Old 07-16-2010, 08:18 AM   #1
Ridin'nFishin OP
Oddometer: 467
3rd Gear Problems 1996 R1100GS
Just bought my first BMW and I love it and I am going to fix it.
Here I am just a few weeks ago the day I picked it up.
How many people have had the same problems with their GS? I am wanting to see if this is common or not for the 1100 GS.
I saw this on Anton Largiader’s website: http://www.largiader.com/ and this describes exactly what my bike is doing.
edit: 2-25-2011
I hope that others that are newbie's with these old BMW's will find this tread before they do what I did, go into the tranny 2 times before I figured out what the problem was.
If you have a older BMW, check to see what transmission you have in it. If it is not a M97 start looking for one or be ready to ship the parts to someone to undercut the gears. They skip gears because they are not undercut.
"My bike 'skips' in third gear...
...almost like the ignition cuts out momentarily, or some gear is skipping a tooth." You need transmission work. This can happen to any gear, but usually second or third suffers first. People will try to tell you the shock coupling in the transmission is slipping from one position to the next... hogwash. It's not possible. What's happened is that the shift dogs have rounded off and a shift fork is bent. The gear is only engaged by the rounded part of the shift dogs, which let the gear slip off and bear against the fork. That in turn springs the gear back into engagement the next time the dogs line up a fraction of a revolution later. The problem can start with a bent shift fork (from dropping the bike on the shift lever, etc) or with rounded dogs (from too many missed shifts or half-shifts). It can also start from poor initial assembly of the transmission, whereby there was never enough shift dog engagement in a particular gear.
You can be certain you have this problem if the oil is an iridescent gold color when you drain it. The gold is the surface of the shift fork wearing away; normally there is absolutely no wear on the shift forks regardless of mileage. Thin slivers of metal that you find will be from the edges of the shift dogs.
Bottom line is, it needs to be repaired. The problem will get worse and you will damage the shift drum. A good rebuild brings M93 and M94 transmissions nearly to M97 spec. Nearly, meaning that the engagement dogs are straight and five out of six bearings are 'clean.' There will still be one open bearing and an M94 will still have O-rings, but neither difference is significant.
Riding a Motorcycle is like flying like a Eagle without ever leaving the ground.
Ridin'nFishin screwed with this post 02-15-2011 at 07:12 AM
Ridin'nFishin is offline   Reply With Quote
Old 07-17-2010, 07:42 AM   #2
Ridin'nFishin OP
Oddometer: 467
What do you think?
Maybe some of you could give me some insight on what else I might have to do to my GS or about my current transmission problem.
I have already changed all the brake lines and bought brake pads, just not installed yey.
I will be tearing down my bike in the morning and will bring the tranny to a local shop to rebuild for me.
I don't like my bikes to be down, I want to ride!
Ridin'nFishin screwed with this post 07-17-2010 at 06:15 PM
Old 07-17-2010, 07:52 AM   #3
Galen
Oddometer: 172
My 96 GS did this in 2nd gear at 12K in 2000. I had it rebuilt to near M97 specs (BMWNA covered the parts as "good will"), but now it's skipping in 5th gear with only 28K on the bike. Transmission's out and heading to the bench. I'm probably going to attempt to repair it myself this go 'round--when I find some time. But, if I find a good used M97 in the meantime... or a cheap used GS with non-transmission issues (missed a couple local ones a couple months ago)...
Galen is offline   Reply With Quote
Old 07-17-2010, 08:32 AM   #4
Ridin'nFishin OP
Oddometer: 467
Interesting
Thanks for your input.
I wonder what else I should change while in there.
Old 07-17-2010, 06:31 PM   #5
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,855
I had a used RT trans in my GS for a while and it did exactly what you describe. I wouldn't suggest you fool with it yourself. Get it to someone who can fix it properly, like Anton.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 07-17-2010, 06:40 PM   #6
Ridin'nFishin OP
Oddometer: 467
Thanks,
I'm going to pull it tomorrow and bring it to a local shop on tuesday. Or do you think it is a specialized thing that I should send it to Anton?
Old 07-17-2010, 07:16 PM   #7
slartidbartfast
Oddometer: 4,855
I think it's a specialized thing. Your local guys MIGHT do a fine job, but why risk it? There are others with good reputation for transmissions but Anton's the first who came to mind. You're adding shipping but the cost might still be lower overall and you'll know it was done right.
Old 07-23-2010, 01:12 PM   #8
Ridin'nFishin OP
Oddometer: 467
Look ar her now
I have the parts ordered and I am going to replace the parts myself.
Here is what it looks like today, transmission on jack.
Here is what the inside looks like. Looks cut and dry simple so I took it farther apart.
The culprit is the 3rd/4th gear shift fork. I can't tell it it is bent or just wore, the wear marks are clearly visible. I ordered parts and will put it back together myself.
Old 07-23-2010, 01:36 PM   #9
slartidbartfast
Oddometer: 4,855
Check the engagement dogs on the gears. If they are rounded, it may well happen again soon. I'm sure you don't want to go into the transmission twice unless you have to.
Old 07-23-2010, 02:57 PM   #10
Ridin'nFishin OP
Oddometer: 467
engagement dogs?
The dogs are in the middle on left and right. The dogs on the right do not look rounded, but they are not as sharp as the ones on the left. It was hard to picture.
Old 07-25-2010, 04:56 PM   #11
switch
Romanian Trailbiker
switch's Avatar
Oddometer: 679
So did you fix it?
As you noticed, I have a similar problem with 2nd gear. I'm quite curious to see if simply replacing the fork helps.
No bikes right now :( Used to own the best dommie in Romania and a damn-good R1100GS. Modded the hell out of both before selling them. Looking to get another bike soon.
switch is offline   Reply With Quote
Old 07-25-2010, 06:36 PM   #12
Ridin'nFishin OP
Oddometer: 467
waiting
I'm waiting on parts to come in Monday, then I will put it together.
I don't know if those dogs are worn to bad on yours ot not, but they are worse than mine. I can barely tell they have any wear at all, so I am going to put it back together.
Old 07-26-2010, 06:59 AM   #13
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,277
Good on you for tearing into it yourself !!!
Tbone is offline   Reply With Quote
Old 07-26-2010, 08:20 AM   #14
Mituk
Mituk's Avatar
Oddometer: 228
My '96 does this in #rd as well . . .
My '96 with 36k miles also does the "skip" in 3rd gear . . . IF I engage 3rd below about 3300 rpm. If I run up to 4800 - 5000 in 2nd, then go to 3rd, it doesn't do it. Not sure why this would matter. So far I've just been very careful with 3rd gear, and spend as little time as possible there.
But, it's good to know what it will take to fix it. I'll have to pull the transmission this fall and ship it off to Anton. . . . rats . . . .
Dave
'98 R1100GS
'96 R1100GS(morphing into . . . )
'99 R1100RT
Mituk is offline   Reply With Quote
Old 07-26-2010, 08:30 AM   #15
GSbiker
new and un-improved
GSbiker's Avatar
Oddometer: 11,738
+1
Just take your time and get all the pieces back in the right place.
TRLcam
GSbiker is offline   Reply With Quote
Times are GMT -7.   It's 10:56 PM.
