Old 07-18-2012, 06:19 PM   #13591
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 20,414
Originally Posted by Rob Dirt View Post
I'm going to air the full bores down for now. The rear has stepped out a few times. I thought it was due to the muffler & arrow map. I've been using stock 36/42. The tires work way better then they should in dirt (aired down). Definately be careful on the Full Bore in the rain.
Next time I'm riding in the rain, I'll see what's up with these tires. Some emergency stops are forthcoming to test my ABS too.
Where I landed. I found my rubber peg cover.
Bummer Rob, glad you came out of it OK.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Mercury264 is online now   Reply With Quote
Old 07-18-2012, 10:30 PM   #13592
xylent
Oddometer: 5
Originally Posted by dirtconnector View Post
My left front was found broken on a ride just Friday. I was thinking maybe the factory or dealer torqued it too tight? The dealer is going to cover it. Mine is 2012 I've had for little over one week. I super glued mine till the dealer gets the new part in.
Could be a heat issue, maybe. It's been hot here in WNC, but I tend to think it's a bad batch of plastic/rubber that the indicator is made of.
Just finished my 8100-mile PA to AK ride. I still have one good indicator, and all my duct tape mods have held up for the last 3 weeks. I picked the bike up right in the middle of the nasty east coast heat wave, and I think the direct sun exposure made a bad plastic problem worse. Both front indicators cracked around the mounting ear...hard to believe they could be overtorqued enough to break with that brass spacer installed on the bolt. Just a weird occurrence all around. Good to hear your dealer is taking care of you. I haven't bothered to call mine yet...might just find an LED unit. I have handguard blinkers on my DRZ and I really like them, so I may go that route with improved guards.
Other than that, the bike performed beautifully. Rear battlewing is smoked. Off to mcsuperstore to shop tires..
xylent is offline   Reply With Quote
Old 07-18-2012, 11:50 PM   #13593
KildareMan
KildareMan's Avatar
Oddometer: 505
@Bueller
Reduce the heat, not thermostatically controlled, from the cat which is considerable. There is no increase in noise I can detect or strange resonances. Most who have done it report a modest increase in torque. Will let you all know.
Well after 1st ride post re-assembly. The exhaust sounds ever so slightly deeper. Obviously the cat rattle is now gone & bike feels "different". Slightly more urgent would be how I can best describe it as. Oh and the right foot area is cooler to.
Costs:
My time
new header gaskets x3 = £10.15 - from UK
new header nuts x6 = £3.24 - from UK
Welding = €40
KildareMan screwed with this post 07-19-2012 at 01:23 AM
KildareMan is online now   Reply With Quote
Old 07-19-2012, 02:23 AM   #13594
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 2,514
Send a message via Yahoo to blacktiger
Originally Posted by KildareMan View Post
Costs:
My time
Welding = €40
Why did you need new header nuts? Can't imagine they're rusty already and shouldn't have been seized on the studs this new.
2002 Tiger955i in black, 68500 miles.
2012 Tiger800XC in black, 19000 miles.
Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, 600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)...
blacktiger is online now   Reply With Quote
Old 07-19-2012, 02:47 AM   #13595
KildareMan
KildareMan's Avatar
Oddometer: 505
Several of mine were in shite order. 2 were hard to remove. Ended up cleaning all the stud threads with a die. Also the manual says to replace. To a great extent I suppose it depends on the environment that you are in as well. After 18 months in the Irish "Climate" new ones made sense.
Old 07-19-2012, 02:54 AM   #13596
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 2,514
Sounds like you needed some stainless nuts. Or, back in the old days I remember them being brass.
Old 07-19-2012, 03:39 AM   #13597
KildareMan
KildareMan's Avatar
Oddometer: 505
I think I'll put them on my regular replacement list, every year maybe. Minimal cost.
Old 07-19-2012, 06:01 AM   #13598
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,396
Originally Posted by browneye View Post
The FB's are a hundred bucks less for a set, and if I can get 4-6K miles out of them I'll be thrilled. Then again, if the rear is toast at 2K I'll be trying something else.
Then you might be pleased to know that I'm at just under 6000 miles on the Full Bore rear currently on my XC, and at the rate it's been wearing, I wouldn't be surprised if it's still good for another thousand miles or more. I'm VERY happy with this tire -- handles great on pavement, works much better off pavement than you'd think it would, and it lasts. (For comparison purposes, the Shinko 705 rear I had on before was spent at 4500 miles.)
I've got a Shinko 705 on the front, and it's coming up on 8000 miles; still looks great. Something tells me the FB M-41 front tire would easily be a 12k mile tire.
Interesting; I've ridden in plenty of rain with mine and haven't had any problems.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 31-June 2, 2013
markbvt is offline   Reply With Quote
Old 07-19-2012, 07:16 AM   #13599
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,255
--mark
What pressure do you use in the rear? I may have pushed to hard with cold tires. I only traveled about 300 yards.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 07-19-2012, 07:39 AM   #13600
Porky
Don't Pass Gas
Porky's Avatar
Oddometer: 458
@Bueller
Costs:
My time
Welding = €40
Were ECU adjustments required?
'08 Suzuki DR650
'11 Triumph venom yellow ABS Tiger 800 - SOLD (Too much heat and exhaust popping)
No fat chicks, fender will scrape.
Porky is offline   Reply With Quote
Old 07-19-2012, 07:46 AM   #13601
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 8,134
Send a message via ICQ to Yossarian™ Send a message via MSN to Yossarian™ Send a message via Yahoo to Yossarian™ Send a message via Skype™ to Yossarian™
My guess is NO.
Old 07-19-2012, 08:01 AM   #13602
KildareMan
KildareMan's Avatar
Oddometer: 505
None.
Old 07-19-2012, 08:40 AM   #13603
cyclingtom
Sim Sala Bim
cyclingtom's Avatar
Oddometer: 3,380
For those XC riders that aren't particularly fond of tubed tires this is a little project that doesn't require too much effort and results in a tire that can (usually) be easily plugged roadside. There's a fair amount of info on spoke sealing for those curious types.
Usual disclaimer for project like this: Preform at your own risk.
Rear has a "safety lip" on the wheel. Let me tell ya, this would be a real bitch to break the bead trail-side with a sidestand.
Scuff the surface up and clean with non-alcohol solvent
Cover the spokes in case a future adjustment is needed and insert proper tubeless valve stem.
Cover evenly with, in this case, 3M 5200 sealant.
Allow product to cure. They have a regular and a Fast Cure 5200. If I do this again it'll be with the Fast Cure.
Install tire, balance, submerge in tub to check for tiny leaks, and ride.
Several rides and all is well.
If the front wheel had "safety lips" I would be sealing that one too, but most of my punctures have been on the rear so hopefully the front won't need an in the field fix....
Inconsequential Adventurer
Upon us all a little rain must fall. L.Z.
cyclingtom is offline   Reply With Quote
Old 07-19-2012, 08:44 AM   #13604
Bueller
Cashin?
Bueller's Avatar
Oddometer: 16,328
Since you have partially filled the drop center section of the wheel, how much harder does this make it to change a tire?
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
Bueller is offline   Reply With Quote
Old 07-19-2012, 08:56 AM   #13605
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 2,510
Converting to Tubeless
Freaking brilliant.
I got to try out the bead breaking with the side stand yesterday and it's a piece of cake. Works great. Still, so much nicer to plug one on the road. As someone mentioned, sure as shit it's dark, cold, and raining when it goes.
Front is super easy to remove and dismount one tire bead - just like the regular dirtbikes. The rear? Not so much!
browneye is offline   Reply With Quote
Times are GMT -7.   It's 04:26 AM.
