Old 09-28-2010, 04:14 AM   #211
Tony990adv
Oddometer: 32
Wink For my KTM 990 ADV
Email sent!
Tony990adv is offline   Reply With Quote
Old 09-28-2010, 05:02 AM   #212
RoyB
Dartmouth, Massacusetts
Oddometer: 1,578
Roy B
Dartmouth, MA www.rvbprecision.com
2007 BMW K1200R Sport abs,2007 DL650 V Strom abs
2004 Honda VFR abs,2001 Moto Guzzi Rosso Mandello
1971 Honda Trail CT90
RoyB is offline   Reply With Quote
Old 09-28-2010, 06:19 AM   #213
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,653
Thank you for the effective diagram.
Old 09-28-2010, 09:47 AM   #214
Unstable Rider
Fart and run
Unstable Rider's Avatar
Oddometer: 2,498
An after thought.
After having mine installed for a couple days, I now WISH I had installed a tiny little red LED indicator light somewhere so I could tell for sure the things are on.... (during the day).
You get to tapping the intensity switch for the three way action, and sometimes you will wonder as you are riding, are they still on?
I got mine for DAY USE as much as night use.
I wanted to be SEEN by the cage-queens on cell phones.
Anyway, next rainy crappy day, I am going to Radio Scrap and getting a red LED I can plant somewhere as an indicator lite..
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 09-28-2010, 09:12 PM   #215
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
Originally Posted by RoyB
I was just about to post a query about a circuit diagram like this. Nice. Thanks
viz
Pig In The City - 2010 BMW R1200 GSA Adventure
Webmaster BMW Touring Club of NSW
viz is offline   Reply With Quote
Old 09-28-2010, 10:54 PM   #216
FJRick
FJRick's Avatar
Oddometer: 205
These lights don't need a relay!
You really don't need a relay at all for these lights. Here's the reason: If you use two of the 24 watt lights that would be 48 watts total which is only 4 amps at 12 volts total for the set. (This is why they only have like 20ga. wire to them) Most switches are rated for at least 10 amps @ 12 volts so all you really need is a switch to operate them not a 30 or 50amp relay. The only time you would require a 50 amp relay is if you were going to run 10 sets (20 lights) of the floods which would be 40 amps at 12 volts. These aren't like regular driving lights which are in the 55 to 60 watt per light range so a pair of them would be close to 10 amps at 12 volts which is getting too close to the limit of a 10 amp switch to not use a relay and you would still only need a 30 amp relay for them. I'm just sayin....
Sidein Slideways!!!
04-Yammy FJR-1300 (Gone but never forgotten!)/04-Zuk DL-1000 06 Husky TE-610 and others!
If I'm selling something I will not respond to PM's sent without you first responding to my original post!!!! (So others know that you have sent me a PM)
FJRick is offline   Reply With Quote
Old 09-29-2010, 01:02 AM   #217
The Bigfella
Big Adventurer
The Bigfella's Avatar
Oddometer: 2,469
PM sent. Price to Australia please
A man should only do the work that is required of him. To do more is a form of greed.
Ride through Oz and Asia
The Bigfella is online now   Reply With Quote
Old 09-29-2010, 03:26 AM   #218
Unstable Rider
Fart and run
Oddometer: 2,498
FJ Rick is right.
Just wire, a fuse holder and switch!
A friend of mine made an observation last night. I was leaving his place just as it was getting dark... he said, "one of your lights is brighter than the other".
I may, perhaps, have my LED's "out of sequence". At some point in the trial and wiring and "playing" with these during set-up, I think I may have them out of sink with each other if that is poss.
When I have one on medium, the other looks like it's on low. If I switch one to high, the other that was on low I think goes to medium then...
Might have to unplug them and point it at the garage door and get em in sink with each other?
Anyone else or is this my imagination?
~Butch Cassidy
Old 09-29-2010, 06:16 AM   #219
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
That may well be, but in a CanBus system like which BMW has (as in my GSA) may not like the extra amps and come up with an warning light.
Anyone confirm that?
Something else: what about spikes from the relay operation (assuming that I have to use one) - would it be worth while to solder a capacitor on the relay (how big and which terminals?)
viz
Old 09-29-2010, 07:45 AM   #220
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
Originally Posted by Sick-Till-Tuesday
FJ Rick is right.
Not your imagination. You will need to disconnect one then cycle the power on the other until at the same output setting, then reconnect.
Old 09-29-2010, 07:38 PM   #221
Unstable Rider
Fart and run
Oddometer: 2,498
Thanks Sanjoh,
Like most people, I confess I took one light out and played with it by hooking it up to a gel cell batt and blasting it down my rural street...
.......cool
As I was doing the install, mount and wire, it never occurred to me that these new 3 way intensity lamps could get "out of sync" with each other, but that's what it was...
Someone else has to have done the same, just disconnect them from each other, put power to one and confirm that it is on HIGH (point towards inside of garage door).
Do the same to the other.
Now, solder or reconnect them both back in tandem to your switch, and when you flip your switch they should both have advanced to "low".
And now they are friends with each other again.
Heading out for a couple days, this will be fun. Venturing into MOOSE country.
~Butch Cassidy
Old 09-30-2010, 01:02 AM   #222
Tony990adv
Oddometer: 32
Thumb Aux. lights for my bike
PM sent! Please reply, Thanks!
Old 09-30-2010, 06:34 AM   #223
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,188
Have the regular flood came in yet?
Thanks,
Assfault
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 09-30-2010, 07:09 AM   #224
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
Thanks,
Assfault
Yes, please email sandjoh at gmail.com
Old 09-30-2010, 06:51 PM   #225
IBGONE
Old, slow, and happy
IBGONE's Avatar
Oddometer: 1,799
Wow! The lights I ordered came today, were a breeze to install, and I just got back from a test ride with them. wOOt! They are bright and very effective. Maybe the best part was ordering them and paying for them late Monday, and Thursday evening I'm riding around with them. great service, and much appreciated.
Harboring hate or resentment is like taking poison and hoping the other guy dies.
There are no demons inside my helmet; just the magic of the Universe sliding past my every sense.
Me.
IBGONE is offline   Reply With Quote
Times are GMT -7.   It's 10:04 PM.
