Old 08-30-2010, 01:33 PM   #76
Plaka
Brevis illi vita est
Oddometer: 4,610
Originally Posted by LasseNC
Is coppergrease sufficient for the exhaustnuts? I saw "ZOA"s ridereport, she had bought some kind of flanges that bolt together. Seemed like a cool solution, albeit not vintage.
Use high temp anti-seize. Often these are graphite based. I have a 9 oz. container from Fel-Pro. Good to 2400F. Comes with a nice applicator brush in the lid. Cost maybe 6USD
I use a quality HP moly grease on the wheel bearings, whatever on the rest, often the moly grease that's in the gun, sometimes Mobil 1 Synthetic 'cause I happen to have a tub and it works well in the cold and it's is very water resistant---like for throttle cams and under heated grips.
Cleaning stuff well before ffresh lube or anti-sieze is as important as the lube. Use a brass hand brush on the made and female exhaust nut threads. Clean the inside of the head exhaust spigot really well, get the carbon off, and then apply a light film of silicone grease----and clean the outside of the header tube where it goes in . Then the exhaust always goes together nicely.
Old 08-30-2010, 01:40 PM   #77
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,075
Will do sir!
Today I localized some odd "clunks" from the forwheel, the wheel had quite alot of sideplay, so new bearings are in order! Reading up on the bearing tech articles on Duanes site as of now :)
Old 08-30-2010, 02:30 PM   #78
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,208
Will do sir!
Are the bearings shot or just maladjusted?
Old 08-30-2010, 10:27 PM   #79
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,075
I am getting a "CLUNK" and other sounds sometimes, when the wheel is turning, quite loud.
Old 08-30-2010, 11:47 PM   #80
Plaka
Oddometer: 4,610
Someone might have left a wrench or something inside the tire when it was mounted. These can make "other sounds". One time a small cat toy was found in a tire. Apparently kitty had batted it in there when the tire was partially mounted on the floor. The guy swore his wheel played "twinkle twinkle little star" at low speed. The forum thread got pretty wild before it was sorted out.
Old 08-30-2010, 11:50 PM   #81
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,075
Jesus :) Well, ordering bearings anyway, at the price they are it would be ludacris not to get them while ordering other parts anyway :)
Old 08-30-2010, 11:58 PM   #82
Plaka
Oddometer: 4,610
The same bearing is used a number of places. So an extra new one is never a bad thing.
Save the old races. Good to press the new in with and certain other little projects.
They are standard bearings made by all the big players, SKF, FAG, etc. Get the numbers off them and you can pick them up at any bearing house.
Old 08-31-2010, 12:05 AM   #83
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,075
Wouldn't it be simpler to do a ballbearing conversion then? Seems to take the whole "preload" thing out of the equation. Yeah the bearing might not last 5 mill. miles, but I am never reaching that on one set of bearings anyway :)
Edit:
Forget it, if it aint broken don't fix it, just my mind wandering. Sticking with the original setup ofcourse :)
Old 08-31-2010, 12:16 AM   #84
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
Lassen,
Do have a shop manual for your bike?
If you don't have one, it would pay dividends for you to acquire one and if you have one, you should take time to read through it.
Just a suggestion....
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 08-31-2010, 12:18 AM   #85
Plaka
Oddometer: 4,610
Edit:
There are many different kinds of ball bearings. Mostly it has to do with the thrust axis through the balls. You want to select one appropriate for the application, in the correct grade, and work out the correct preload.
There is a reason angular rollers are used. look at your car and you will see them again.
Old 08-31-2010, 12:19 AM   #86
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,075
Originally Posted by mymindsok
Lassen,
I do. I just have alot of questions that I don't think is answered in the manual.
Old 08-31-2010, 12:20 AM   #87
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,075
Yeah I know, it's just that my old AJS also used conical roller bearings, and a popular conversion there is to ballbearings, hence my thought of simplicity.
Old 08-31-2010, 12:28 AM   #88
Plaka
Oddometer: 4,610
If it is not answered in the manual, then you should not be asking it! Do not even THINK it. Verboten! They diddn't writee the book for you to go getting all creativee with shit.
BTW, you really also want the real factory shop manual, not just a Clymer or Haynes.
Old 08-31-2010, 12:29 AM   #89
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,075
Thats the one I have.
Old 08-31-2010, 12:38 AM   #90
Plaka
Oddometer: 4,610
Excellent. now go up the board and write 350 times:
"My airhead is not a POS AJS
My airhead is not a POS AJS"
Times are GMT -7.   It's 06:05 AM.
