Old 03-13-2013, 06:11 PM   #286
epicxcrider
epicxcrider's Avatar
Oddometer: 645
The easiest to find is from an aprilia RXV.
I think there are others that work but you don't want one with less travel than oem.
Old 03-13-2013, 09:28 PM   #287
Bayner
Oddometer: 1,518
And you want ones with comp and rebound on each leg, rather than individually.
Bayner is offline   Reply With Quote
Old 03-13-2013, 10:53 PM   #288
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
As long as the Shiver 45 forks have more travel than the stock BMW forks you can shorten them to match the F800GS stock travel and length as long s you know the diference.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 03-14-2013, 08:41 AM   #289
dirtysouthjacket
dirtysouthjacket's Avatar
Oddometer: 539
Originally Posted by epicxcrider View Post
Do it! Pm me if you have questions!
Will do! I've sent a few pms to aprilia forum members... we'l see if I get any hits. My only fear at this point is finding a good suspension shop in the GA, SC, or NC states somewhere. I'll start working on that. I'd like to have a fairly fast turn around once I do the machining so I'm not off the bike too long.
I may not have gone where I intended to go, but I think I ended up where I intended to be. -Douglas Adams
2011 F800GS Alpine White, 1998 KDX 200, 2000 KL250G Super Sherpa
DSJ's Shenanigans
dirtysouthjacket is offline   Reply With Quote
Old 03-14-2013, 08:45 AM   #290
dirtysouthjacket
Oddometer: 539
I've also reread the thread again and think I know everything to do. Is there any way to find out a standard valve to use with the stock rxv springs and then the stiffer springs? That might mean people in the future don't need to go to a suspension shop? I'm still pretty limited in my motorcycle suspension theory.. But this thread is making me learn a lot! If the F800GS feels half as good as the trail bike I'll be pumped!
DSJ's Shenanigans
Old 03-14-2013, 09:03 AM   #291
epicxcrider
Oddometer: 645
All I did was rebuild the OEM Fork with the aprilia RXV internals with 10WT oil. No change to valving or the spring, all straight from the RXV. It will do until the end of the season when I'll probably ship it off to get professionally valved and sprung. The difference is amazing already.
Old 03-14-2013, 09:26 AM   #292
dirtysouthjacket
Oddometer: 539
Oh awesome! I totally missed that. That makes it so much faster for me to do this then.
DSJ's Shenanigans
Old 03-14-2013, 09:27 AM   #293
dirtysouthjacket
Oddometer: 539
And you DID NOT do a spacer right? Did you lower the forks in the clamps then?
DSJ's Shenanigans
Old 03-14-2013, 09:28 AM   #294
epicxcrider
Oddometer: 645
I didn't make a spacer. Would have been easy to add, but just decided to try it without and left the clamps at the normal height. Front end seems a tad higher so I might drop them .5" or so.
Old 03-14-2013, 09:29 AM   #295
dirtysouthjacket
Oddometer: 539
Originally Posted by DoWorkSon View Post
So will any Shiver Marzocchi 45mm forks work on this?
There are a set on ebay I was thinking about buying, but not sure... there has been a lot of info thrown out, so it's a little confusing
If they are the same ones I'm looking at they are probably pretty close to you. I think I had to dig a little but the seller looks to be in Yuma AZ. Shipping to you will probably not be that bad. I'm hoping to find something a lot closer to SC to save on the shipping... Good luck!
DSJ's Shenanigans
Old 03-14-2013, 09:31 AM   #296
dirtysouthjacket
Oddometer: 539
Ok, very cool! This is starting to look so easy! Now we need to come up with a cheap option for the rear! If I save enough on the front though, I might just try to sneak in on the group buy for the rear.
Can you tell my first bike was a KLR?
DSJ's Shenanigans
Old 03-14-2013, 09:33 AM   #297
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
You can buy a spacer from moose racing. They come in 2" length so you just cut it in half.
Old 03-14-2013, 11:19 PM   #298
DoWorkSon
Oddometer: 267
So tell me if these would work.... I'm a bit confused and don't know if they will match up.
The forks I'm looking at are:
-12inch travel
-total fork length of 36"
- upper fork diameter 53mm
-lower fork 58mm
-45mm fork tube
-rebound/compression/air bleed screw on both
Just wanna confirm this is close to RXV forks and will work
DoWorkSon is offline   Reply With Quote
Old 03-15-2013, 06:05 AM   #299
epicxcrider
Oddometer: 645
Sounds fine. Pm me a link?
Old 03-15-2013, 07:14 AM   #300
dirtysouthjacket
Oddometer: 539
Originally Posted by Gangplank View Post
If I had to do it now I'd try the YZ450F forks. Don't remember what year is a 46mm. Maybe 2001? A 46 would fit into our fork tubes and work according to the people I have talked to.
You'd have to find a set in decent shape. Prolly doesn't even matter if they are bent because normally the fork tubes bend and the internals are still straight. I had a set that I got off ebay for $125. I was planning to use those before I found the ones on AF-1 for cheap.
Gangplank, you made this statement back on like page 8 or 9. But you didn't state a reason. Was it merely cost that you went with the Shiver? I think later on you mentioned that you were still thinking about trying the YZ even after the shiver swap. Just wondering your reasons....
DSJ's Shenanigans
Times are GMT -7.   It's 08:20 AM.
