Old 11-22-2004, 01:46 AM   #1
Bigbird OP
"Dog Is My Co-Pilot"
Bigbird's Avatar
Location: The Point of No Return, in the Adirondacks, NY
Oddometer: 440
Question two batteries on one battery tender?
Has anyone tried keeping two batteries charged using a single battery tender? I wondered if it's possible to connect 2 batteries to one battery tender and keep them both charged up thru the winter storage period? Could you hook the two up in series and then connect the battery tender to the first, and have it charge both? Or will I have to alternate tending from one to the other?
[http://www.pinterest.com/dudones/
"Keep yer stick on the ice" Red Green
Bigbird is offline   Reply With Quote
Old 11-22-2004, 06:32 AM   #2
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
For one thing, I am glad you asked first. Batteries seem benign, but have a volitile side that makes me jumpy when considering stuff like that. I dont know the answer to your question....just wanted to toss in a comment
dead
Chopperman is offline   Reply With Quote
Old 11-22-2004, 06:46 AM   #3
AFekete
AFekete's Avatar
Oddometer: 3,208
Thumb from Battery Tender dot com....
http://batterytender.com/faqs.php/#15
very indepth explaination...
thanks,
Andrew
AFekete is offline   Reply With Quote
Old 11-22-2004, 09:24 AM   #4
xtphreak
from B4 "adventure bikes"
xtphreak's Avatar
Oddometer: 7,963
read the article closely linked by Afekete
it won't work in series.
that would require a 24 volt charger, you are thinking about hooking them parallel ... (+ to +) & (- to -)
if the charger will supply enuff current, hook charger to one battery, use 10 ga wire to connect to second ... again all + together & all - together
Do one thing every day that scares you. Baz Luhrmann
Women and cats will do as they please,
and men and dogs should relax and get used to the idea.
Robert A. Heinlen
Adventure is discomfort recounted at leisure. Flash / GSWayne
Chrome don't get ya home. Rob Nye
Stamp Out Hoplophobia in Our lifetimes.
1999 Tiger 885
1995 XT600E
xtphreak is offline   Reply With Quote
Old 11-22-2004, 02:58 PM   #5
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
The basic answer is NO.
IF you connect in series then the voltages will add. And the batteries MUST be of the same capacity (amper hours CCA etc). If they are not th esame one battery will charge befoer the other causing the non charged bater to never get a full charge.
IF you connect in paralell the voltages will be ok. But if one battery is faulty it can cause the second good battery not to get a charge and may well cause the good battery to fail too.
Basicly - don't do it. Not usless you spend days balancing the batteries. In which case you may as well buy another battery tender! I use to ballance batteries for frequency standards. Never again - I'd just buy new ones.
Frank Warner is offline   Reply With Quote
Old 11-22-2004, 04:16 PM   #6
SteveAZ
SteveAZ's Avatar
Oddometer: 1,212
What he said. Just save the headache and get another float charger.
You could float them in parallel *if* they are both already fully charged and topped off, but it just ain't a good idea...
SteveAZ is offline   Reply With Quote
Old 11-23-2004, 04:40 PM   #7
GOAT BOY
GOAT BOY
GOAT BOY's Avatar
Oddometer: 41
Eek
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOO! Don't do it you'll be sorry.
GOAT BOY
GOAT BOY is offline   Reply With Quote
Old 11-24-2004, 07:38 AM   #8
Sa-tevo
Jetmechs' Winston Wolf
Sa-tevo's Avatar
Oddometer: 505
It will be difficult to do. Here's the problem:
I used to help set up commercial slot car racing tracks. We often used lead acid truck batteries for the current capacity. If connected in parallel with no diodes, one battery would try to charge the other battery. This will lead to one weak cell in the low battery to run away and charge more, outgassing, getting very hot, and scaring the hell out of me as I didn't want a spark in that enviroment if I disconnected the charger or cables in the circuit. The batteries in parallel will always try to balance themselves, which they can never quite accomplish.
"Never should have destroyed the Bamiyan statues." - Popular sentiment of those partaking in the Gitmo Resorts vacation tour
Sa-tevo is offline   Reply With Quote
Old 11-25-2004, 02:03 AM   #9
Bigbird OP
Bigbird's Avatar
Oddometer: 440
OK, I'll just get another battery tender. Thought it was worth looking into, but obviously the "solution" is more trouble than the original problem is worth. Thanks to one and all for the feedback. Cheers
BB
Times are GMT -7.   It's 04:48 PM.
