Old 06-28-2013, 05:36 PM   #181
WF_Jester
WF_Jester's Avatar
Oddometer: 276
Question Advice....
Erlin,
I need/want to make a carbon fiber sheet about 2' x 2' the kicker is the thickness it needs to be about 1/8" thick because of how it will mount and needing to have countersunk holes for flat head screws. Can you give me any advice and tell me about how many layers of fiber I need to achieve that thickness?
De inimico non loquaris male, sed cogites
2010 BMW F800GS
1965 Panhead Chopper
2006 HD Roadking
2005 Softail Standard - Stolen
1981 Suzuki GSX 750 - Burned
1977 Yamaha IT 400 - Burned
1974 Suzuki TC 100 - Sold
WF_Jester is offline   Reply With Quote
Old 06-28-2013, 05:59 PM   #182
ebrabaek OP
Oddometer: 4,824
Originally Posted by WF_Jester View Post
Erlin,
Sure, but first, What is it to be used for...... Structural.....???? If Structural I would go with 12 oz fabric. 3-4 layers should do it. Thickness actually much depends on how much resin you have in there. Most people will lay up with more resin than the 30/70% rule. If i were to make a plate, I would get two pieces of glass from the depot (2x2 feet) treat them with release agent, and simply lay up the sandwich in between. Makes for a nice smooth finish, and you can carefully squeeze it to an exact thickness of 1/8 inch. Or you can just wing it..... Be aware of the common mistake to brush too much resin in the middle, and the piece is now thicker in the middle, than the edges. Two glass plates control that as well. Hope this helps. If you only have 6 oz fabric, then 5-6 layers.
Erling
Old 06-28-2013, 06:32 PM   #183
WF_Jester
WF_Jester's Avatar
Oddometer: 276
Not sure what you mean by structural. It will be about a 12" x 6" X .125" piece that will be supporting about 7 pounds of weight about the same size but 3" thick. The 3" and .125 being parallel to each other. I figure that it will be plenty strong. The glass is a wonderful idea. This is just the first step of a larger project. More details and questions to follow if I can make a simple 1/8 plate.
2010 BMW F800GS
2006 HD Roadking
Old 06-28-2013, 08:21 PM   #184
ebrabaek OP
Oddometer: 4,824
By structural, I mean does it need to carry a load. Composites are very strong, but flexible. I'd go with the 3-4 layers, of 12 oz, or 5-6 of the 6 oz. 3 layers of release agent on the glass. squeeze the top glass down to achieve 1/8 inch thickness, then leave it alone to cure.
Erling
Old 06-28-2013, 09:40 PM   #185
slowpoke
slowpoke's Avatar
Oddometer: 103
Beautiful! But I'll stick with metal.
slowpoke is offline   Reply With Quote
Old 06-29-2013, 06:19 AM   #186
ebrabaek OP
Oddometer: 4,824
Thanks...
Erling
Old 07-01-2013, 01:05 PM   #187
WF_Jester
WF_Jester's Avatar
Oddometer: 276
Does the resin have to have contact with air to harden. How do you figure out how much resin to use. I have an volume of about 9ci not counting the carbon fiber that comes out to about 5 fl ozs of resin once again without taking the carbon fiber displacement in to account. You mentioned a 30/70 ratio earlier which percent is resin?
2010 BMW F800GS
2006 HD Roadking
Old 07-01-2013, 04:01 PM   #188
ebrabaek OP
Oddometer: 4,824
At this point, so as not to turn this into a different build/how to, I think you need to read up a little. I have lots of threads here,taking you step by step. Click on my username, and navigate to the "all threads started by ebrabaek" and start reading. This is something you need to do before proceeding. I would like you to start a new thread, rather than post it in here. If you dont like that, then post it in here...
http://advrider.com/forums/showthread.php?t=603891
Here is what searched yielded.....
http://advrider.com/forums/search.php?searchid=25717235
This is NOT meant to put you off. I Don't work like that, just to organize this in the appropriate thread. Resin is 30%....cloth is 70% by weight.
Erling
Old 08-12-2013, 05:33 PM   #189
speed_racer
speed_racer's Avatar
Oddometer: 707
Hey Erling,
great thread again! this looks like an awesome bashplate!
I was reading in an early post you said Kevlar had great abrasion and carbon had great stiffness,
So was it just the look or another reason why you put the outer layer on the bashplate in CF? because wouldnt it be more durable to put the kevlar on the outside?
speed_racer is offline   Reply With Quote
Old 08-12-2013, 07:00 PM   #190
ebrabaek OP
Oddometer: 4,824
Originally Posted by speed_racer View Post
Hey Erling,
You got it right....... It is a bit easier to manage CF on the outside, than K-39. You see, when you start bashing, and scrapink the K-39, as top layer, it frays, and as it is hard to sand, or grind away, you end up having a bash plate looking like cotton ball hanging down. Plus the yellow K-39 finish is not good looking.... imho. So I put a CF diaper on it.....
This way with CF on top the K-39 does not fray in comparison. Looking at it.... I do have several yellow scars protruding though......
Erling
Old 08-12-2013, 08:32 PM   #191
speed_racer
Oddometer: 707
arr right! nice one.. so its easier to patch up some CF ;)
Nice work.. I might start working on some CF stuff once i have the garage space.. I cant believe the finish you are getting on it, it looks very cool!! I thought you would of had to make a fiberglass mould then make the CF for that type of finish but apparently not..
Old 08-12-2013, 09:08 PM   #192
speed_racer
Oddometer: 707
Im just Curious, have you had any experience with the West 105 epoxy products? It seems to be the only thing the Australian suppliers carry...
http://www.carbonfiber.com.au/category3_1.htm
Cheers :)
Old 08-13-2013, 05:54 AM   #193
ebrabaek OP
Oddometer: 4,824
You can do that as well. The sort of raised , uneven surface of the raw cured fiber, has to be sanded, but then it is as glossy as your hands want it to be.
Erling
Old 08-13-2013, 06:01 AM   #194
ebrabaek OP
Oddometer: 4,824
Cheers :)
I have no direct experience with the 105, but as it is a marine grade stable product, it is available around the world. As such less emphasis is made in the boutique flavors, like transparency. It takes the alchemist a bit more trouble to create polymers that are clear, and stands up to UV bombardment. The best thing for you to do, is have a look at the transparency of the 105...... if it is not too dark for you, then ask someone who has used it, unpainted, how it stands up to UV rays.
Erling
Old 08-13-2013, 08:41 PM   #195
speed_racer
Oddometer: 707
Thanks heaps, I'll do that..
Times are GMT -7.   It's 07:36 PM.
