Old 09-07-2010, 07:15 PM   #136
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Originally Posted by chrishsu
I would like to buy a pair of Flood beam with 3 mode dimming for my DR650. Can someone please suggest which mounting option I should get- flat or 7/8s bar mount?
Both mounts are included as well as shipping in the US. I also have push button on/off waterproof switch for $10. Paypal to sandjoh at gmail.com
Old 09-07-2010, 07:15 PM   #137
monkeyfez
Enabler....
monkeyfez's Avatar
Oddometer: 5,000
Well it's entirely up to you but on my DR I bought the light mount brackets from Jeff at procycle. DR page here. Can't link directly to the item on the page. If you use Sanjoh's flat mount it should bolt right up.
here's a pic from their site (using someone else's lights.)
the mount is solid and works well. Plus it cost's like $9.
EDIT 205'd by sanjoh. doh.
"When the monkey tells you to give it up, give it up." ~ Bubba Satori
monkeyfez is offline   Reply With Quote
Old 09-07-2010, 10:19 PM   #138
bigalsmith101
bigalsmith101's Avatar
Oddometer: 895
On my DR650...
I mounted the lights to my Acerbis Hand Guards as shown. I wanted to keep the lights out of ANY line of fire. If I damage them now... Well, then I probably deserve it.
Lights 2
Lights 3
LIghts 4
Here is my switch. $4 at Shucks auto. Probably not waterproof, though I did silicone caulk around the edges. Above the main on/off switch, I wired in a momentary switch that I pulled out of a used dishwasher. Again, probably not waterproof. But if they fail, I'll get one of the switches that Sanjoh uses.
Switch 1
Switch 2
bigalsmith101 is offline   Reply With Quote
Old 09-08-2010, 05:10 AM   #139
Unstable Rider
Fart and run
Unstable Rider's Avatar
Oddometer: 2,503
They look good even turned off !
Can't wait for mine to arrive.
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 09-08-2010, 06:56 AM   #140
dnrobertson
Big Bike, Slow Rider
Oddometer: 794
Sanjoh,
Please post up here when you get new supplies of the spot and flood lights. I am not really interested in the dimmable lights.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 09-08-2010, 08:51 AM   #141
1200B
Ride everywhere...
1200B's Avatar
Oddometer: 282
would it be possible to get the flood and spot led kit and hook the spot to come on with the stock low beam and the flood to come on when the high beam is switched on?
Photo Site:
http://JustinStG.com
1200B is offline   Reply With Quote
Old 09-08-2010, 09:02 AM   #142
cooter69
Smells Bad
cooter69's Avatar
Oddometer: 149
You would just have to run seperate relays to activate the lights via the trigger ex hi or low. I would also put in a switch to turn them all the way off if your on the road. They reflect on fog because they are so bright.
cooter69 is offline   Reply With Quote
Old 09-08-2010, 03:01 PM   #143
Velocibiker
Adventure Antagonist
Velocibiker's Avatar
Oddometer: 1,164
Some good ideas on mounting. No matter where I end up mounting them, I want to be able to adjust in/out and up/down. With these mounts, the only way that works is if the are mounted with the base in-line with the length of the bike (longitudinally??). If mounted using bigalsmith's way or using the ProCycle mounts, your ability to adjust where the light goes is limited. RAM mounts are a possibility, but I'd prefer a more rigid mount.
Currently bikeless.
Velocibiker is offline   Reply With Quote
Old 09-09-2010, 12:44 PM   #144
Qwik
Adrenaline Addict
Oddometer: 6,568
PIAA Makes a clamp/mount for the KTMADV Crash bars. Thats what I am going to use (I already have the clamp)
Speed bumps never seem to make me go any faster
Qwik is offline   Reply With Quote
Old 09-09-2010, 02:27 PM   #145
Velocibiker
Oddometer: 1,164
Linky please.
Currently bikeless.
Old 09-09-2010, 02:42 PM   #146
monkeyfez
Enabler....
monkeyfez's Avatar
Oddometer: 5,000
Originally Posted by Velocibiker
Linky please.
Inmate Hotspice sells them (cyclenutz) I couldn't recommend him enough.
http://www.cyclenutz.com/Auxiliary-L...unts_c_81.html
Old 09-09-2010, 09:07 PM   #147
Stromdog
Howl at the Moon
Stromdog's Avatar
Oddometer: 2,703
Here are a couple of pics of some Discount Auto Parts "el Cheapos", mounted on my DL 1000.
I ordered a set of lights from Sandjoh, so I sholuld just be able to switch out these lights and leave everything else in place. The sizes look to be quite close
I just used one of the front fender bolts to attch the lights. I cut little squares of inner tube material and put them between the base of the light and the fender. These "cheapos", have been pretty decent, but draw 70 watts all the time. Sandjoh's lights (floods), are 27 watts each, for a total of 54 at full power. The Strom is a little "stator challenged", so being able to run with less amp draw is a good thing.
Stromdog is offline   Reply With Quote
Old 09-12-2010, 04:12 AM   #148
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
The following images are not controlled for exposure, they were all done using my smartphone camera, which has rather basic controls.
I went outside early this morning to capture images while it's dark. Now I have some idea of the real power of these floods.
First, the garage door with the stock headlight. Note the yellow cast to everything, and in particular the parts of the garage door that are outside of the light pattern, as compared with the second photo. This is partly a result of the camera changing exposure for the vastly differing light levels.
With both LEDs burning, the stock headlight's pattern is almost completely gone. See how white the background is? The camera sees this light as very natural and bright enough to get much truer color reproduction.
The next set of images were taken with the bike in the same position (perhaps 8 feet from the garage door). This will help you to understand the amount of light, as the scene is lit by the reflection from the garage door.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 09-12-2010, 05:59 AM   #149
Sharkguy
chain lube applier
Sharkguy's Avatar
Oddometer: 203
I bought these a month or so ago. I have been following this thread and note some of you want to know how to assemble the connectors. Please see the links on page 3 for some assembly instructions. I didn't need to use the connectors, but some may. Just helping out a great vendor.
Sharkguy is offline   Reply With Quote
Old 09-12-2010, 07:15 AM   #150
SAC73
SAC73's Avatar
Oddometer: 4
Lighting
Very good lighting, make deliveries to Argentina? Regards
SAC73 is offline   Reply With Quote
Times are GMT -7.   It's 02:37 AM.
