Old 08-08-2013, 12:12 PM   #541
NCD
Dirty Hairy
NCD's Avatar
Oddometer: 494
Stock BMW is 60mm, RXV is 100mm, I split the diff with 80mm and it works well. 7.5w Motorex.
NCD is offline   Reply With Quote
Old 08-08-2013, 01:42 PM   #542
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Originally Posted by ERU View Post
Hello guys .
My Ohlins 0.55 springs finnaly came and i will put them on the bike hopefully tomorow. So, i'm 80 kg with riding gear and i wish to have that "plush sensation" anyone talk about.
How much air should i have in the forks and what oil weight ? I'll use Motul since it's the best oil easily available here.
Thx.
When i did mine I went with 100 air over oil as recommended with the forks. If you want it more plus add more air, if you want it more stiff less air & more oil generally works.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 08-08-2013, 04:21 PM   #543
DoWorkSon
Oddometer: 267
That's what I did. Seems to work good for me
DoWorkSon is offline   Reply With Quote
Old 08-08-2013, 09:56 PM   #544
jscottyk
jscottyk's Avatar
Oddometer: 329
Hello guys .
Thx.
Mr. Ed McCoy setup mine with 5wt Maxima Oil at 110mm with 0.49 springs and 25mm preload.
jscottyk is offline   Reply With Quote
Old 08-09-2013, 01:13 PM   #545
ERU
ERU's Avatar
Oddometer: 39
Wink
Many thx.
I just instaled the springs today. My suspension guru used Motul 10w and he let 90 mm air at my request.
I get her to some country roads this afternoon and the improuvement is major but i think i want it more soft so i may remove some oil from the forks first to see how it's going.
The biggest problem i have now it's that i want a good shok for the rear end .
I'm considering a rear shock from a KTM 990. Does anyone try that ? Or any "cheap " alternative to 1000+ squid aftermarket shocks ?
Adventure is not a cable channel.Freedom from the prison of pavement.
The beaten path is for beaten people.Pain is momentary.
Giving up is forever.Rest when you're dead.
WINDRIDER
ERU is offline   Reply With Quote
Old 08-09-2013, 06:25 PM   #546
DoWorkSon
Oddometer: 267
About how much did that revalve/setup from McCoy run you?
Old 08-15-2013, 07:14 AM   #547
epicxcrider
epicxcrider's Avatar
Oddometer: 645
I like my Elka rear shock - was maybe $850? I forget now. Differ t animal though - very sensitive to correct spring and preload.
Old 08-15-2013, 10:09 AM   #548
jscottyk
jscottyk's Avatar
Oddometer: 329
Apologies for the delay in replying. Somehow missed your question.
If I recall correctly it was $450 for parts and labor including springs and re-valve. I'll check the invoice later tonight and confirm.
Old 08-15-2013, 10:10 AM   #549
jscottyk
jscottyk's Avatar
Oddometer: 329
+1
The Elka shock is a great addition along with this fork work.
Old 08-15-2013, 11:48 AM   #550
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
I know where you can order an Elka shock on a discount :-D. Hit me up if you want to order one through the group buy.
I had my forks done through Ed as well. If I recall it was $300 for the labor & revalve + about $120 for the springs & a couple bucks for the spacer, etc.
Old 08-16-2013, 01:44 PM   #551
epicxcrider
Oddometer: 645
I did all those suspension mods and its been a street queen since the move to Seattle. Can't wait to REALLY try it out.
Old 09-23-2013, 12:27 PM   #552
NCD
Dirty Hairy
NCD's Avatar
Oddometer: 494
Happy to report that a thorough beating through CO and UT proves the conversion is a great transformation to the front of the bike!
Old 09-23-2013, 12:42 PM   #553
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Nice!!
Old 09-24-2013, 12:03 AM   #554
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,429
Has anyone found a rear shock brand that can be ordered longer than stock to match the added travel with the Shivers? Elka and Ohlins told me no. Only need 1" at the axle so an extra 1/4"-"3/8" of shock stroke would be good.
I've been running the .95 RT springs for a couple seasons. They are stiff but the .55 were too light for me (255lbs plus gear). RT now has .75 springs. My forks are in at Enzo Racing for a full service, minor valving changes and .75 spring install. Anxious to see how they feel with the changes.
Camel Tank auxiliary fuel tank for F series BMW twins. www.Camel-ADV.com
AT-BZ-CA-CN-CO-CR-CZ-CH-FR-DE-GB-GT-HN-IE-JP-KZ-KR-LI-LU-MX-NL-NI-PL-RU-SV-UA-US
'09 BMW F800GS, '14 KTM 1190 ADV-R
Camel ADV is offline   Reply With Quote
Old 09-24-2013, 05:12 AM   #555
rmhrc628
rmhrc628's Avatar
Oddometer: 2,547
Tt ?
rmhrc628 is online now   Reply With Quote
Times are GMT -7.   It's 04:19 PM.
