04:03 PM   #11905
Marsh Tiger
Marsh Tiger's Avatar
Oddometer: 550
Eastern Beaver's 3-circuit solution takes up a tiny amount of space, fitting very easily next to the battery/fuses. I'm willing to bet three additional circuits is more than enough.
Eastern Beaver stuff is tops
Marsh Tiger is offline   Reply With Quote
Old 03-28-2012, 04:36 PM   #11906
jphish
Oddometer: 617
Dont trust posi-locks ? Hmmm. Well tens of thousands of miles on 7 different motorcycles - never ever had one fail. If you install them right - really not much to go wrong.
jphish is offline   Reply With Quote
Old 03-28-2012, 05:25 PM   #11907
internalcombust
Yes its dirty, thanks.
internalcombust's Avatar
Oddometer: 1,586
Very innovative.
Thanks.
2012 Tiger 800XC
04 DRZ400S
79 GL1000 basket case
internalcombust is offline   Reply With Quote
Old 03-28-2012, 05:34 PM   #11908
dwoodward
dwoodward's Avatar
Oddometer: 5,566
The concept just makes me cringe. If I solder or crimp something, I can see how good the connection is. Posi-Taps scare me worse.
I have wire strippers, solder, good quality connectors, good crimpers, shrink tubing, heat guns, torches, and soldering irons, and I'm not afraid to use any of it.
Old 03-28-2012, 07:41 PM   #11909
RichardU
Let's Ride
Oddometer: 901
That's okay, people have a long history of being scared of stuff: electronic ignition, disk brakes, fuel injection, ABS brakes, telephones, indoor plumbing, flying contraptions, ...
I have all that stuff too, and been using it since the 60s. But I have an open mind and have taken the time to discover a superior solution. And how much of that stuff will you have with you on the side of the road when you need to repair something? You can rewire Posi-locks with nothing but your bare hands (and teeth if you need to strip a wire.)
Seriously, if you ever get a chance, just connect two wires with a Posi-lock and see if you can pull them apart. You might be surprised.
Old 03-29-2012, 08:22 AM   #11910
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,168
+1 I have them on all my bikes including my Husky and I have not had a single one fail. Not one. They work as advertised.
As for soldered joints, I am pretty sure I read somewhere on ADV that an aircraft mech said that soldered joints were a no-no in the aircraft world due to stress fractures of the joint.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Times are GMT -7.   It's 04:43 AM.
