Old 10-21-2013, 07:51 AM   #3646
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Yeah I was all excited about the model 50 until I saw the specs; 25 vs 30 deg does not, on paper, seem like it'll add much throw. Really like to see pics...
Sa
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 10-21-2013, 01:12 PM   #3647
dsc522758
dsc522758's Avatar
Oddometer: 20
Rotary Switch
I know I saw a post in here......maybe from Sanjoh.....on putting a dab of something under the rotary piece to help keep it from turning on it's own. Does anyone remember what that "dab" was?
2009 Kawasaki KLR 650
dsc522758 is offline   Reply With Quote
Old 10-21-2013, 06:25 PM   #3648
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
Originally Posted by dsc522758 View Post
Has anyone ever mounted their lights on Happy Trail PD Nerfs for the 2008+ KLR650n that is shown in this picture? Have you used the ADVmonster Crash Bar Light Mount? I would really like to see the install pictures close up. Sanjoh says they will work but then in the description is says it will work with bars 30mm, 27mm, 25mm and 23mm. I don't think those bars are that big.
Believe the dimensions, the mounts will not work on the 5/8" tubing HT uses for some of their bars.
Originally Posted by RedMenace View Post
I see the M15 spots sold as pairs at a very affordable price. Anyone using these? How does the light output compare with the M30, M50, M60 that you all seem to be discussing?
Looking at setting up a light bar across the nose of my sidecar....
I've put some 3000 miles on my strom with these lights. They work great, a bit tighter beam than the model 30.
Originally Posted by daveburton View Post
Whilst I'm sure the quality of the lights is good, my 60s installation on my GSA resulted in melting the on/off/dimmer controller. I had to cut it out on the road and tape up the wiring. I had the dimmer Velcro attached to the front fairing. If you guys know of a better quality unit I'd appreciate the feedback. The lights survived 2000 miles in Brazil and Uruguay including some gravel roads. The wiring logic seems good etc but the switch feels very light, not sure if that implies poor quality.
Hi Dave, sent you an email on the dimmer a few days back. I would certainly like to understand what happened with your dimmer and need your reply.
Old 10-21-2013, 06:46 PM   #3649
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
M15 pics. This is a single light.
This is a great deal! Less than $70 usd for a quality set of lights with a 1 year warranty.
Old 10-22-2013, 04:52 PM   #3650
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
Originally Posted by ewagman View Post
Sanjoh:
Looking at your lamp specs:
M 50:
  • Spot Beam 25 degrees
  • 2.2amps @12v, 26 watts
  • 3x Cree LED XML U2
  • 2700 lumens
M 60:
  • 30 degree Beam
  • 3600 lumens
  • Cree XM-L U2 LEDs
  • 2.4 amps (28 watts) @12v
I am trying to visualize the difference in illumination between these two lamps. I am assuming the housings match and are the same size?
Perhaps your experience can shed some light on this? I'd like to have the basis for an informed decision for an imminent purchase.
Housings are the same, aluminum, oring sealed openings.
The M60s still have the edge on distance. The M50 puts out more than our M44.
Pics should be up in a couple of days.
Old 10-22-2013, 04:53 PM   #3651
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
Your favorite grease or petroleum jelly under the rotary knob.
Old 10-23-2013, 06:37 AM   #3652
ewagman
Oddometer: 28
Thanks, so the 60's have the edge for distance as well as fill, for only $10 more. I missed my deadline to obtain and install new lamps for my impending ride, now I have plenty of time to wait for the pics to be posted.
ewagman screwed with this post 10-23-2013 at 08:42 AM Reason: spell
ewagman is offline   Reply With Quote
Old 10-23-2013, 07:37 AM   #3653
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
ADVmonster M1 at work in the surf.
Old 10-23-2013, 03:05 PM   #3654
George 99
George 99's Avatar
Oddometer: 776
John, here's my DRZ with the wind screen 'n lights. Works a charm so far. Haven't had her out after dark yet but she sure lights up the garage.
And with the added aluminum plate "shelf". Tabs on the shelf attach to the upper triple clamp bolts, then to the top of your provided braces. Lower Adel clamps wrap around the fork legs and to the bottom of the braces. Very stable mount.
The shelf has, so far, a volt meter and switch, and the heated grips control. Under the shelf is all the wiring for lights, grips, turn signals, horn, etc.
The 'puter is mounted to piece of aluminum plate screwed to the fiberglass. Front "arrow" LED turn signals are also mounted to the fiberglass, pretty much tucked in.
Thanks for this option, I think it all hangs together pretty good with the big Safari tank.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 10-23-2013, 08:00 PM   #3655
Shaggie
Unseen University
Shaggie's Avatar
Oddometer: 2,622
Thanks for the feedback.
I like your install!
what mount is this using??
Impressive set up!
Shane
"We are not at home to Mr Reasonable" - Sam Vimes
NZ Touring pics:Brass Monkey 2009:Kiwi Sun:Tiki-touring: Daytrips in NZ
Shaggie is offline   Reply With Quote
Old 10-23-2013, 08:39 PM   #3656
dsbiker
Oddometer: 16
Impressive set up!
Mount is custom made by me guess I should have taken some install sequence pics but I didn't
dsbiker is online now   Reply With Quote
Old 10-23-2013, 09:32 PM   #3657
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,651
Does Sanjo have yellow lights or lenses?
Jim
JimVonBaden is online now   Reply With Quote
Old 10-23-2013, 10:56 PM   #3658
tc339
tc339's Avatar
Oddometer: 60
Jim
ask that a bit ago. apparently the manufacturer discontinued them so they are looking for an alternative.
tc339 is offline   Reply With Quote
Old 10-24-2013, 04:55 AM   #3659
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 751
Nice set up George. Do those yellow cases go on the bike? I am very disappointed that there isn't a picture with one of your ST1100 in the background.
'97 Honda ST1100
Sunday Rider is offline   Reply With Quote
Old 10-24-2013, 06:29 AM   #3660
JimVonBaden
"Cool" Aid!
Oddometer: 51,651
Thanks! My cheapo E-Bay light died, so I was considering a second set of ADVMonster lights.
Oh well, the search continues.
Jim
Times are GMT -7.   It's 09:32 PM.
