Old 01-02-2014, 03:53 PM   #3796
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Originally Posted by inyang View Post
At your site and the 'inmate' discount code is not accepted.
No more discount or different code?
fixed, "inmate" good for 10% off
Old 01-02-2014, 06:46 PM   #3797
hoadie72
Oddometer: 69
I missed that there's an inmate discount when I placed my order. I'll definitely remember next time!
I installed a pair of M60s + dimmer on my F650GS over the weekend and while I've tried the lights out twice at night, I'm impressed both with the increased visibility other road users have of me, and how much brighter these lights are at night when on high. It's difficult to say exactly, but they seem to be twice as bright as the puny OEM high beam, and that's with the M60s still pointing to the ground a bit.
Anyway, I have a question - with the dimmer set to anything other than the lowest setting, off, or full, one of my lights makes an audible high pitched humming noise. The dimmer I bought is the "Rotary LED Dimmer with High Beam Bypass". Is this to be expected?
hoadie72 is online now   Reply With Quote
Old 01-02-2014, 07:00 PM   #3798
Jnich77
Jnich77's Avatar
Oddometer: 669
Two model 30's and a model 60 + my high beam with a OEM spec bulb in the middle of nowhere Tx.
Jnich77 is offline   Reply With Quote
Old 01-03-2014, 05:08 AM   #3799
Rutabaga
Oddometer: 730
Could you please post a picture of your installation? I have an 09 G650 and have interest in seeing the possibilities. Thanks.
Rutabaga is offline   Reply With Quote
Old 01-03-2014, 09:08 AM   #3800
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Originally Posted by squiffynimrod View Post
Does that include the Rotary LED Dimmer with High Beam Bypass? That may explain the degrade in battery performance after I installed the dimmer and the M30's on the GSA. Or the battery's just wearing out.
The rotary dimmer pulls .0065a when off.
Old 01-03-2014, 01:18 PM   #3801
inyang
5secs away
inyang's Avatar
Oddometer: 396
Order placed
'11 - 690R
inyang is offline   Reply With Quote
Old 01-05-2014, 04:51 AM   #3802
hoadie72
Oddometer: 69
Here you go.
Admittedly in that position there's a little movement. A more rigid position would be near the indicator stalks but I want people to see when I'm turning. Or not.
Old 01-07-2014, 06:50 PM   #3803
cba191
wanna buy a monkey?
cba191's Avatar
Oddometer: 696
what exactly would I need in addition to the lights. I want to use a skene dimmer and a handlebar switch. I'm thinking about a 30 and a 44.
I'd think about the 60 if my Tiger had a better alternator.
cba191 is offline   Reply With Quote
Old 01-08-2014, 07:25 AM   #3804
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
You'll need to mount the lights. The Tiger electrical should be able to handle the M60s easily. I ran a couple of 55w halogens when I had my tiger, no problem. A pair of M60s is less than 60w. Keep in mind if you are using a dimmer, the power consumption is significantly reduced while in the dimmed mode. Typically when you have the high beams on you are moving, thus creating a bit more power from the electrical system.
Old 01-13-2014, 05:49 AM   #3805
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Another happy customer
I got my model 30's installed. I am really pleased with the ease of install and quality of the products. Thanks so much for the great products and great service. The lights make it a joy to ride at night.
Old 01-13-2014, 10:16 PM   #3806
hoadie72
Oddometer: 69
Hi sanjoh; when you have a sec can you pls take a look at this?
Old 01-14-2014, 07:30 PM   #3807
dwj - Donnie
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 14,026
How do the Model 30 LED off road Spot lights compare to the $319 auxiliary LIGHTS KTM sells for the 990 Adventures? Will the supplied brackets mount them under the fairing of the 990 Adventure the way the KTM lights mount? Also, what is the difference between the standard lights and the heavy duty lights? Thanks!
Donnie
Donnie - Retired & Riding - 2010 990ADV - 39,152 Miles - 1 Continent - 10 Countries
Traveling Mexico 2014 - SPOT
dwj - Donnie screwed with this post 01-14-2014 at 08:34 PM
dwj - Donnie is offline   Reply With Quote
Old 01-15-2014, 09:46 AM   #3808
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
PM sent
Donnie
Here is a thread on the KTM kit. Looking at the beam pictures in that thread, a pair of model 30s will offer: 1) significantly longer throw/distance, way beyond the stock high beam. 2)more light closer to the bike.
The M30 will mount to a stud or flat surface. Looks like that kit comes with some additional brackets.
Old 01-16-2014, 07:58 AM   #3809
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,232
Donnie, John,
The 990 above is mine (and my buddy's Africa twin), both with Model 60, same as model 30 in terms of size.
My mechanic made a couple of aluminum brackets to mount the lights under the cowling, they can be seen in the first pic arising from the fairing's side. It's a bit over engineered and not really necessary but they are very well made.
You can also install them using a simple straight steel angle on each side of front frame, mounted vertical, using the horn mount holes and identical holes on the other side of the front frame.
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is offline   Reply With Quote
Old 01-20-2014, 12:54 PM   #3810
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,600
Well hello Guys and gals!
I'm here for my long overdue feedback on John's customer service! All I can say is that I'm amazed about not only his products, but also of how he deals with customers!
Send him a PM a month ago to ask him how long he'd need to ship to France since I was going on a trip and needed to replace my spot LED light from him (discovered that you can't run two different sets of lights with the autoswitch AS7: was running the M60 flood and M30 spot model). He was able to ship in less than a week to my home and even offered me a full refound for the model I wasn't going to use (by the way John I think that I'll keep it for my GF's bike, but really thanks again for the offer)! Model that I've bought back in august! I've never seen such a devoted vendor! Be sure that when I get my new bike in february that I'll buy some more lights from you!
Cheers mate!
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road – One month to find the rising sun
Loutre is offline   Reply With Quote
Times are GMT -7.   It's 11:27 PM.
