Old 08-26-2010, 09:11 PM   #121
TrainedChimp
Consistently wrong
TrainedChimp's Avatar
Oddometer: 185
Originally Posted by Sergiok
Do you have an aftermarket can? A Dobeck/Wunderlich or other type of controller on the bike?
Me? No, I don't have anything like that. I have done Steptoe's CCP jumper trick and I have Booster plug.
"Fools congregate."
TrainedChimp is offline   Reply With Quote
Old 08-28-2010, 04:12 AM   #122
lennie
Oddometer: 181
I have good news.
I went to visit my machinist friend Brian today and used his mill to drill the locating pin holes with a 3 mm carbide drill.
In measuring a sample of 12 sprockets the size ranged from 2.91 mm to 2.93 mm.
This along with the loctite securing the pins explains the effort required to remove the pins with a drift.
After drilling the holes they measured 2.98 mm to 2.99 mm.
I have calculated the I have removed between 1.6 thou and 2.1 thou from the holes.
This now allows the pins to be fitted with light pressure from my small hammer for fitting with no sign of the existing cracks opening at all.
I will post photos tomorrow as I have had long day and wish to rest.
lennie screwed with this post 08-29-2010 at 04:21 PM
lennie is offline   Reply With Quote
Old 08-28-2010, 05:15 AM   #123
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,435
How did I miss this mod, over the past seven years? Sounds like an easy boost to low-end torque, and something I can easily handle at home.
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 08-28-2010, 07:59 AM   #124
lightfighter
where does this go?
Oddometer: 2,255
i have only ever seen it mentioned here in the gspot, and on a sport boxer forum that lennie is on.
but they are good kit... "easy" is relative, but if you have a mechanical background, understand valve trains, and can read instructions... managable.
lightfighter is offline   Reply With Quote
Old 08-29-2010, 03:43 PM   #125
lennie
Oddometer: 181
Andrew,
I have been very low profile with my marketing over the last 10 years.
Install is easy at home. Take time, mark all timing marks, safety wire the chain, and be very careful with removal and install of the sprockets. I usually insert a phillip screw driver into the cam bolt hole to slide the sprocket out.
You will be more than happy with the results.
Old 08-29-2010, 07:10 PM   #126
sbrownn
SlowMo
Oddometer: 457
Bolt failed
One of my cam sprocket bolts was over stressed upon removal. I don't know whether it had been done during assembly or when I loosened it, but when I put it back in it wouldn't torque down; just kept turning. I was really lucky I didn't twist it off in the cam shaft. Replaced them both.
sbrownn is offline   Reply With Quote
Old 08-29-2010, 07:31 PM   #127
lennie
Oddometer: 181
Adventurrer,
Best to replace the bolts with newies.
It can take a lot of pressure to get the bolts loose in the first place.
Old 08-29-2010, 07:37 PM   #128
Kilo Sierra
Kilo Sierra's Avatar
Oddometer: 189
Lennie,
Please resend your last email from Thursday(I think) to me...I accidentally deleted it.
tks,
ks
Kilo Sierra is offline   Reply With Quote
Old 08-29-2010, 08:10 PM   #129
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,435
Hmmm... basic question here, how do the new sprockets do anything different than if I were to just skip the chain over by a tooth with the existing sprockets? Seems that would achieve the same effect, of altering the cam timing... No? I have not taken an oilhead's head apart, but looking at the picture, it must be that the four holes fit onto pins on the camshaft, and so set the relative positions of teeth, TDC arrows, and cam lobes.
Old 08-30-2010, 01:51 AM   #130
The Other JC
4 year lurker..
The Other JC's Avatar
Oddometer: 206
360 degrees / 17 teeth would give a 21 degree turn per tooth. Quite a dramatic difference. Lennie has done the trial and error to get the best performance envelope at 9 degrees.
The sprocket is held in relation to the cam by a nipple, then 65NM of torque
The Other JC screwed with this post 08-30-2010 at 02:49 AM
The Other JC is offline   Reply With Quote
Old 08-30-2010, 05:37 AM   #131
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,435
Ah, yes... 17 teeth... jumping just one would give about 21 degrees...
Sometimes my head gets ahead of my math.
Old 08-30-2010, 05:57 AM   #132
The Other JC
4 year lurker..
Oddometer: 206
For the curious. The nipple placement is moved to account for the percentage degree change.
Old 08-30-2010, 08:48 AM   #133
dede
Lefty
dede's Avatar
Oddometer: 162
curious
Haven't seen the inside of an assembly. If the bolt is in the center holding the sprocket to the cam shaft and the alignment pin locates the sprocket radially. What do the rest of the holes do?
The democracy will cease to exist when you take away from those who are
willing to work and give to those who would not. Thomas Jefferson
dede is offline   Reply With Quote
Old 08-30-2010, 10:29 AM   #134
Hookalatch OP
Born Under Bad Sign
Hookalatch's Avatar
Oddometer: 364
Yes, the large center hole is where the bolt attaches. The smallest 5th hole is where the tab on the reluctor/camshaft timing device on the right head locates and is also held in by the main bolt. Thankfully the other 4 holes do not hold any fasteners or other devices.
Chuck
Hookalatch is offline   Reply With Quote
Old 08-30-2010, 12:07 PM   #135
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 802
Just weight reduction...
Ralf Wilkowski
Been there - already forgot about it...!
Follow my Journey, pursue insanity:
www.itwasnotme.com
signit98 is offline   Reply With Quote
Times are GMT -7.   It's 12:43 AM.
