Old 07-24-2010, 06:35 PM   #1
ProdigyXL OP
Long way north
Oddometer: 10
Question Where is the SAE connector ?
Hello,
I just bought a SAE To Dual Cigarette Socket Y Cable to power my etrex trough the cigarette car adapter. Unfortunately, I wasn't able to locate the connector on my bike. I know, I'm more than a noob.
If someone has the knowledge to help me, I would appreciate greatly.
Thank you.
Jim
(BMW F650GS 09)
ProdigyXL is offline   Reply With Quote
Old 07-24-2010, 06:39 PM   #2
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,772
You have to install it yourself...
Oh yeah... and make sure you don't make an embarrassing mistake like I did. I have both the GPS hard mounted and the connector hard mounted to the battery (I use mine for the trickle charger). Since there are so many terminals on the batter I thought I tightened everything up but the bike started acting funny like it was "resetting" itself or something. Turns out I hadn't tightened the connections enough, I used some fancy electrical grease as well a buddy from work let me borrow, works like a charm.
EnderTheX screwed with this post 07-24-2010 at 06:50 PM
EnderTheX is offline   Reply With Quote
Old 07-24-2010, 07:02 PM   #3
ProdigyXL OP
Long way north
Oddometer: 10
Ok so I'll have to buy another cable
EnderTheX, thanks for your reply.
If I understand correctly, I'll have to buy another cable to connect my SAE connector on the battery and I'm set.
Old 07-24-2010, 07:05 PM   #4
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,772
Yep I was originally hesitant to reply since I bought mine used and I'm unsure of what they come with stock but I had to install another cable. Here is a picture I borrowed off a site trying to sell em.
Old 07-24-2010, 07:15 PM   #5
ProdigyXL OP
Long way north
Oddometer: 10
Bingo
There will be so many wires on my bike that I'm thinking to hire a IBM consultant Once again, thank you. I'll buy the piece you mention, install it and it's done.
Old 07-24-2010, 07:27 PM   #6
TierHawg
Herder of the J-Cats
TierHawg's Avatar
Oddometer: 137
Here is where I placed mine:
TierHawg is offline   Reply With Quote
Old 07-24-2010, 07:41 PM   #7
ProdigyXL OP
Long way north
Oddometer: 10
Thumb
Very clean setup indeed.
Old 07-24-2010, 07:43 PM   #8
Too Many Toys
Adventure Poseur
Too Many Toys's Avatar
Location: Just off the Lincoln hiway in Ioway & Mesa, AZ
Oddometer: 1,200
FYI, SAE is the same as Battery Tender's use. Plus Powerlet Products has a ton of SAE cables/connectors.
I usually wire them directly to the battery, bypassing the CANBUS which allows you to charge your bike w/ a normal battery tender/charger. Direct to the battery will provide higher amperage also, thinking the CANBUS is only like 5 amps max. output. Not sure that's enough for heated clothing.
TMT
Too Many Toys is offline   Reply With Quote
Old 07-24-2010, 09:50 PM   #9
TierHawg
TierHawg's Avatar
Oddometer: 137
Forgot to add:
The SAE connector is from Battery Tender. I wired it directly to the battery, and ran it from the right-side, around the head tube, and located it near the left grip as shown in the pic above. I use it for the battery tender, and can use it for a tire pump and a cigarette socket to power a GPS / ect.
Old 07-24-2010, 10:48 PM   #10
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 817
Thumb Powerlet rock
I bought one of these from Powerlet to reduce the number of connections to my battery - http://www.powerlet.com/product/term...-fuseblock/409 It's pretty easy to cram down into the dead space behind the battery and lets you hook up four separate power and ground connections.
Bucko is offline   Reply With Quote
Old 07-25-2010, 04:50 AM   #11
JRWooden
Oddometer: 4,292
One more note...
I kinda went crazy and added several sets of taps.
A gerbing for my heated gear, an SAE for my tender, and a custom one for my GPS.
I caught what could have been a big problem if undiscovered ... the standard bolts on the top of the battery are not long enough for more than about two extra sets of leads. Watch your thread engagement at the battery posts if you go electrical-farkle-happy
Old 07-25-2010, 12:04 PM   #12
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 817
Originally Posted by JRWooden
One more note...
See my previous post for the solution...
Old 07-25-2010, 01:26 PM   #13
JRWooden
Oddometer: 4,292
I like your solution ... I'm just cheap
Old 07-25-2010, 03:08 PM   #14
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
I use a battery tender. It comes with an SAE plug.
How's this for a clean set up?
Left side of the bike wire tied up under left side panel:
Close up:
And the tender saying GREEN LIGHT =
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 08-26-2010, 12:52 PM   #15
Catskill
tree hugger
Catskill's Avatar
Oddometer: 1,783
BMW wiring for heated gear?
Searching for an answer that's in between the "gear" section of the forum and the "gs" section...this is one of the closest threads that came up when I searched.
I'm in the market for heated gear.
I own a F800gs...
Is there a Heated Gear brand (besides the $400 Aerostitch jacket liners) that makes jacket liners,gloves and pant liners that all hook together so you can plug them into the BMW plug? And is the F800 big enough to support gloves, jacket liner and pant liner?
I'm guessing the answer is "no" since that would be too good to be true but I figured it can't hurt to ask...
STOP the land grab
If we stuff the duck with chocolate, does that make him a fudge packer?
Catskill is offline   Reply With Quote
Times are GMT -7.   It's 09:12 PM.
