Old 08-15-2010, 01:08 PM   #46
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,069
Plaka: Duly noted, thanks :)
Which kind of tyrepressures do you run? Do you follow the manual, the tyre maker or?
Old 08-15-2010, 02:54 PM   #47
Jasper ST4
Guest
Oddometer: n/a
Originally Posted by Plaka
Carbs tip to the inside 15 degrees or so---they do not sit strait up and down.
Haven't heard that one before. I've always done mine vertical, seems logical since it involves float levels.
Old 08-15-2010, 03:57 PM   #48
TimTowtdi
TimTowtdi's Avatar
Oddometer: 242
+1
I'd be interested where that came from. Why tilted inside? Why not outside?
TT
TimTowtdi is offline   Reply With Quote
Old 08-16-2010, 12:16 AM   #49
Plaka
Brevis illi vita est
Oddometer: 4,608
Word has it to run slightly higher pressures in the modern tires. Maybe 34 front. 38 rear. I max out the rear if I have a heavy load on. Ask around on the airheads list.
Old 08-16-2010, 12:21 AM   #50
Plaka
Oddometer: 4,608
Originally Posted by TimTowtdi
+1
TT
'cause it's supposed to be to the inside? On the /5 the carbs won't fit right. I got the bit of info from one of two sources, and long ago. In my minds eye I'm seeing a pic in the manual (factory manual) showing the correct angle. Unfortunately that manual is burried at the moment. Anyway, given I am running the same basic carb on the /7 I keep doing it, although the fitting seems to acomodate all sorts of things. I doubt the float level is an issue, especially if the level setting accounts for it. It may (totally guessing) have more to do with the cable angles.
Old 08-16-2010, 12:02 PM   #51
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,247
+1
I view the carbs from behind and judge vertical in reference to the cylinder cooling fins.
Renner is offline   Reply With Quote
Old 08-16-2010, 12:21 PM   #52
DaneKSJ
Oddometer: 3
Hejsa
Så jeg er ikke den eneste danske boxer-ejer, der hænger ud her.
Tillykke med /6'eren. Kører selv rundt på en 30-årig R100RS.
Hvor i landet kører du?
DaneKSJ
Tired RS...
DaneKSJ is offline   Reply With Quote
Old 08-16-2010, 12:34 PM   #53
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,132
DaneKSJ
No shit.
Old 08-16-2010, 12:41 PM   #54
Jasper ST4
Guest
Oddometer: n/a
So is he for or against airheads?
Old 08-16-2010, 01:19 PM   #55
KaiWE
KaiWE's Avatar
Oddometer: 30
DaneKSJ
Translates to:
So I'm not the only danish boxer owner that hangs out around here. Congrats with the /6. Am riding a 30-year old R100RS myself. Where in Denmark do you ride?
If anybody was wondering
'57 BSA DBD34 - '57 Lambretta Li 150 Series 1 - '80 Gilera 50 TS - '84 Moto Guzzi 850 T5 - '04 Monkey Bike
KaiWE is offline   Reply With Quote
Old 08-16-2010, 01:32 PM   #56
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,069
I ride commute most of the time around Esbjerg, I don't really tour around Denmark, I prefer trips to other countries for biking :)
Old 08-16-2010, 04:10 PM   #57
mykill
odd
mykill's Avatar
Oddometer: 1,166
I'm with Plaka on this one. I was taught to line up the front dome screw between the first two full fins to the inside of the spark plug. That gives them an ever so slight tilt to the inside. I was taught this 20 years ago by my BMW Guru, a factory trained BMW guy. I'm sticking with it.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 08-16-2010, 04:42 PM   #58
Jasper ST4
Guest
Oddometer: n/a
Let me guess, and he did it because he was taught that way?
Old 08-16-2010, 06:04 PM   #59
TimTowtdi
TimTowtdi's Avatar
Oddometer: 242
Well, I set mine straight up and down, judged by standing about 10 feet behind the bike. Works for me. (I won't say where I was taught that, though )
TT
Old 08-16-2010, 09:41 PM   #60
mykill
odd
mykill's Avatar
Oddometer: 1,166
More than likely. But he, many others and I have had many happy years and miles under our belts.
Times are GMT -7.   It's 08:25 AM.
