Old 08-25-2010, 03:48 PM   #106
Kilo Sierra
Kilo Sierra's Avatar
Oddometer: 189
Thanks Lennie...
I will.
ks
Kilo Sierra is offline   Reply With Quote
Old 08-25-2010, 03:53 PM   #107
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,558
Talking holier than
Originally Posted by Hookalatch
... you only need a 4 holer.
teehee...he said 4 holer!
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 08-25-2010, 04:53 PM   #108
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 810
Look at your stock left side sprocket. If it only has 4 evenly spaced holes you only need a 4 holer. My 2007 left side sprocket only has the 4 holes.
Chuck
Great advise...!
Ralf Wilkowski
Been there - already forgot about it...!
Follow my Journey, pursue insanity:
www.itwasnotme.com
signit98 is offline   Reply With Quote
Old 08-25-2010, 09:38 PM   #109
TrainedChimp
Consistently wrong
TrainedChimp's Avatar
Oddometer: 185
Can anyone tell me what I should torque the cam sprocket bolts to?
I got the install done tonight, itís pretty fiddly getting the old sprocket out and the new one in especially without dropping anything into the engine. Everything went pretty well I followed this guide posted by someone earlier. He mentions turning the rear wheels to align the tab on the new cam sprockets I didnít need to do that, you can rotate the slot on the cam side instead, it moves very easily with a screw driver. Now that I am mostly done everything, thankfully, still lines up; TDC mark, cam arrows out pointing to the same spot on the chain, valves slack at TDC. I did rotate the rear wheel after the cams were on and the only thing concerning it Iím hearing a click from the right hand side when manually rotating the rear wheel, I think Iím hearing the valves on that side Ė donít remember if it was doing that before or not. All I need to do now is to final torque the cam sprockets and put the crash bars and tank back on.
I also checked the valves while I was in there and they were still in spec.
"Fools congregate."
TrainedChimp is offline   Reply With Quote
Old 08-25-2010, 09:52 PM   #110
lightfighter
where does this go?
Oddometer: 2,290
Originally Posted by Sergiok
Slacker!
i would have let him put mine on, but i think he was goofing off up in alaska or something.... go figure.
lightfighter is offline   Reply With Quote
Old 08-25-2010, 10:32 PM   #111
Sergiok
Underwater Basketweaver
Sergiok's Avatar
Oddometer: 181
No idea about the clicking but one thing for sure, after all is said and done with the chain/sprocket/etc and just before you put the spark plugs back in, turn the engine over by hand and make sure EVERYTHING is as it it should be (rotates correctly, etc). I think one guy on the PP board had an issue where he was perhaps one tooth off and had to start from scratch. The last thing you want to do is err one tooth off then fire the engine up and have it grenade a split second later!
'05 R1200GS
'08 HP2Sport
Sergiok is offline   Reply With Quote
Old 08-25-2010, 10:46 PM   #112
TrainedChimp
Consistently wrong
Oddometer: 185
Yep, everything rotates fine, turned the rear wheel quite a few times and everything still lines up; TDC mark, cam arrows out and pointing to the same spot on the chain, valves closed at TDC - checked both sides. I think it's all good.
"Fools congregate."
Old 08-25-2010, 10:48 PM   #113
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 810
Factory spec for the Camshaft Sprocket Bolt is 65nm... I usually clean the bolt and the thread with carb cleaner and then use a dab of loctite.
As for the clicking, you are likely hearing the valve train... if everything rotates freely and you don't feel anything hitting (i.e, Valve/Pistons), all should be well.
Now tighten those bolts and have fun!
Ralf Wilkowski
www.itwasnotme.com
Old 08-25-2010, 10:49 PM   #114
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 810
Yeah, kick a man for having some fun... I see how you are!
Ralf Wilkowski
www.itwasnotme.com
Old 08-26-2010, 01:03 AM   #115
lennie
Oddometer: 181
Mag00,
No you were not duped. I would never infer that.
From the photos I would say you just got an early set is all.
lennie is offline   Reply With Quote
Old 08-26-2010, 09:07 AM   #116
mag00
Outa Control Dave
Oddometer: 422
No not you Lennie, I thought maybe RFK just sent what was on their shelf. Old batch or not if I only need 1 with 5 holes then these will work.
2012 Ducati Multistrada
08 SE Ultra,
2012 Triumph explorer 1200
09 R1200GSA
IBA #25226
mag00 is offline   Reply With Quote
Old 08-26-2010, 09:17 AM   #117
TrainedChimp
Consistently wrong
Oddometer: 185
Signit98, thanks. Didn't use loctite becaue I already had most everything back together and didn't want to pull the bolts out again.
Bike is purring like a kitten.
"Fools congregate."
Old 08-26-2010, 09:19 AM   #118
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,558
...but do they work?!!
Old 08-26-2010, 04:32 PM   #119
TrainedChimp
Consistently wrong
Oddometer: 185
I only got to ride for about 30 minutes today. Bike sure seems smooth, I don't feel like I'm lugging the engine giving it gas in the low 3k rpm range anymore and the mid 4ks seem less vibey than I remember. That was definitely a short test though. So far so good. I don't have any regrets about buying them.
"Fools congregate."
Old 08-26-2010, 05:47 PM   #120
Sergiok
Sergiok's Avatar
Oddometer: 181
Do you have an aftermarket can? A Dobeck/Wunderlich or other type of controller on the bike?
'05 R1200GS
'08 HP2Sport
Times are GMT -7.   It's 06:41 PM.
