Old 07-28-2010, 09:31 PM   #1
alohagirl OP
alohagirl's Avatar
Oddometer: 103
Question Oxford Heated Grips remove/reinstall
Have have Oxford Heated Grips installed on my handlebars.
They work great, and I recommend this product highly, however:
I want to change my handlebars.....
So, does anybody out there know how to remove and reinstall the oxford heated grips? ... Is it even possible?
How do I remove the glue (I'm not sure what kind it was, it came with the grips)?
I guess the worse-case scenario is I have to suck it up and buy new heated grips for the new bars.
If that happens: Anybody out there want to buy a pair of Renthal Fat Bars RC Enduro bend with Oxford heated grips pre-installed? LOL
Thanks in advance for any advise.
alohagirl is offline   Reply With Quote
Old 07-29-2010, 02:52 AM   #2
JensEskildsen
Oddometer: 1,041
Sometimes, spraying wd40 or simular under the grips, between the grips and handlebar, can make it a lot easier.
JensEskildsen is offline   Reply With Quote
Old 07-29-2010, 06:21 AM   #3
TonyKZ1
TonyKZ1's Avatar
Oddometer: 718
One of the recommended ways to do it is to get them very hot, and then using a towel or gloves to protect your hands slowly try to twist them, depending on what adhesive you used to mount them, they should come loose. I've removed mine this way when I bent my handlebars and had to replace them.
Tony
1997 Yamaha Seca II - mostly stock, Oxford Sports Style Heated Grips, Barkbusters Blizzard Cold Weather Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page.
TonyKZ1 is offline   Reply With Quote
Old 07-29-2010, 10:41 AM   #4
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,857
I can tell you 10 things that don't work, cause I tried 9 of them and the 10th destroyed the grips.
I guess my adhesive (golf grip tape) was probably not the best stuff to use, if being able to remove them easily was a possible outcome. The good is, tho, that they didn't budge for the 3 years I had them on.
Live and learn.
swingset is offline   Reply With Quote
Old 07-30-2010, 11:44 AM   #5
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,927
If you used the cement that came with them they are not coming off easily, and possibly not at all intact.
First thing I would try is to hook them up to a 12v power supply and leave them on for a while. I see you're in CA, do this during daylight so the sun can help with the heating process.
Remove the clutch and brake levers so you have room to work. Grab a long but thin flat head screwdriver. See if you can get it under the grips at all, oxford grips are not as flexible as others so this may prove difficult. If you can manage to just get the screwdriver in at least half way to 3\4 in then could yourself lucky. Pry a little bit just to get the grip flexible, then quickly remove the screw driver, shove in the little red straw from a cna of WD40 and spray inside, a lot.
WD 40 combined with the heat should allow it to spread to all the nooks and crannies, hopefully you will be able to twist the grip off at this point.
Do the left side first. Be extra careful with the right side. You might want to find a used throttle tube on ebay and order it in advance just in case.
Next time DO NOT USE THAT CEMENT and instead use the extra hold hairspray.
HaChayalBoded is offline   Reply With Quote
Old 06-15-2013, 12:11 PM   #6
Tenere_PDX
Tenere_PDX's Avatar
Oddometer: 2
So - did it work?
I am in the same boat. My brother fell over and twisted my bars. I am going to try all of these suggestions today?
Tenere_PDX is offline   Reply With Quote
Old 06-15-2013, 01:51 PM   #7
JTT
JTT's Avatar
Oddometer: 1,530
As I remember, the Oxford glue is basically Superglue or CY. Acetone will break down CY, as will even acetone fumes. I remember ungluing tires from RC cars that are glued on with CY. If you left them overnight in a sealed container with a bit of acetone in the bottom, the fumes would be enough to break the CY bond. Never tried it with grips though, I'd test on a small place first as acetone will melt some plastic,
JTT is offline   Reply With Quote
Old 08-24-2014, 05:03 PM   #8
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,479
Old thread. Same boat. End result, destroyed the grips. Same techniques I've used on regular grips did not work on these Oxford grips. That glue they use is more like epoxy. Good news is the sport pattern I had on them had gotten warn down over years of use, so I guess replacing them was due in time.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 08-24-2014, 05:59 PM   #9
DonM
Do-dah Do-dah
DonM's Avatar
Oddometer: 317
Super glue is pretty good to 500F and grips will likely be toasted by then.
You will have to physically break the bond which won't be easy as there is not much play between bars and grips but give it a try and report back!
Best regards,
Don M
DonM is offline   Reply With Quote
Old 08-24-2014, 09:44 PM   #10
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,664
I used the glue that came with them and they come loose when ever I set them on high.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Times are GMT -7.   It's 12:22 AM.
