Old 08-04-2010, 07:44 AM   #1
pdulik OP
Oddometer: 3
r90 dyna III ignition problem
i just installed a dyna III electronic ignition on my 1975 r90/6. everything ran perfect for maybe 10 miles until i came to a stop and it died instantly. came to find out the bike is losing spark at idle now. maybe a problem with the coils? everything was working perfectly up until i put the ignition on.
pdulik is offline   Reply With Quote
Old 08-04-2010, 10:57 AM   #2
mykill
odd
mykill's Avatar
Oddometer: 1,166
retrace
Since you have a history with the bike prior to the Dyna and it always worked fine, then start looking at everthing you touched. Check for power to the coils and quality of connections. Your igniton switch may also be the culprit.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 08-04-2010, 04:13 PM   #3
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
If your coils are new and the correct ones for use with the Dyna III ignition don't read on:
Primary coil resistance has to match the specification of the Dyna, check that. It is possible that 10min with the wrong coil killed the Dyna, when going back to points everything seems normal. If your coils are the original pair of 6V coils, about 35yrs old you could have killed the ignition too. Did you burn points rapidly and was that the reason you installed a Dyna? Signs of too low coil resistance.
What about just simply one of your "new" wires coming loose?
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 08-05-2010, 10:08 AM   #4
pdulik OP
Oddometer: 3
coils are the original coils. i thought it said that was ok. i didn't go through points often. the reason i put it on was because i heard such good thing about them and i wanted to make the bike more reliable. the low coil resistance is what the guy who installed it was thinking. i guess i'll check the coil resistance and the ignition. one more thing. the bike dies at idle and won't start again for a couple minutes. i don't know what that means either.
Old 08-05-2010, 01:14 PM   #5
Mandello
Guzzista
Oddometer: 161
I've had both points issues and DYNA ei issues on the road, points never took more than 10 minutes to sort out, the DYNA issue required a tow and overnighting new parts.... unless its for racing i don't see the point(s) in adding a dyna kit :p
AlexM
Mandello is offline   Reply With Quote
Old 08-05-2010, 05:20 PM   #6
StephenB
StephenB's Avatar
Oddometer: 2,044
That does point to a temperature (time sensitive) issue such as insulation failing inside the coil that start to act when the coil gets warm (heat expansion) and disappear when the coils cool down again (all back to normal). Remember, insulation inside the coil is achieved by using varnish which will age and crack with all those temperature changes over the life of your bike. If the coils are original I strongly recommend to replace them as they are initiating your combustion. If they don't work right, the best electronics won't help either.
This isn't the only possible solution to the problem, but I would not hesiate to replace the 35yr old coils to go with a brandnew electronic ignition.
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 08-09-2010, 10:58 AM   #7
pdulik OP
Oddometer: 3
well i put the points back in and it's running like a dream again. think i'm going to keep em on the rest of the riding season and worry about it later.
Old 09-02-2010, 04:32 PM   #8
kraut.burner
Smells güt!
kraut.burner's Avatar
Oddometer: 460
I did a little research on the Dyna III and found the installation manual. It says the dyna III was designed for use with the stock coils, or coils that have At least THREE OHMS primary resistance.
heres the link:http://www.starracing.com/Star/documents/D35-1.pdf
I too am thinking about using this, and getting new coils as well. Hope this helps!
04' R1100S- Gone but not forgotten
74' R75/6 Café Classico
R75/6 Café project
kraut.burner is offline   Reply With Quote
Old 02-22-2013, 08:33 PM   #9
flemsmith
lurk
Oddometer: 696
I'm confused....
I bought a Dyna III some time ago in prep for a rebuild. So now I'm rebuilding a 78 Moto Guzzi T3, and the instructions I have are exactly the same as the ones you show, except the model number is different D37-1, and it says at least 5 ohms primary resistance. Since I have new coils I've been running with the points that are 3 ohms I'm wondering if I'll end up burning up the output amp if I install it? I may just stick with points for that reason. But the electronics unit looks the same outwardly...would they really have designed a different unit with a lower output for Guzzi's, doesn't make a lotta sense to me.
roy
flemsmith is offline   Reply With Quote
Old 02-23-2013, 07:17 AM   #10
photorider
photorider's Avatar
Oddometer: 302
Sensor plate coming loose is a common problem which creates the symptoms you describe (it's how the system is grounded)
photorider is offline   Reply With Quote
Times are GMT -7.   It's 05:48 PM.
