08-17-2010, 05:07 AM
#61 | |
Oddometer: 2,579
Airhead stuff, tools, camping stuff, riding gear for sale/trade. http://www.eskimo.com/~newowl/BMWPARTS.htm |
08-17-2010, 05:23 AM
#62 | |
Guest
Oddometer: n/a
08-17-2010, 05:44 AM
#63 |
combustophile
Oddometer: 1,569
It would be nice to know the rationale behind tilting.
No doubt the Bings function adequately some few degrees past vertical but it appears less than optimal. If the tilt is to accomodate cable interface then I manage fine without it. A good technical school will teach 'why' things are done beyond 'what' is done. This helps technicians think for themselves. |
08-17-2010, 07:04 AM
#64 |
odd
Oddometer: 1,093
On the level
It's a good thing none of us have to lean our bikes in turns, otherwise they wouldn't run at all with all that tilting.
Never underestimate the laxative properties of motorcycling. |
08-17-2010, 07:28 AM
#65 | |
Guest
Oddometer: n/a
08-17-2010, 07:29 AM
#66 |
combustophile
Oddometer: 1,569
...ever seen in-cockpit footage of Bob Hoover performing aerobatics with an open tumbler of water, no liquid spilled?
There's a whole lot more sloshing going on in our float bowls. |
08-22-2010, 04:40 AM
#67 |
XSessive!
Grease pumps, do you use them? I haven't seen the one BMW shows in the pictures, only pumps that goes onto nipples.
Are they available? Are they even needed? Alternatives? Want to grease the swingarm and centerstand pivots. |
08-22-2010, 05:20 AM
#68 | |
Guest
Oddometer: n/a
08-22-2010, 05:24 PM
#69 | |
Oddometer: 2,579
Push greasers are cheap anywhere chainsaws are sold. They are used for lubing the nose sprockets on bars. Mine cost less than $8 a couple months ago and is made in Germany. Looks like decent grease in it but you can always reload it with whatever grease you want to obsess over. On the later bikes the push greaser fittings vanished. They are a very expensive part compared to a simple bolt. You have to tear the part down to lube it. This is lots of work and gives a poor lube job. Lots of the grease just rubs off on assembly leaving voids. With flush greasing you get a complete grease fill and just have to wipe up the old stuff. You use plenty to get a good flush. I will be making a proper flush grease pivot for the brake pedal on my /7, the ones from the /5 won't fit and pivoting on bolt threads, even with a steel bushing, is BS. I hada kickstand that did that and at 65K, even with a grease fitting, the pivot was shot. (granted, it takes huge pressures) On big industrial equipment the Zerk fittings on all the bearings and whatnot are replaced with a barb fitting and a slender plastic tube. All the tubes come together at a central point at a greasing manifold. When greasing is required (often daily or more often) everything gets flush greased at once from a central point.
08-30-2010, 08:18 AM
#70 |
XSessive!
I have a "hard" time understanding the various fittings and what you are trying to get into my head. Somehow my "Thank you" reply got lost :S
Anyway, thank you for the quick and spot on answers every time! Not the end of questions though. Reading snowbums site he refers to some special tools for doing a spline lube. Mostly thinking about the 27mm socket, as I do not have access to a lathe to turn one down. Are there any places to get some already made for this purposed or am I doomed to sanding one down? Which grease types do you guys use? Want to use the mix snowbum suggests if I can get the types. |
08-30-2010, 08:24 AM
#71 | |
Guest
Oddometer: n/a
I use Hi-temp Permatex anti-seize for the splines. Not that it needs to be hi temp, it's what I had for the exhaust nuts. It's been working for 30 years so far. |
08-30-2010, 08:29 AM
#72 | |
XSessive!
08-30-2010, 08:58 AM
#73 |
Guest
Oddometer: n/a
If it ain't broke, don't fix it. That's as old school as you can get. I don't know about the copper, a high quality high temp anti-seize is what you want. Loosening the nuts and re-tightening once a year doesn't hurt. A wrench for that is one of the few special tools that I have for the beemer.
08-30-2010, 09:19 AM
#74 | |
Lost In Place
Oddometer: 15,990
Look around...
08-30-2010, 12:00 PM
#75 |
Coyote's Brother
Oddometer: 3,299
You can easily trim down a socket using a bench grinder.
It won't be pretty but it'll work just fine.
Hawkdude Hate rots the pocket that carries it. |
