08-04-2010, 08:13 AM
#1 |
Jett Cycle Sports
Oddometer: 5
08 Triumph Scrambler - Little Rock
http://www.jettcyclesports.com/index...dard&Itemid=99
![]() $5400.00 Miles: 2406 Engine type: 2 cylinders, 4-stroke, Inline Displacement: 865 cc (52.85 cubic inches) Bore × stroke: 3.54 inch × 2.68 inch (oversquare - shortstroke) Cooling system: Air cooled Power: 56.56 HP (41.6 kW) @ 7000 rpm Torque: 69 Nm (50.89 lb-ft) @ 4500 rpm Throttle: Cable operated Valves Valve train: DOHC, variable Valves per cylinder: 4 Fuel and ignition Sparks per cylinder: 1 Fuel supply system: Carburetor Ignition type: Digital CDI Compression: 9.2:1 Lubrication system: Wet sump Gear box: Manual 5-speed Clutch: Wet, multiple discs, cable operated Final drive: Chain Starter: Electric Dimensions Physical measures Length: 87.1 inch Width: 34.1 inch Height: 47.3 inch Wheel base: 59.1 inch Trail: 4.1 inch Seat height: 32.5 inch Weight Curb weight: 485 lbs Dry weight: 451.9 lbs Chassis and suspension Frame type: steel, Double cradle frame Front Suspension: Cartridge Suspension travel: 4.72 inch Fork angle: 28° Brake: Single Disk, Ø12.2 inch Tire: 100 / 90 R19 Rear Suspension: twin shock, Swingarm Suspension travel: 4.13 inch Brake: Disk, Ø10.04 inch Tire: 130 / 80 R17 Other ABS available: No Power-to-weight ratio: 0.19 KW/lbs (5.29 lbs/HP) Fuel capacity: 4.39 gals Number of riders: 2 persons Monday Closed Tuesday 8:00 AM - 5:00 PM Wednesday 8:00 AM - 5:00 PM Thursday 8:00 AM - 5:00 PM Friday 8:00 AM - 5:00 PM Saturday 8:00 AM - 4:00 PM Sunday Closed Jett Cycle Sports 4008 Macarthur Drive North Little Rock, AR 72118 Phone: (501) 753-9448 Email: jettcyclesports@att.net
Jett Cycle Sports 4008 MacArthur Dr. North Little Rock, AR 72118 Phone: (501)-753-9448 Web: www.jettcyclesports.com |
08-04-2010, 10:04 AM
#2 |
a fine automobile
Oddometer: 1,621
"Soon as I have my baby, I'm gonna get these raw tattoos." "Mom, you better not eat all my chicken." |
08-05-2010, 09:29 AM
#3 |
off-ramp slayer
Oddometer: 4,026
Somebody yank this add....
