Old 07-27-2010, 04:57 PM   #16
MSH
The Salt
MSH's Avatar
Oddometer: 3,219
Originally Posted by radtrinidad
Never been to a Better Homes and Gardens or cook book forum but thanks for showing how narrow minded you are. Too bad you have to share the forum with women. Typical man. Oh wait, did I just stereotype you? How rude!
I'm very sad because you quoted from my fav movie in your sig too. /sigh
Don't get your panties in a knot. Narrow minded? Hey... I did get your better homes and gardens lingo did I not. :-).
~KTM 640 Adventure R~
"Lately it occurs to me what a long, strange trip it's been"
MSH is online now   Reply With Quote
Old 07-27-2010, 07:57 PM   #17
outpostbabu
outpostbabu's Avatar
Oddometer: 202
Great thread ebrabaek! I'm very interested to see how this turns out. I don't know much about carbon fiber, usually when I see it on car hoods and things its unpainted. Is it possible to paint it so that the look and texture of it matches the originally exactly (ie it would be indistinguishable from the original)? And how does the weight compare to the original plastic parts?
http://www.fortunemegastore.com
outpostbabu is offline   Reply With Quote
Old 07-27-2010, 08:10 PM   #18
ebrabaek OP
Oddometer: 4,763
Yes....Sand and paint, just like you would any other piece.
Stocker is 213 grams......New piece is 179 grams...... But it was made with 3 layers of fabric.....2 would have been more than enough, but the new piece will need to be stronger to house switches...plugs..etc. If I had only used 2 layers, which would still have been way stronger than stock, it would have weighed in at about half of the stock piece.
Thinking about trying it????
Erling
Old 07-28-2010, 08:06 AM   #19
Mongo357
Mongo357's Avatar
Oddometer: 153
Question heat shield
Would a few layers of this wrapped around the stock exhaust be enough to act as a heat shield? Looking for a poor man's way to keep the exhaust from burning myself, a tarp, or possibly some soft luggage.
Mongo357 is offline   Reply With Quote
Old 07-28-2010, 08:37 AM   #20
ebrabaek OP
Oddometer: 4,763
Unfortunately not. Although less of a heat cunductor than SS.....CF will still transmit too much heat if mounted on top of the SS. A CF shield 1/2 to 1 inch away on the other hand, would be sufficient.
Erling
Old 07-28-2010, 08:48 AM   #21
ricohman
Marinoni man
ricohman's Avatar
Oddometer: 1,981
Is the CF part larger than the original since its not actually a mold?
ricohman is offline   Reply With Quote
Old 07-28-2010, 08:55 AM   #22
ebrabaek OP
Oddometer: 4,763
Yes...by 1 1/4mm.......In this application...not an issue.
Erling
Old 07-28-2010, 08:58 AM   #23
ebrabaek OP
Oddometer: 4,763
Finished.......After 1 hr of finish sanding........It was finally ready to coat with a of the shelf automotive spray lacquer, with a uv inhibitor......
After two layers of lacquer......
And finally .... next to original piece......
In a few minutes.....on the bike......
Erling
Old 07-28-2010, 09:18 AM   #24
ebrabaek OP
Oddometer: 4,763
Finally on the bike.......
Finished......and on the bike.......
So all in all.....4.5 to 5 hrs of labor......... It is an easy project for the first timers........material under US$50........ In closing..... This piece will be build upon in a few weeks. The part I wanted to promote.....is how easy this particular project is/was. Even for the total beginner......double the labor....and you still only have 10 hrs in it. Next project is a CF/Kevlar honeycomb skidplate.....But that`s another story..... Post up questions....there are many material questions....I`m sure.....I`m here to help. Off for a test ride........
Erling
ebrabaek screwed with this post 07-28-2010 at 09:24 AM
Old 07-28-2010, 10:31 AM   #25
OverlandHank
Loves to Farkel
OverlandHank's Avatar
Oddometer: 59
Very Nice work!
2010 BMW F800GS
2009 Suzuki DL650 Vstrom
2004 Honda VT750 Aero
OverlandHank is offline   Reply With Quote
Old 07-28-2010, 11:09 AM   #26
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Not that I expect it to be significant, but have you had a chance to see of there's any weight difference between yours and the OEM part?
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 07-28-2010, 11:44 AM   #27
CrazyMike
***42***
CrazyMike's Avatar
Oddometer: 924
David,
You missed a spot. Check post #20 (the green text).
Ebrabaek,
Very cool...keep up the good work and keep showing us!!!
Mike
1999 BMW R1200C
2009 BMW F800GS
WANTED: Kawasaki ZRX 1200R
CrazyMike is offline   Reply With Quote
Old 07-28-2010, 12:00 PM   #28
LewisNClark
LewisNClark's Avatar
Oddometer: 1,060
Thanks for taking the time...interesting project
Originally Posted by ebrabaek
Finished......and on the bike.....Next project is a CF/Kevlar honeycomb skidplate.....But that`s another story..... Post up questions....there are many material questions....I`m sure.....I`m here to help. Off for a test ride....
Erling
Very interesting project – thanks for taking the time and harrassment..
Questions:
1)Could you cut and paste a corrected list of supplies I made below? (know some of it is wrong, or duplicated)
2)Could you make a modifed list for making a bash plate ? (ie. Stronger material)
3)How high a risk of ruining the OEM plastics with making the mold ?
4)Wouldn’t the skid/bash plate be a safe first project since if you screw it up a little and can’t see, it your safe.
(Could you check my list of supplies and cut and paste corrected list for anyone else's interest).
Supplies:
Silmer 249 – Polyester (USComposites)
Epoxy (Brand ?)
Resin (Brand ?)
Automotive Spray Lacquer (with UV inhibitor)
Twill 5.7 oz Cloth (Brand?)
Sand paper – 80 grit (rough sanding)
Sand paper – 220 grit (finish sanding)
Black Electric Tape
Plastic Cups for mixing
Wax (with high carnuba wax) (is that just car wax?)
Parafilm (nold release spray?)
Resin with wax - ???
Surfacing wax Modifier – C
Tools:
Dremmel
Paint sprayer/compressor (needed ?)
Brushes (?)
The Trip: http://www.advrider.com/forums/showt...ht=Lewis+Clark
Link to 4,000+ pictures of Lewis & Clark Trail:http://lewisandclark.smugmug.com/
LewisNClark screwed with this post 07-28-2010 at 12:12 PM
LewisNClark is offline   Reply With Quote
Old 07-28-2010, 12:40 PM   #29
ebrabaek OP
Oddometer: 4,763
Questions:
Absolutely.
The skid plate will feature a little different layup...Since it will be a structural item. There is a bit more to that, than I can paste here....But I will start it soon. That will be a really interesting project.
None..... Well... I had a little raised plastic because I used polyester....but it has since subtracted, and is almost not apparent. I would say use epoxy on plastic.... There is no conflict between the two materials.
.....One could say yes.....That construction ( skid plate) most of the time will be in building a styroform mold that suits your nature.... That`s the complicated part......The extra layup is a piece of cake. And I don`t plan on sanding it.
Supplies:
Carbon Fiber Cloth.....5.7 oz twill http://uscomposites.com/carbonpage.html
Silmar 249 – Polyester (USComposites) http://uscomposites.com/polyesters.html
Epoxy (Brand ?) ...http://cgi.ebay.com/EPOXY-RESIN-CRYS...item483544bccc
Automotive Spray Lacquer (with UV inhibitor).....any will do...Key word uv protection. I used dupli color clear coat finish 8 oz. cost around $ 6
Sand paper – 220 grit (finish sanding) then 800 grit and 1200 grit prior to last two coats of lacquer.
Black Electric Tape
Wax (with high carnuba wax) (is that just car wax?) Mirror glaze and Prize Driscoll http://uscomposites.com/moldrelease.html
Parafilm (mold release spray?) I use the above for polyester ,and this for epoxy..
http://cgi.ebay.com/MOLD-RELEASE-FIB...item483a24fc63
Resin with wax - ??? Some polyester resins have the surfacing wax mixed in... I don`t use them.
http://www.shopmaninc.com/solvents.html
Tools:
Dremel
Paint sprayer/compressor (needed ?) No
Brushes (?)
There are several places to get the resin etc.... But above are the links to where I get them... Don`t mind the fleabay. That is just a cheaper way to get it...Than their main website. They know their stuff.
Erling
Old 07-28-2010, 01:05 PM   #30
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Originally Posted by CrazyMike
David,
D'oh! Thanks Mike.
David
David
--Curly
Times are GMT -7.   It's 11:35 AM.
