Old 07-03-2014, 02:19 PM   #4111
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
Next week for beam shots.
F40 webpage http://stores.advmonster.com/f40-lig...ot-flood-beam/
Old 07-03-2014, 02:59 PM   #4112
SoilSampleDave
Oddometer: 2,072
I'm probably 4 - 6 months out from buying a used 950, and this is going to be first farkle, without question.
"Comparison is the thief of joy" - TR (the good Roosevelt)
'08 530EXC
SoilSampleDave is offline   Reply With Quote
Old 07-03-2014, 11:19 PM   #4113
tobbik
Oddometer: 77
F11 Fog Lights
Hi,
I have a couple of questions about the Fog lights?
- When will they be available again?
- How long are the leads?
- can you wire both lights of a single (switched) fuse?
- 3A Fuse okay?
Thanks,
- Tobias
tobbik is offline   Reply With Quote
Old 07-04-2014, 05:16 AM   #4114
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,567
Thumb
Originally Posted by ZORBA View Post
Any beam patterns?
Sent from my iPad using Tapatalk
Hi Zorba!!! Are you going to put those on the GS?
Please say yes!
Cheers!
Dave
Racegun is offline   Reply With Quote
Old 07-04-2014, 11:25 AM   #4115
Offcenter
On The Road Again!
Offcenter's Avatar
Oddometer: 283
Sanjoh, there are many of us out here running older 6 volt bikes.
How about a flood or spotlight for us? These old electrical systems won't support additional standard incandescent bulbs.
An LED flood light would be a godsend.
George, high in the hills of Jersey!
77 Honda CT-90
76 Honda GL-1000
Offcenter is offline   Reply With Quote
Old 07-04-2014, 08:47 PM   #4116
Slvrtundevl
Slvrtundevl's Avatar
Oddometer: 523
Sanjoh, I sent you a pm about 2 weeks ago... Did you get it?
Come to the darkside....We have Cookies!!!
2010 KTM 990
Slvrtundevl is offline   Reply With Quote
Old 07-05-2014, 04:28 AM   #4117
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
Originally Posted by tobbik View Post
Hi,
- 3A Fuse okay?
Thanks,
- Tobias
Available now (will update web page)
Lead is one meter.
Can be wired together, 3a fuse is fine for a pair.
Old 07-05-2014, 04:30 AM   #4118
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
Are these older bikes DC 6v?
Old 07-05-2014, 04:33 AM   #4119
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
Please look at the F40 here.http://stores.advmonster.com/f40-lig...ot-flood-beam/
Let me know if that helps.
Old 07-05-2014, 05:17 AM   #4120
Offcenter
On The Road Again!
Offcenter's Avatar
Oddometer: 283
Yes sir, I ride a '77 Honda Trail 90, 6 volts DC.
A friend has a 74 Honda ST-90, also 6 DC.
He also has an old BSA that is also 6 volts. Don't know if
the lights on that one run DC or AC.
Years ago, I had three of the old BMWs from the 50s and 60s.
They were also 6 DC. I would have killed for good lights
on those bikes. I'm sure all the collectors of those old machines
would love to have bright LED lights that draw low current.
Since the LEDs themselves only run off of 3 volts or so, making
a set for 6 volt systems shouldn't be a big problem, right?
(Just guessing. You'd know better than me.)
77 Honda CT-90
76 Honda GL-1000
Offcenter screwed with this post 07-05-2014 at 05:23 AM
Old 07-09-2014, 08:42 AM   #4121
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
F11's are back in stock
Old 07-10-2014, 07:09 PM   #4122
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
Any feedback on the F40 combo lights?
Old 07-11-2014, 01:36 AM   #4123
bigalsmith101
bigalsmith101's Avatar
Oddometer: 924
I was just about to ask the same question, but decided to just do before asking. I used these lights all the way to Argentina and back on a DR650, and have a spare Model 30 and Model 40 lying around.
I bought a 1974 Suzuki TC100 just yesterday and it appeared that the headlight was burnt (or so I thought). Have to have a headlight to be legal, so I tested the Model 30 on a 6v battery charger (it worked) and wired it up to my bike via the battery and a switch. BAM! Success! Legal!
WAY better lighting and WAY more of it. Saweeeeeeeeeeeeeeeeet! The light is off in the photo, but trust me, it's like night and day when compared to the stock 6v bulb regardless of high beam or not. Just rode it tonight side by side with a 2005 Yamaha Zuma, and there is no comparison.
Slap a couple of these badasses on your bike and never look back. I've got mine mounted to the stock headlight mounting bolt on my TC100.
As I got down the road, my headlight started working as the voltage/battery got up to speed. However, I've got a ADVmonster LED light on there and it's STAYING.
bigalsmith101 screwed with this post 07-11-2014 at 01:43 AM
bigalsmith101 is offline   Reply With Quote
Old 07-11-2014, 04:32 AM   #4124
fredgreen
Stoked for Rick's
fredgreen's Avatar
Oddometer: 692
Still waiting for delivery here in Canoodia. I'll report back when it's installed on the S10!
You can find me out in the garage, or the woods.
My ride report: http://www.advrider.com/forums/showthread.php?t=701602
http://advrider.com/forums/showthread.php?t=724831
fredgreen is offline   Reply With Quote
Old 07-11-2014, 02:36 PM   #4125
Offcenter
On The Road Again!
Offcenter's Avatar
Oddometer: 283
BigAl, just to make sure I understand you.....
Are you saying that the 12 volt model 30 and 40 worked on 6 volts??
77 Honda CT-90
76 Honda GL-1000
Times are GMT -7.   It's 03:48 AM.
