Old 07-26-2014, 03:06 AM   #4156
tc339
tc339's Avatar
Oddometer: 60
Originally Posted by fredgreen View Post
Super tenere
Post some pictures when you get it mounted up. Considering this for my Tenere and want to see how it looks.
tc339 is offline   Reply With Quote
Old 07-28-2014, 03:51 AM   #4157
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,694
ordered a pair of M50 and foglights for my 1150GSA :o)
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Old 07-28-2014, 01:50 PM   #4158
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,064
Thanks for your business! Shipped today
Old 07-28-2014, 06:09 PM   #4159
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,324
This is pertaining to my V Star.I want to mount fogs down low on my engine guard and mount my spots up where most cruisers have there's above the signal lights.Would this be optimal placement?
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is online now   Reply With Quote
Old 07-29-2014, 07:14 AM   #4160
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,064
Yes it would be the best placement with fogs and spots wired independently.
Fogs low to reduce glare during fog(spots off).
Spots high for max distance when conditions warrant (fogs on for fill or width, if needed).
Old 07-29-2014, 10:13 AM   #4161
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,324
Thumb
They would all be wired independently with their own switches.The V Star 650 doesn't have much reserve and I am going all LED next spring to free up a few watts for my GPS.
Old 07-29-2014, 04:39 PM   #4162
Scratch33
Fugawi?
Scratch33's Avatar
Oddometer: 2,762
Ordered a set of Model 30 LED's for my girlfriend's F700GS. That bike definitely needs more light up front.
If you've never stared off into the distance, then your life is a shame.
2008 R1200GSA
2009 DD750
2010 MADASS 125
Scratch33 is offline   Reply With Quote
Old 07-31-2014, 05:07 PM   #4163
SoilSampleDave
Oddometer: 1,915
Just got my advmonster flashlights in and I have a question. The red charging LED flashed on the charger when I started charging the batteries, and 5 hours later it is still flashing. I was assuming it would go off or go solid when fully charged; is this not the case? It definitely charged the batteries, flashlights work like a champ.
Don't drive like my brother!
"Comparison is the thief of joy" - TR (the good Roosevelt)
'14 690R
SoilSampleDave is online now   Reply With Quote
Old 07-31-2014, 08:13 PM   #4164
nvklr
nvklr's Avatar
Oddometer: 137
I would like to see how you mount these.
nvklr is offline   Reply With Quote
Old 08-01-2014, 11:05 AM   #4165
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,064
Sounds good. You will likely free up a bunch more watts than your GPS will use.
The charger LED will eventually turn green. The charge cycle is such that the last few % of capacity takes the longest time. You can leave the batteries in the charger when it is in the wall, it will shut off the charge to battery when full.
Old 08-02-2014, 05:22 AM   #4166
fredgreen
Is it Spring yet?
fredgreen's Avatar
Oddometer: 671
Tenere lights mounted
Lights work great mounted here. The mounts from Sanjoh required a bit of belt sander adjustment to fit proper and the inserts supplied had a burr that needed filing off. The light bar just fits in this location. The amount of light is obscene, don't stare directly at it!
You can find me out in the garage, or the woods.
My ride report: http://www.advrider.com/forums/showthread.php?t=701602
http://advrider.com/forums/showthread.php?t=724831
fredgreen is offline   Reply With Quote
Old 08-04-2014, 05:35 AM   #4167
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,064
Thanks for the pics
Any idea if it would bolt up under the fairing?
Old 08-04-2014, 11:51 AM   #4168
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,064
Had several advr's ask if the F40 combo spot and flood leds were independently controllable.
We now have the F20, available in spot or flood.
  • Cree XM-L2 LEDs
  • 2000 Lumens
  • Beam Patterns available: 10 degree spot or 30 degree flood
  • Aluminum construction with stainless hardware.
  • AR-1 coated Polycarbonate lens
  • IP68 rated - Dust and waterproof
  • Input voltage 9-32VDC
  • 5500k color temperature
  • 1 meter sheathed wire lead, ready for connectors
Old 08-04-2014, 02:41 PM   #4169
fredgreen
Is it Spring yet?
fredgreen's Avatar
Oddometer: 671
Thanks for the pics
It will indeed fit if the crash bar is not mounted on your S10.
Old 08-06-2014, 05:12 AM   #4170
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,064
Times are GMT -7.   It's 01:20 PM.
