Old 10-24-2013, 11:54 AM   #3661
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 828
Originally Posted by George 99 View Post
The yellow cases may go on, I have the racks mounted now. Using soft bags this weekend to go down to Salton Sea.
Here's a pic with the racks on, and a packed ST in the background. Took this last Wednesday before a weekend ride to Lompoc, CA.
Looks great George. Lot of adventure on those bikes with ADV Monster lights (a plug for the thread drift).
Sunday Rider is offline   Reply With Quote
Old 10-25-2013, 06:15 AM   #3662
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Nice looking install!
Any issues with the safari and the fairing with steering at full lock?
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 10-25-2013, 06:24 AM   #3663
George 99
George 99's Avatar
Oddometer: 787
None, John. I checked closely before installing the turn signals, they come closest to the tank. All is good.
Someone else mentioned the fairing looks like it's mounted high, but I like it. Have about 40 miles on the combination, no problems.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 10-25-2013, 06:48 AM   #3664
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Great!
The fairing is very flexible with respect to mounting height. I choose to mount mine as low as possible due to the off road type of riding I do.
Mine is bolted to the fender with nylon bolts for the lower mount and to the stock headlight subframe for the upper. Still provides plenty of protection, rode for 6 hrs in the rain the day after this pic, no problem.
Old 10-25-2013, 09:54 AM   #3665
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,429
Will be watching this thread to see your new Fog Lights!
Looking for a replacement atm.
We will be coming out with a true fog light next month. Plan on having yellow available with the new light.
Honda
GsVs is online now   Reply With Quote
Old 10-29-2013, 01:54 PM   #3666
George 99
George 99's Avatar
Oddometer: 787
[QUOTE=sanjoh;22633351]Great!
I've now got my horn (such as it is) mounted under the fairing. Looks right.
Having an issue with my remote dimmer, assume it's the battery. Need to go to Rat Shack for a replacement. Otherwise, all worked well on my weekend trip to Salton Sea and back. Arrived there after dark on Friday and the 60 provided plenty of light. 44 was on dim and couldn't boost it to full bright.
I'll let ya know how things work out.
George
Old 11-01-2013, 05:22 AM   #3667
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Did you get things straightened out? Plenty of room for a voltmeter behind the fairing
Old 11-01-2013, 01:04 PM   #3668
George 99
George 99's Avatar
Oddometer: 787
Volt meter installed in the 'luminum dash. Works a treat. Barely see a move when turning lights on/off. Heated grips and/or vest drop it to low 13s, so not too worried.
Dimmer problem was the battery. This thing sat on a shelf for over a year so not surprised. A little problem finding a 27A 12V battery in Kingman, only place in town is Rat Shack. They come in a pair so I now have a spare.
George
Old 11-01-2013, 04:09 PM   #3669
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Great! Just got the Dual Sport Fairing installed on a 2013 CRF250L. Considering a bolt on kit if there is some interest
sanjoh screwed with this post 11-02-2013 at 07:05 AM
Old 11-01-2013, 09:43 PM   #3670
George 99
George 99's Avatar
Oddometer: 787
Looks good, John.
I'm wondering if Honda will put the 300 motor in the CRF? I sure enjoyed the 250 while in Thai earlier this year.
George
Old 11-01-2013, 09:45 PM   #3671
tc339
tc339's Avatar
Oddometer: 61
M62 Lights
Anyone with the M62 lights have issues with the mounts? I have them as tight as I can get them and they still wobble around a lot. Any recommendations to fix it?
tc339 is offline   Reply With Quote
Old 11-03-2013, 06:09 AM   #3672
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Take a close look at the fit between the mount block and the light body. Both are slightly tapered, the tapers should engage firmly, before the flat end of the mounting block bottoms out on the light body.
If this is the issue, file off some of the mounting block where it meets the light housing until the tapers fit firmly.
Old 11-03-2013, 02:41 PM   #3673
tc339
tc339's Avatar
Oddometer: 61
Okay thank you. Yeah the front of the mount hits the light body. I will grind down the front. That sounds like it will do the trick. Thank you.
Old 11-06-2013, 05:55 PM   #3674
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Originally Posted by cheeseyboy View Post
With a pair of the m15 led's, is a relay necessary? How bright would these be for occasional street use? And is the rotary dimmer weatherproof? Thanks.
No relay is needed, less than 2 amps for the pair.
The lights are very bright, with a focused beam. I've used them for some 3500 miles, with a dimmer. A great addition to the Vstrom.
And an awesome deal at less than $70 for the pair after the inmate discount.
The rotary dimmer is waterproof.
Old 11-07-2013, 01:50 PM   #3675
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,294
Any idea when the amber fog lights will be available or what the price will be?
" I need to stop talking and start drinking" ...Mom
RedMenace is offline   Reply With Quote
Times are GMT -7.   It's 06:40 AM.
