Old 06-20-2012, 11:29 AM   #2461
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,285
Originally Posted by kbroderick View Post
On the subject of a clipped beam—any chance there's an LED in the work with a low-beam-friendly pattern?
Not in the near future. You need an LED controller/dimmer
Heck, the technology seems to be at a point where you could have a dual-mode, single-lamp solution that provided a quality (i.e. good light where you want it, sharp cutoff) low beam as well as a bright-as-heck high/driving beam, but no one seems to have one on the market.
Already have the dual-mode ala high/low beam using one of our LED controllers. Optics have not been developed to address the clipped DOT light.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 06-20-2012, 01:33 PM   #2462
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,435
"clipped beam"
Hey sanjoh ....
Have you experimented with a solid or mostly smoked Light protector in a semi-circle shape ... to maybe get that "clipped beam --- low-beam-friendly pattern ???
just curious ...
http://stores.intuitwebsites.com/hst...ion/Detail.bok
Honda
GsVs is online now   Reply With Quote
Old 06-20-2012, 06:41 PM   #2463
watagans300exc
watagans300exc's Avatar
Oddometer: 114
Light specifications
Hi John,
Just ordered mine. 4 x the Mod 60 + dimmer, + poly lens covers + HD mounts.
Say, I can't seen to find any engineering drawings of the fitting so I can pre-fabricate a mount. ( I may be having a man look as my wife says though)
Do you have any info I could have a look at??
I am just after the housing and mounting bracket info. Nothing "back of house"
Cheers,
Tony.
watagans300exc is offline   Reply With Quote
Old 06-21-2012, 04:49 AM   #2464
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,285
Originally Posted by watagans300exc View Post
Hi John,
Cheers,
Tony.
Email sent, thanks for your business.
Old 06-21-2012, 02:06 PM   #2465
nickgindy
Doing it Wrong
nickgindy's Avatar
Oddometer: 2,537
Got my lights installed. Here are the lights mounted to the windshield. It doesnt hold to bad but I may look into a mount last in time.
My toggle.
Im leaving the controller on my keys for now.
There is hardly any room for the control box near battery so put it in the rear of the bike.
All wires were crimped with connectores and heat shrinked over the connectors.
I also wired in a advmonster volt meter. It is wired to turn on and off with the switch. Unfortunantly it can not be seen in direct sun light.
2003 Sv650s; 2012 BMW F650GS; 1999 Suzuki Dr 350se
The Nightmares of Others
In memory of IMPD Officer Perry W Renn. E.O.W July 5, 2014. "I will always get out of my car."
nickgindy is online now   Reply With Quote
Old 06-21-2012, 02:20 PM   #2466
nickgindy
Doing it Wrong
nickgindy's Avatar
Oddometer: 2,537
Video of everything
Note in the video it looks like the lights flicker. They do not its just the way video captures the leds. Hopefully the video will be edited upright once its available on here.
Old 06-21-2012, 02:25 PM   #2467
subybaja
subybaja's Avatar
Oddometer: 2,893
Originally Posted by pyro_ View Post
Not exactly true, you can get DOT approved 7" LED headlights from trucklight and SW Speaker (Harley uses these ones). I have one of the trucklights on my bandit right now.
Kbroderick has the phrasing right- "DOT compliant". "DOT approved" just means that the manufacturer states that it meets standards. Anyone can say that, as long as they can back it up. I don't really understand how states can use a non-existent definition in their laws (but they do).
http://www.bikersrights.com/nhtsa/notapproved.html
The European CE mark is the same.
We had part of a Slinky. But I straightened it.
subybaja is offline   Reply With Quote
Old 06-21-2012, 03:12 PM   #2468
eSONG
eSONG's Avatar
Oddometer: 435
mounted mine on the hand guards, both sides. works AMAZINGLY WELL... my only regret was i should have gotten them SOONER. if you have any doubts, you will not be disappointed. my friend who has never seen them before and had HIDs on his other bike was literally shocked when he saw how bright they are, both on low during daytime, and full power at night on the backroads.. he called them my "light cannons". i love 'em. Thank you Sanjoh!!
eSONG is offline   Reply With Quote
Old 06-21-2012, 03:14 PM   #2469
nickgindy
Doing it Wrong
nickgindy's Avatar
Oddometer: 2,537
Do you go off road ever
Old 06-21-2012, 04:32 PM   #2470
eSONG
eSONG's Avatar
Oddometer: 435
no, not really...if you're referring to single track where true dirt bikes belong. i'm probably on unpaved roads about 10-15% of the time, and most often, unintentionally while going over backroad mountain roads...
Old 06-21-2012, 06:20 PM   #2471
walkergreenlabel
Oddometer: 193
aim
any advice on aiming these puppys before the race tomorrow?
walkergreenlabel is offline   Reply With Quote
Old 06-21-2012, 06:21 PM   #2472
eSONG
eSONG's Avatar
Oddometer: 435
i set mine at night
Old 06-21-2012, 11:16 PM   #2473
nickgindy
Doing it Wrong
nickgindy's Avatar
Oddometer: 2,537
I decided to try to 3m my fob. I hope is holds up and if not i hope replacement fobs are available and are universal. Haha
Old 06-22-2012, 07:25 AM   #2474
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,285
The plastic will eventually break, you might want to consider the mount sooner than later.
That is intentional, if it was bright enough to see in direct sunlight, it would blind you at night. I would recommend mounting it under your gauges.
Thank you, glad you are enjoying the lights.
Horizontal with the ground. No matter how you aim them, everyone in front of you will be pissed But you will be making daylight!
Old 06-22-2012, 12:56 PM   #2475
nwdub
Oddometer: 1,097
So I'm lookin in to a pair of the 60s when I get some money, how would I set up a dimmer low beam and full on high beam?
and why can I get the exact same lights for less on ebay?
nwdub is offline   Reply With Quote
Times are GMT -7.   It's 07:44 PM.
