Old 01-24-2014, 01:44 PM   #3811
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Originally Posted by ben2go View Post
I dig it but I can't find the small light bar you have posted here,the one with 4 leds side by side.Is it still in skunk works status?
Not quite ready for showtime. Should be ready within a couple of weeks.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 01-24-2014, 08:05 PM   #3812
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,727
Sweet.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 01-25-2014, 02:48 AM   #3813
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,350
The new site looks good, easy to navigate.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 01-25-2014, 03:22 AM   #3814
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 7,658
Question
I am already running a set of the original Denali lights on my Tenere. I have them mounted low on the crash bars. I would like to add more light just below my factory headlights. I am thinking fog lights but not sure..
I was looking at your F11 fogs and your M15 spots which would you recomend?
Also wondering if your dimmer switch could handle all four lights at once?
However, I am not complaining because I know that I am probably better today then I will be tomorrow, so I try and enjoy every day as it comes, and stay determined to live well and be appreciative of what I still can do..."Stromsurfer"
PWRCRZR is offline   Reply With Quote
Old 01-25-2014, 05:26 AM   #3815
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Are the Denalis spot or flood beam? Where are you needing more light, distance, width or both?
Yes, the dimmers are rated by ampacity with up to 6 amps for the rotary dimmer or 8 amps for the wireless dimmer. Your system would be around 4 amps with the additional lights.
Old 01-25-2014, 09:51 AM   #3816
Trippps
Fool
Oddometer: 82
I'm looking to mount a pair to the top of my highway bars on a cruiser (Rocket 3 Touring), to illuminate the edge of the road for deer, do you think spots or floods would be a better choice?
And to clarify, you can tie them in with your high beams so that when the high beams are on they are on full brightness, but when you flip your high beams off, they revert to whatever the dimmed setting is? And can they be used in conjunction with a relay setup, for me specifically the Eastern Beaver?
'The greatest obstacle to discovery is not ignorance -- it is the illusion of knowledge.'
Trippps screwed with this post 01-25-2014 at 10:12 AM
Trippps is offline   Reply With Quote
Old 01-25-2014, 11:10 AM   #3817
dwj - Donnie
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 14,869
Need Help with Mounting Bracket for 2010 990 ADV
Hi!
I have read of a few folks using 1" angle iron, aluminum in my case, to mount Model 30 LEDs and other Leds that are the same size. I have removed the cowlings, I have the angle aluminum, but I can't seem to understand how to make it work. It is my understanding that you use the horn mounting holes. how do you do this and retain the horn. Looks like the angle iron will have to be shaped considerably. But maybe I am over looking the obvious. I would appreciate some help! I am trying to get my moto headed from Mississippi to Central America. Of course I have to stop in south Mexico and pick up my "novia"! Photos of my moto are included. Thanks!
Donnie
Donnie - Retired & Riding - 2010 990ADV - 51,036 Miles - 2 Continents - 10 Countries
Return to Panama - SPOT
dwj - Donnie is offline   Reply With Quote
Old 01-25-2014, 02:33 PM   #3818
Texcollect
Adventurer wannabe
Texcollect's Avatar
Oddometer: 200
Finally got round to taking a couple of photos of my installed lights.
Sent from my iPhone using Tapatalk Pro
If you love your bike, set it free. If it comes back to you, you just highsided.
Texcollect is offline   Reply With Quote
Old 01-26-2014, 03:21 PM   #3819
dwj - Donnie
Oddometer: 14,869
Hi!
I am in the process of placing an order for the 3rd time. My item never left the Cart and I received no confirmation, so I am assuming something went wrong. I only want one pair of mounts. Please disregard any more than one order. Thanks!
Donnie
OK! I got an order number this time!
Old 01-26-2014, 05:49 PM   #3820
hoadie72
Oddometer: 74
Originally Posted by hoadie72 View Post
Here you go.
Admittedly in that position there's a little movement. A more rigid position would be near the indicator stalks but I want people to see when I'm turning. Or not.
Changed from the brackets in the photo above to the Ezy-Mount light brackets, which are much, much more rigid.
Even happier with the lights now, not to mention the service from John.
hoadie72 is offline   Reply With Quote
Old 01-27-2014, 09:17 AM   #3821
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Floods would give you the width to see well off the edge of the road. Model 44 or if you want to light the world, Model 60s.
Using either the rotary or wireless dimmer will provide this option. When a dimmer is purchased with lights, the setup comes plug n play.
Yes
Old 01-27-2014, 09:17 AM   #3822
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Is that an FZ or ?
Old 01-27-2014, 09:22 AM   #3823
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Originally Posted by dwj - Donnie View Post
Hi!
Donnie
Perhaps you could ask this in Orange Crush?
Old 01-27-2014, 09:40 AM   #3824
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Where did you find the ezy-mount?
Old 01-27-2014, 11:58 AM   #3825
hoadie72
Oddometer: 74
I bought it from Cyclenutz. It was their last set, and I couldn't find anyone else with stock. It's a shame because it's very well made, over engineered for my application.
Times are GMT -7.   It's 02:01 AM.
