Old 08-31-2013, 01:49 PM   #3511
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,463
Sanjoh, I have the M60's on my WR250R (love them), and now thinking I need some Aux lights on my R1150GS. Mostly for on-street visibility, but also want to light up small windy country roads in the night times. What lights do you recommend for that? Also do those M64's work off the dimmer the same as the M60's, and is the mount similar?
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 09-02-2013, 10:11 AM   #3512
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,212
Originally Posted by sanjoh View Post
Try mounting the light above or below the mounting point.
Unfortunately the mount extensions were just too weak to hold the lamps, and the vibrations weekend the metal to the point of failure. This time around, I've built some heavy duty mounts that will not fail. And of course, because I'm cheap, I'm using products from the local hardware store. pics coming soon
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 09-03-2013, 07:19 AM   #3513
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
A pair of M30s or an M30 and a M44 for a bit more beam width. Do you have a place in mind to mount them?
The M64s work fine with our dimmers. The mount is much thicker as the lights are quite a bit heavier than our round lights.
Old 09-03-2013, 08:35 AM   #3514
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,463
Thinking of fabricating a light bar mount for under the "Beak". Nothing fancy just a some aluminium bar stock I have laying around.
Old 09-03-2013, 08:51 AM   #3515
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,647
Dooooooo it and then post pics and how to.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 09-04-2013, 04:02 AM   #3516
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Don't make it look too good or your friends will want one
Old 09-05-2013, 09:57 AM   #3517
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,463
Will do.
Order just sent - went with the Model 60's with the dimmer after all. Combo works great on my WR250, might as well keep with the same ones on the GS.
Old 09-06-2013, 04:35 AM   #3518
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Will do.
Thanks for your business
Old 09-06-2013, 08:51 AM   #3519
George 99
George 99's Avatar
Oddometer: 778
Received my fairing and M60 yesterday, John. I'm getting it wired and mounted now. Quality of the fairing gel coat is great, thanks for good service.
(Could'a been cheaper tho, you don't _really_ need to make a profit do ya. )
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 09-07-2013, 05:49 AM   #3520
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Thanks for your business. Now let's see some pictures!
Old 09-08-2013, 02:10 PM   #3521
JustinP
JustinP's Avatar
Oddometer: 1,970
We have a 20a dimmer with high beam bypass in the works. Contact me at sandjoh@gmail.com if you have any interest in testing it.
Is that a remote dimmer, or rotary dimmer? I'll be ordering a pair of m64's to add to my model 60's. The m64's will be replacing my model 30's. Would be interested in testing the new dimmer, since the one I have can't handle 4x 2.4 amps.
Also - what is the weight of the M64 versus the model 30 format?
And, if you order a set of the m64's wit ha dimmer, do they come "plug and play"?
FAST: 2004 non-ABS "Silver Bullet" FJR - FASTER: 2008 Touring/Endurance Hayabusa - SLOW: 1997 R1100GS
Quality LED Lighting - ADV Discount inside:) - LEDRider LED motorcycle lights
JustinP screwed with this post 09-08-2013 at 07:33 PM
JustinP is online now   Reply With Quote
Old 09-09-2013, 04:49 PM   #3522
Ceemack
Oddometer: 77
I've suddenly got an issue with my rotary dimmer. I'm fine on low-beam, but when I hit the high-beam switch the LED lights go out.
Any suggestions?
Ceemack is offline   Reply With Quote
Old 09-09-2013, 06:00 PM   #3523
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
M64s are heavy, don't have the weight handy, will post up tomorrow. Yes on the plug n play, will need an approximate length lead you will need as the light come with a 10" lead standard.
Old 09-09-2013, 06:01 PM   #3524
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Any suggestions?
Check connections first. Do the lights go to full power when rotary knob is put on full ouput?
Old 09-09-2013, 08:58 PM   #3525
Ceemack
Oddometer: 77
Yes, on low-beam they'll go from full brightness to nothing, depending on how the knob is turned. They've worked perfectly until this weekend.
I haven't had a chance to test the wire I've got spliced into high-beam circuit, which in turn is connected to the purple wire on the dimmer. I'm a little puzzled as to why they'd go out completely once the high-beam circuit was activated.
Times are GMT -7.   It's 12:26 AM.
