09-12-2010, 11:57 AM
#151 | |
Lost in Cyberspace
I don't think that a resistor before the the setup will smoke a LED but could heat up the driver unit indeed.
Suzuki DR650 '92 [Mods to do] Luggage system w/ Pelican 1520 (Thanks to inmate 685), or softbags [Mods in the make] Tool tube with tools [Mods done] 1 1/8" handlebar - KLR650 Shock on DR650s - ZX-10R directionals on DR650s - RMZ450 muffler on DR650s - Acerbis Mollsoft taillight - Trailtech Vapor – Twin Air - Metzeler Tourance - Tusk sealsavers - more to come puntoMX screwed with this post 09-12-2010 at 12:17 PM |
09-12-2010, 08:57 PM
#152 |
Howl at the Moon
Oddometer: 2,703
I'll post up some garage door shots once I get mine mounted. I switched out the stock lamps on my DL 1000 with a pair of ARC Xenon Super White bulbs a couple of years ago. An improvement over the already great stockers! The high beams really reach out there, while providing a decently wide beam. Stroms are known for their GREAT headlights. The best I've seen. The high beams will fry your eyes during the daytime. At night, no good for traffic conditions-they will blind oncoming drivers.
I'm looking forwards to Sandjoh"s units. I hope that these will give me a wider, brighter "ditch view". Not concerned about the "reach", as much as the wide angle of coverage of the lights on two lane country roads at night. I've had my share of close calls with various, "road crossing", critters over the past 35 years of motorcycling that could have put me down hard. Properly aimed, these should increase daytime visiblility to other drivers too. We didn't have the quality of headlights 30+ years ago that we have now. I'm figuring that they would have saved alot of lives. Ride safe, Brothers. |
09-13-2010, 10:32 AM
#153 | |
Team Gear Whore
** An LED lamp contains an LED (or array of LEDs) with a built-in current-limiting resistor whose value is chosen for the intended operating voltage (usu. a range, 12V to 14V) and for the particular arrangement of the LEDs. A multiple LED array may include series-connected LEDs (the LED Vf's add together) or parallel-connected LEDs (the LED If add together) or, typically, parallel arrays of series-connected LEDs (LED Vf's and If's add together). I meant no offense to you personally, only the advice given.
Alex Alegado, http://www.alsplace.com2009 Aprilia SL 750 Shiver / 2007 Kawi KLX250S |
09-13-2010, 01:33 PM
#154 | |
Lost in Cyberspace
(I know I can't ).
Suzuki DR650 '92 [Mods to do] Luggage system w/ Pelican 1520 (Thanks to inmate 685), or softbags [Mods in the make] Tool tube with tools [Mods done] 1 1/8" handlebar - KLR650 Shock on DR650s - ZX-10R directionals on DR650s - RMZ450 muffler on DR650s - Acerbis Mollsoft taillight - Trailtech Vapor – Twin Air - Metzeler Tourance - Tusk sealsavers - more to come |
09-13-2010, 06:16 PM
#155 | |
Team Gear Whore
Your flashlight example is very good: A lot of those super-bright, compact flashlights use white LEDs that have relatively high forward voltages (relative to standard LEDs, e.g. 3V or more) but they are powered by a single 1.5V battery. The "extra" voltage is made up by a DC-to-DC converter that trades current draw for voltage (power being mostly constant through the conversion). It works the other way too: Those 4 cell Mag-Lites will have a series voltage of 6V which a DC-to-DC converter can step-down to the proper voltage for the LED, say 3.7V (Example). The DC-to-DC converter is what makes those Mag-Lite LED conversion kits cost more than you'd expect them to.
09-13-2010, 06:29 PM
#156 |
Meat Popsicle
Oddometer: 169
Conlige suspectos semper habitos. |
09-13-2010, 07:15 PM
#157 |
Purveyor of Light
Oddometer: 3,646
Not yet, will advise
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
09-13-2010, 07:28 PM
#158 |
I Ride Ms Piggy
Oddometer: 1,798
Glad I stumbled on this thread - was looking at HIDs. Seems that LEDs are coming of age - finally!
One of the issues that I have always had with high powered driving lights is that when switched to low beam against oncoming traffic it is "Good Night Irene" with the light output dropping to zilch and can't see nuttin' in front. What is the solution to this? HID low beam? I would love to have a couple of the floods, but also need a solution for low beam, *without* going the HID path if possible. viz |
09-13-2010, 07:34 PM
#159 | |
Goin' Somewhere
Oddometer: 1,266
+1
I agree with viz ...
You need to talk your supplier into developing a 6 to 7 watt Euro beam that can be ran day & night ! Quote:
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - '09 DR650SE - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -- - '12 NC700X |
09-14-2010, 05:41 AM
#160 |
Howl at the Moon
Oddometer: 2,703
Just finished mounting a set of the 3 way lights on my DL 1000.
Looks to me like when they are on the "low", setting, they'll work perfectly for daytime driving lights. When set on "high", these things are amazing. They are exactly what I was looking for in a night time riding, two lane country road scenario. Wild critters lurking in the shadows will really stand out with these. I plan on aiming them low and to the left and right in order to get a wide illumination pattern. I'll try and get some pics posted of both a daytime low setting and at night on all three settings. These appear to be high quality units and really look sharp on the bike. |
09-14-2010, 09:49 AM
#161 |
Oddometer: 62
Do you ship to Greece?
09-14-2010, 05:09 PM
#162 | |
Grumpy Old Bastard
Oddometer: 6,492
09-14-2010, 06:44 PM
#163 | |
Oddometer: 82
After I find my dual waterproof high-frequency PWM ... I will order my LEDs |
09-15-2010, 02:51 AM
#164 | |
Ravening for delight
Oddometer: 8,645
I am considering these dimmers: http://www.theledlight.com/dimmers.html You can get a 12 volt model that is very small and rated for 8 amperes in a confined space. THAT is the kind of thing that I suspect you could build into an enclosure and pump power through all day long without trouble.
Why did I drink all of the ingredients for vomit? "Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar "you cannot reason a person out of something they were not reasoned into." - Jonathan Swift |
09-15-2010, 10:40 PM
#165 |
Smells Bad
Oddometer: 149
Here's some shots mounted on a 1999 st1100
The headlight bulbs are silver stars. The light examples were highlight exposed on the low beam and the settings were left that way via dslr low ![]() highbeam ![]() highbeam + uber light ![]() lowbeam + uber led ![]() a few mounted shots sorry it was late n' the bike is dirty ![]() ![]() Here's an alblum with more shots if needed linky |
