Old 10-16-2013, 03:42 PM   #3631
red_rock_beetle
Oddometer: 10
awesome, I was thinking 2-60's amd 2-30's but I guess I'll try the 60's to start with. I have a bit of a light fetish
red_rock_beetle is offline   Reply With Quote
Old 10-16-2013, 03:48 PM   #3632
red_rock_beetle
Oddometer: 10
Is there any promo codes I can use? and what is the ETA on the dimmers?
red_rock_beetle screwed with this post 10-16-2013 at 04:03 PM
Old 10-16-2013, 05:07 PM   #3633
jasonmt
Oddometer: 556
http://www.advrider.com/forums/showthread.php?t=431761
jasonmt is offline   Reply With Quote
Old 10-16-2013, 05:23 PM   #3634
Mike Honcho
Got Beaver?
Mike Honcho's Avatar
Oddometer: 2,392
Just ordered some M60 goodness.
Mike Honcho is online now   Reply With Quote
Old 10-16-2013, 05:29 PM   #3635
red_rock_beetle
Oddometer: 10
Thanks jasonmt, I have 2 60's coming to texas also!
Old 10-18-2013, 08:04 AM   #3636
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,195
Thanks for the repeat business
Thanks! Let me know if you need any tech help.
Old 10-20-2013, 05:08 AM   #3637
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,195
Rotary dimmers are in stock
Old 10-20-2013, 05:50 AM   #3638
dsc522758
dsc522758's Avatar
Oddometer: 20
Originally Posted by marcopolos View Post
I have the Happy Trail Nerf Bars/skidplate/pegs on my green 08 klr. Does anyone have these lights mounted on the lower screw in the pic or somewhere on the bars? How bout on the lower screw of the actual fairing? I want them away from my blinkers and will probably have them on a switch or dimmer so as not to blind anyone in oncoming traffic off the road. I wouldn't mind mounting these on my jeep rack and getting rid of my huge KCs
(pic is from HT site)
Has anyone ever mounted their lights on Happy Trail PD Nerfs for the 2008+ KLR650n that is shown in this picture? Have you used the ADVmonster Crash Bar Light Mount? I would really like to see the install pictures close up. Sanjoh says they will work but then in the description is says it will work with bars 30mm, 27mm, 25mm and 23mm. I don't think those bars are that big.
2009 Kawasaki KLR 650
dsc522758 is offline   Reply With Quote
Old 10-20-2013, 05:51 AM   #3639
dsc522758
dsc522758's Avatar
Oddometer: 20
Originally Posted by sanjoh View Post
Thanks, your install looks great! What kind of bike do you have?
We have a mounting bracket that will work on the HT bars.
Send me an email sandjoh@gmail.com with the year and model of your bike and I wll send some examples of mounting.
These are what I am talking about.
Old 10-20-2013, 09:42 AM   #3640
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,269
I see the M15 spots sold as pairs at a very affordable price. Anyone using these? How does the light output compare with the M30, M50, M60 that you all seem to be discussing?
Looking at setting up a light bar across the nose of my sidecar....
" I need to stop talking and start drinking" ...Mom
RedMenace screwed with this post 10-20-2013 at 09:56 AM
RedMenace is offline   Reply With Quote
Old 10-20-2013, 12:01 PM   #3641
daveburton
Oddometer: 185
Dimmer switch
Whilst I'm sure the quality of the lights is good, my 60s installation on my GSA resulted in melting the on/off/dimmer controller. I had to cut it out on the road and tape up the wiring. I had the dimmer Velcro attached to the front fairing. If you guys know of a better quality unit I'd appreciate the feedback. The lights survived 2000 miles in Brazil and Uruguay including some gravel roads. The wiring logic seems good etc but the switch feels very light, not sure if that implies poor quality.
daveburton is offline   Reply With Quote
Old 10-21-2013, 05:32 AM   #3642
ewagman
Oddometer: 31
Yes, pics are on the way.
Sanjoh:
Looking at your lamp specs:
M 50:
  • Spot Beam 25 degrees
  • 2.2amps @12v, 26 watts
  • 3x Cree LED XML U2
  • 2700 lumens
M 60:
  • 30 degree Beam
  • 3600 lumens
  • Cree XM-L U2 LEDs
  • 2.4 amps (28 watts) @12v
I am trying to visualize the difference in illumination between these two lamps. I am assuming the housings match and are the same size?
Perhaps your experience can shed some light on this? I'd like to have the basis for an informed decision for an imminent purchase.
ewagman is offline   Reply With Quote
Old 10-21-2013, 06:51 AM   #3643
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Yeah I was all excited about the model 50 until I saw the specs; 25 vs 30 deg does not, on paper, seem like it'll add much throw. Really like to see pics...
Sa
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 10-21-2013, 12:12 PM   #3644
dsc522758
dsc522758's Avatar
Oddometer: 20
Rotary Switch
I know I saw a post in here......maybe from Sanjoh.....on putting a dab of something under the rotary piece to help keep it from turning on it's own. Does anyone remember what that "dab" was?
Old 10-21-2013, 05:25 PM   #3645
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,195
Believe the dimensions, the mounts will not work on the 5/8" tubing HT uses for some of their bars.
I've put some 3000 miles on my strom with these lights. They work great, a bit tighter beam than the model 30.
Hi Dave, sent you an email on the dimmer a few days back. I would certainly like to understand what happened with your dimmer and need your reply.
Times are GMT -7.   It's 05:26 PM.
