10-17-2010, 06:07 PM
#46 |
JockeyfullofBourbon
Oddometer: 5,636
I haven't had a lick of trouble with my spoked wheels. I'm not sure I'd even bother with a 1mm runout on either front or rear.
Perhaps coming dirt bikes has framed my expectations of what a wheel should and shouldn't be. Simply saying, 'I was riding my moto off the road and your BMW literature says, "UNstoppable" therefore any damage that occurs from this sort of riding should be covered under warranty.' seems to me to be a load of hog anus. Anyone of us could take a set of Woody's exel creations or anyone's custom built, better than OEM wheels and bash the living hell out of them. And then we could call woody and say, 'well, you made these wheels for a BMW GS which you know is UNstoppable so this is a warranty.' You might as well try calling Exel with the same claim. Let's see how far you get with that? Maybe it was a shoddy wheel, maybe someone can't pick a line or was riding above their heads and smacked into something square at speed. All the company can (woody included) is look at the damage and it's generally not hard to tell impact damage from a wheel that is manufactured out of spec. Checking your spokes is something you're supposed to do at the 600 mile and 6k service. If you can't be bothered then shame on you. I've built hundreds of high end bicycle wheels (road and mountain) and trued loads of moto wheels (albeit never a set of BMW wheels).
"So what makes this protest different is that you're set to die, Bobby?" --May well come to that. "You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?" -- It's in their hands. Our message is clear. They're seeing our determination. |
10-17-2010, 09:18 PM
#47 | |
Built to Last
Oddometer: 3,087
gome here bubale,,,
OBTW,,i do believe you that you weren't abusing your bike,,,AND we do send an analysis of your wheel and what went wrong etc w
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W |
10-18-2010, 05:07 AM
#48 |
TeutonicChronic
Oddometer: 835
pretty good for some skinny spoke wheels
I've been running my OEM spoke wheels on my HP2 for the past 3 years, on and off. I ride 'em pretty hard, rocks and ruts and edge hits. I've trued the front wheel twice. Unlike standard spoke wheels, with nipple on the rim, BMW wheels have nipple on the hub. Takes fewer turns to get effect at the rim. So, take it easy and turn lightly, then check for true. Otherwise, you may over-crank and make the wobble worse.
Anyway, I'm pretty well impressed with the wheels, as I ride 'er pretty hard through all kinds of hard hits. My Woody Wheels are stronger and narrower for dirt...but OEM ain't bad.
Warthog 2006 HP2 |
10-18-2010, 01:16 PM
#49 |
Oddometer: 466
What torque setting are the spokes?
What is the correct torque setting for the spokes? Not sure I've haeard or seen that yet?
Coming off a KTM 990 I'm used to the spoked wheels and spoke maintenance. Not saying I could true a set of x-laced, but I can atleast tell if the spoke are torqued correctly, then decide to send them to Woody if need be. Please advise on the torque setting? Thanks, Matt.
2010 R1200GS Adv 2008 KTM 990 2003 Kawa Z1000 (Orange) 2000 RC51 # 41 "I can't lead, I go too fast..." Scott Hinkle, April 2010 |
10-18-2010, 09:02 PM
#50 | |||||||||||||
Built to Last
Oddometer: 3,087
torque values for BMW X-lace/spoke wheels
need more torque values ,,here's alink to eveerything ya need to know about your R1200GS http://www.r1200gs.info/misc/torque.html ![]() w
10-18-2010, 09:32 PM
#51 | |
Oddometer: 31
10-19-2010, 05:57 AM
#52 |
Oddometer: 168
I have a big problem with cross spoke wheels.
The unanodised ones on my 1100 are a knuckle breaking b*tch to clean! |
10-19-2010, 07:18 AM
#53 | |
Built to Last
Oddometer: 3,087
unanodozied rims can be re-juvenated....
or powder-coating them to the color of your choice,,,either process is usually $100 or less ... CAveat Emptor,,,these old rms will usually have little tiny pits and corrosion that has a tendency to be revealed when anodized an possibly when baked in the oven[out-gassing it's called....tiny little craters] ,,,,my experience finds that satin black does the best job of not making these blems more noticeable in either configurationin your case upgrading to a ss spoke and powder-coated nipple kit would be a wise investment ![]() the job can run circa $300-500 depending on what gets done [an $800-600 saving] ![]() w
10-19-2010, 09:59 AM
#54 | |
Oddometer: 168
10-19-2010, 12:29 PM
#55 |
because I can
Oddometer: 6,045
Hey Woody! I haven't read all the posts so forgive me if these questions have already been asked and answered. What is BMW's run out limits and what are yours? Now that I know that these wheels can be dealt with I am sure I am going to start checking run out and I bet it won't take too long to find some that need warrantied.
Do the grub screws strip on ya very often? Do you soak them real good first? What happens if one does strip? |
10-19-2010, 01:04 PM
#56 | |
Oddometer: 17
10-19-2010, 01:40 PM
#57 | |
Built to Last
Oddometer: 3,087
actually it's all just common sense in hindsight... 1,,start by blowing out the head of grub screw with compressed air and use dental pick to assist in removing dirt...not doing so will invariably not allow the 2mm allen to have full purchase,,and then you've added to your problems ![]() 2,, a squirt of WD-40 or similar penetrant to lube the threads 3,,here's the trick: with 5mm allen or T-40 Torx bit give each nipple a 1/8th turn ccw this relieves tension on the grub screw:>),,NOW ya can take a good 2mm allen [ ie one that doesn't have its edges worn round ] and remove it without stripping it 4,, re-installing em requires patience and accurate alignment or you'll cross thread em in a heart beat 1nm/1ft-lb torque FYI nipple and grub screw are about $2.50 if ya mess up here are two links pertaining to all your question http://www.advrider.com/forums/showthread.php?t=69728 and my first post on advrider ''demystifying the bunk re: straightening /truing/rebuilding GS wheels'' http://www.advrider.com/forums/showt...debunking+myth plenty straight data to chew on and Pulleeeze pass the word that it is Do-ABLE....help save yourself and your fellow rider anymore unneccesary and unwarented grief.. yes it is possible on a daily basis to true/straighten your wheels up to less than a third or a sixth of BMW's .060''/1.5mm run-out ,,,and our run-out specs are +/- a given number ie the wheel does not wander more than +/- a certain spec usually .005-010'' these days ![]() w
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W woody's wheel works screwed with this post 10-19-2010 at 02:54 PM |
10-20-2010, 09:14 AM
#58 |
because I can
Oddometer: 6,045
Thanks Woody!!
10-31-2010, 09:30 AM
#59 |
Stupid Hurts
Oddometer: 308
Woody,
I have some un even rear tire wear on my 05 GS. Last time I changed the tires I put the bare rear rim on my balancer and noticed a "hop". I don't have a measurement for you. The tire has a flat spot in it and is due for another set. Do you think it should be trued up? No vibration to speak of. Can post pictures if needed Thanks, Joe
-You can't get beat up with your feet up- "My Bride Says I'm An A$$hole To Ride With" Current stable: R1200GS, G3-TR 90 Bushmaster Past times: GS450L SV650 VF500F KE125 SL125 XL500 DR350 CR125 "Come visit me in the hospital, I dig carnations." |
10-31-2010, 10:40 AM
#60 | |
Built to Last
Oddometer: 3,087
uneven tire wear,,on X-laced bmw wheels
result....a wheel that won't cause your tires to wear out as rapidly,,,a smoother ride,,,peace of mind for less than $250 woody
