Old 07-18-2010, 07:25 AM   #16
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,689
Originally Posted by Ducksbane
Geno_Rocket ... I think you should check your rear ride height ....
That's a good point. The OP said nothing about verifying correct sag for the suspension. Sag is the first place I'd look then if it keeps weaving I'd lower raise the forks in the triple tree 5mm and see if that makes a difference.
Old 07-19-2010, 06:03 PM   #17
geno_rocket
Oddometer: 143
Geno_Rocket ... I think you should check your rear ride height ... Much as I dislike the front K60 on loose surfaces I have Never had any instabilty on a firm surface.
I would be concerned and check the ride height if the wobble occured anywhere else except this spot on the interstate. That mixture of rain grooved asphalt and concrete is the only place where I have the issue, but it is a big issue there, so I am chalking it up to the tires. When I get away from this one stretch of highway (I-64 east and west at the I-270 interchange in STL for anyone so interested) then I have no problems. Just a perfect mixture of traffic speed, wheel diameter, tire tread, and suspension mass to make the bike squirrely on those grooves.
Heck, the rain grooves on the highway at that location would probably be considered ruts in some locations. Now that I think about it, that is why I took the BMW adventure riding school - to learn how to ride those things!
Ducksbane, as you suggest, rear ride height should not be overlooked. I read back through the posts and none of the original posters mentioned whether the wobbles occur when the bike is fully loaded or not. Assuming the rear ride height is at the lower limit of specifications, and the front is at the upper limit and you are riding the bike fully loaded with gear - the net result can be a significant unloading of the front end and resulting instability at speed. I have the preload cranked up pretty high as I am a big boy, so I discounted that point in my situation. All that said, this weekend, when riding over my favorite highway interchange with fully loaded bags, I felt there was a bit more wobble, but I knew why and expected it - the load I was carrying unweighted the front end a bit more.
Okay, at the risk of extending this thread even more, does anyone know how much difference the diameter of knobbies (any type) are from the OEM tire? That difference in diameter could upset the ride height and potentially bring on a wobble. Now a F8 is not a racebike, but racers are concerned with such things. What the heck, the post is only two pages long right now.....
geno_rocket screwed with this post 07-19-2010 at 07:07 PM
geno_rocket is offline   Reply With Quote
Old 07-19-2010, 08:36 PM   #18
Moab OP
Moab's Avatar
Oddometer: 132
Wobble continued
Thanks for all the comments, they have certainly got me testi g different theories.... I have experimented since my original post and I am absolutely convinced of a couple things, first of all the wind can be a significant factor in wobble, as u are buffeted back and forth...that in combination of a death grip when it happens only exacerbates the problem.
Have gotten to a point where I can duplicate the wobble every time, and while the knobbies make the problem worse, I think wind buffet and loose clothing combined with gripping too hard plays an equal part.
I can almost always decrease the wobble down to almost nill with some simple adjustments.....
May not work for everyone but in my case it sure did.
Thanks all
Good, Bad.....I'm the guy with the gun
'04 1150 GS
'09 KLR 650
'10 800gs
Moab is offline   Reply With Quote
Old 07-20-2010, 03:33 AM   #19
WOLVERINE
Keep her pinned!
WOLVERINE's Avatar
Oddometer: 625
I put my stock Anakee's back on to compare....Let's just say the wobble(Squirrelliness) has gone away and all I can say is 180KPH is no problem and stable!
If you think you're free, there's no chance of escape!
2008 R1200GSA
WOLVERINE is offline   Reply With Quote
Old 07-20-2010, 04:42 AM   #20
upweekis
upweekis's Avatar
Oddometer: 2,717
Originally Posted by GrizGirl
I was just writing up some thoughts on the 800 after going 4700 miles over every imaginable road surface in 9 days of driving. The front end with knobbies and highway driving became an issue on the trip. It is unstable. Above 90 mph it is downright dangerous. Yes, at highway speeds with knobbies you will feel the frontend wobble. I felt it with the battlewings as well but it was not as pronounced as when I went to TKC-80's.
Up to 85 I just had to get used to the wobble. It never affected cornering or my ability to maintain control of the bike. You start going faster than that and you have some issues. Just be aware and watch your speed, particularly when you are passing at interstate speeds. More details will be in a post I'm working on.
Cathy
21 inch front wheel, Knobby tires and 80+mph on pavement, and people think the front end shouldn't wobble?
Piss on the "Urban Dictionary" -- Speak English!
upweekis is offline   Reply With Quote
Old 07-21-2010, 01:43 PM   #21
rchrds
Head Doucher
Oddometer: 117
Running the stock battlewings, no wobble, to 95 MPH. I put on TKCs for some off-roading in Colorado, and experienced the same wobble above 75mph with a single rider. Adding the wife on back, and the wobble range increased to ~85 mph, so extra weight on the bike definitely makes a difference. The wobble lessened some after 1000 miles or so on the TKC80s (all on about 4 days) That may have had something to do with rubbing the corners off the knobs.
Justa noob view.
rchrds is offline   Reply With Quote
Old 08-19-2010, 12:12 PM   #22
MSH
The Salt
MSH's Avatar
Oddometer: 3,213
Thanks all
I am getting the same speed wobbles after switching to TKC80's. Did BMW of Utah swap out your rubber? They swapped out mine! I wonder if they dont balance them after they swap? Did you end up pulling the weights off of the front wheel? PM'ed
Matt
~KTM 640 Adventure R~
"Lately it occurs to me what a long, strange trip it's been"
MSH is offline   Reply With Quote
Old 08-19-2010, 01:36 PM   #23
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,689
Matt
I threw a set of TKC on my bike and forgot to balance them. They had a pretty noticeable hop at around 35-40 mph, but on the highway they were smooth up to about 80. Never got above that, and no wobble for me.
They were 1.5 ounces out of balance when I checked.
Old 08-19-2010, 02:50 PM   #24
ecce
ecce's Avatar
Oddometer: 129
I could feel how the front end became less stable when putting on a metzeler karoo 2 (without the T). Nothing huge just more nervous so to say.
Increased pressure to 2.2 bar and since then I dont notice as much.
What I am experiencing is exactly what I expected when I switched from my r1200gs with wider and smaller front wheel to this proper narrower and larger wheel of the f800gs.
I guess that every thing you do to make the bike handle better offroad will cause it to handle worse onroad...
ecce is offline   Reply With Quote
Old 08-19-2010, 07:49 PM   #25
MSH
The Salt
MSH's Avatar
Oddometer: 3,213
What is 2.2 bar? A European measurement?
True!
Old 08-19-2010, 07:59 PM   #26
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,689
True!
32(ish) PSI
Old 08-19-2010, 08:17 PM   #27
GrizGirl
Oddometer: 1,442
Hmmm... at what point did I say I expected a smooth ride? I didn't. There will be a wobble, there will be movement in the front, even at much slower speeds. What shouldn't happen are death defying full bike sways from left to right that had my companion convinced I was going to die that day. That shouldn't happen.
And no, I was not overloaded, me and my gear weighed less than many of the riders alone weigh who have 800's, so that was not the problem.
GrizGirl is offline   Reply With Quote
Old 08-19-2010, 09:11 PM   #28
gr8ridn
gr8ridn's Avatar
Oddometer: 406
True!
The standard conversion is 14.5 PSI= 1 bar
2014 R1200GSAW
Racing Blue, Premium Group, DWA
gr8ridn is offline   Reply With Quote
Old 08-20-2010, 01:01 AM   #29
Ceri JC
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
Things I'd check:
Tyre pressure,
Wheel bearings,
Headstock bearings,
If all those are okay, try street tires and balance the wheels for the street tyres.
Only problem I've had in this area was my bike liked tracking straight a bit too much, turned out to be headstock bearings (replaced under warranty).
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is offline   Reply With Quote
Old 08-20-2010, 05:04 AM   #30
MSH
The Salt
MSH's Avatar
Oddometer: 3,213
Gaaahhh!!! It just sucks to be doing investigative repair work on a bike that has 700 miles. I know its the rubber knobbies. The first 600 miles were free of any kind of problem. No wobbles, nothing!
Has anyone tried a front tire (knobby) that didnt shimmy and shake?
Times are GMT -7.   It's 09:07 AM.
