Old 08-02-2010, 10:50 AM   #1
67L48 OP
Dangerously Incompetent
67L48's Avatar
Oddometer: 46
Headlight Wiring ?: 2004 KTM 450 EXC
2004 450 EXC
Headlight is all stock and I do have a wiring diagram.
I am trying to go from the stock switch to an aftermarket DS master switch.
Stock bulb has 3 prongs for ground, low and high. However, KTM factory wiring only uses the ground and low. That much I know.
The stock harness at the bulb has two wires: white and brown. I believe that brown is the ground and white is low beam.
The white wire goes into the factory light switch next to the digital meter. A yellow wire leaves the switch and goes into the factory wiring "path." I thing the yellow wire goes to the stator (generator).
The aftermarket switch has 3 wires that it calls Headlight Main (black), Low beam (white), and High beam (blue).
So, how do I connect it all together?
Here's my guess:
Connect the black "Headlight Main" to the factory yellow wire on the "battery side" of the factory headlight switch.
Connect the white Low Beam wire to the lightbulb prong where the factory white wire was connected.
Connect the blue High Beam wire to the lightbulb prong that was previously bare/open.
Leave the brown factory ground wire connected as is.
Is that correct? Or should I be connecting the black "Headlight Main" directly to the battery? Something else?
67L48 is offline   Reply With Quote
Old 08-02-2010, 12:40 PM   #2
Tail Gunner
Life is Good !!!
Tail Gunner's Avatar
Oddometer: 1,601
Your guess is right. The headlight is AC and should not connect to the battery (which is DC). It gets its power from the AC stator. This link might help you understand the options with stators
http://ktmtalk.com/index.php?showtopic=395998
Here's my guess:
Drew
06 BMW HP2 - BLUE
94 Goldwing - BIG RED
06 BMW RTP - BLACK & WHITE
Meet & Greet Thursdays 6pm
Tail Gunner is offline   Reply With Quote
Times are GMT -7.   It's 03:51 PM.
