Old 05-08-2013, 07:11 AM   #3361
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,265
Originally Posted by dsc522758 View Post
Any other 12v fused source not mentioned in the documentation? That 12v wire coming from the rotary is a bit short to get anywhere. You mentioned the horn circuit. The horn switch won't work will it?
The horn circuit may work, the switch will not as it is momentary on. What type of bike is it? Which model lights?
Since I am trying to wire with highbeam bypass do I need to go by some wire at Radio Shack and some type of spade connectors and run a hot to a relay of some sort from the battery hot and then run from relay to 12v marked on the rotary switch? I guess ground works the same. Bike is in pieces in the garage until I get this figured out.
Switched fused power is recommended. Your description of the relay will work.
Relay also? 44 divided by 12.5 = 3.52 x 1.25=4.4 10A inline fuse I guess?
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 05-08-2013, 07:41 AM   #3362
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,803
Depending on where you draw your power from, this diagram can work:
I have a few others here: http://www.jimvonbaden.com/BMW_Wiring_Diagrams.html
Jim
JimVonBaden is online now   Reply With Quote
Old 05-08-2013, 07:48 AM   #3363
Goofy Footer
Oddometer: 569
sanjoh, do you sell brackets to flush mount your lights? (I'm thinking more headlight replacement as opposed to auxiliary lighting).
Also, I'm assuming the latest Model 30 sale at the end of March has ended, correct?
Goofy Footer is offline   Reply With Quote
Old 05-08-2013, 08:05 AM   #3364
dsc522758
dsc522758's Avatar
Oddometer: 20
2009 Kawasaki KLR650. Model Lights are dual 44's. Going to try using a relay. I know I can do this! hahaha
2009 Kawasaki KLR 650
dsc522758 is offline   Reply With Quote
Old 05-08-2013, 08:06 AM   #3365
JimVonBaden
"Cool" Aid!
Oddometer: 53,803
Relay set-up:
Jim
Old 05-08-2013, 08:50 AM   #3366
dsc522758
dsc522758's Avatar
Oddometer: 20
Originally Posted by JimVonBaden View Post
Relay set-up:
Jim
Will 10amp fuse work or do I need a 15amp fuse?
Old 05-08-2013, 09:40 AM   #3367
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,265
Yes, please email sandjoh@gmail.com
Correct
Old 05-08-2013, 09:42 AM   #3368
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,265
10a will be fine. Figure each Model 44 pulls 1.8a each.
Old 05-08-2013, 11:10 AM   #3369
JimVonBaden
"Cool" Aid!
Oddometer: 53,803
5 amp for two lights, ten for four!
Remember, you are protecting the wiring, not the lights. Keep the fuse close to the accessory max to minimize wire damage in the event of a short.
Jim
Old 05-08-2013, 11:13 AM   #3370
dsc522758
dsc522758's Avatar
Oddometer: 20
What exactly plugs into terminal 86 on the relay. Check your email as I cannot attach pics yet.
Daniel
Old 05-08-2013, 11:24 AM   #3371
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,265
Daniel
Replied
Pics are not allowed as attachments, need to have a 3rd party host, ala smug mug, photobucket etc
Old 05-08-2013, 02:05 PM   #3372
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
Relay set-up:
Jim
I would add to this: use a diode protected relay, something like the Narva 68032 to insure against circuit spikes that could upset or damage canbus systems... Everything else is the same, just a diode is added.
viz
Pig In The City - 2010 BMW R1200 GSA Adventure
Webmaster BMW Touring Club of NSW
viz is offline   Reply With Quote
Old 05-08-2013, 02:39 PM   #3373
JimVonBaden
"Cool" Aid!
Oddometer: 53,803
Daniel
86 is the trigger wire that goes to your on/off switch. It carries a very small load and allows the smallest of switches without danger of hurting it. Pull a large load on a weak switch and it will fail. Not really an issue with most LED lights.
Jim
Old 05-09-2013, 07:35 AM   #3374
dsc522758
dsc522758's Avatar
Oddometer: 20
Light Position
Geez.....now that I got the lights working, how do you get them to stay in the position you want? I have got those things cranked down and they still move. Do I need to replace the Phillips head with a hex head to get more crank on them? I sure do like them!
Old 05-09-2013, 08:30 AM   #3375
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,265
Tighten the nut, hold the phillips. Fine pitch, keep on turning the nut.
Times are GMT -7.   It's 02:55 PM.
