Old 01-24-2011, 07:29 AM   #841
BexarWolf
Oddometer: 46
Has anyone figured out a better way to secure the lights in their base to keep them from turning? I have mine mounted sideways and I've removed the two inside nuts/added a nylon sleeve over the screw but they still tend to turn a little. I considered setting them again and then just brazing the brackets so there's no movement.
BexarWolf
2001 BMW F650GS
Falkor
__________________________________
"Sit tall in the saddle, hold your head up high. Keep your eyes fixed where the trail meets the sky. Live like you ain't afraid to die. Don't be scared, just enjoy your ride" - Chris LeDoux
BexarWolf is offline   Reply With Quote
Old 01-24-2011, 07:45 AM   #842
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
I used aluminum rather than nylon spacers. This allowed me to crank 'em down nice and tight. I also used a bit of loctite and let it get between the two parts of the bracket.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 01-24-2011, 10:00 AM   #843
Callahan
Callahan's Avatar
Oddometer: 1,181
Bite washer ?!?!?!?
My thought is of using a washer between the leafs of the bracket to bite the metal plate and provide resistance of movement. As a last resort maybe going back to the 4 nut system, still with the added movement resistance washers.
I have two 24W Floods and as yet have not mounted mine but have this system ready to go.
e.g.
Lock washer
Internal tooth lock washer
Serrated lock washer
Fan disc lock washer
Callahan is offline   Reply With Quote
Old 01-24-2011, 12:14 PM   #844
katoomryder
Oddometer: 84
Originally Posted by liquorpig View Post
I'm looking for something that will help out my 450exc for nighttime trail riding but I haven't seen any examples of these installed on smaller bikes
Anyone out there that's installed these on a 'dirt' bike that can give an opinion on how they've worked out for them?
I put a set (10w spot & 24w flood) on my 450 and they work great. took a little time to figure where to mount 'em (ended up on the handguards) and I had to get a DC stator (KTM's put out AC from the stator) and wired into my headlight switch. Now the low position on the switch runs the high circuit on the stock headlight and the high switch position runs both LED's. just have to remember to turn the key switch off with the DC conversion as it will drain the battery.
2008 990 Adventure
2008 450 EXCR - Sold
2001 453 MXC - Sold
1995 250 EXC - Sold
katoomryder is offline   Reply With Quote
Old 01-24-2011, 01:25 PM   #845
BexarWolf
Oddometer: 46
The lock washers between the leaves of the brackets seems like a viable option.
This is how I have mine mounted right now:
And my switch install. One is for the flood and the other is for the spot:
e.g.
Lock washer
BexarWolf
2001 BMW F650GS
Falkor
Old 01-24-2011, 05:35 PM   #846
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Easier Adjustment via spacer, "beefier" looks
Got this "spacer" from Home Depot 1/4-20, reduced the length by ~2mm, using it with an M5x35 socket head screw and stop-nut, works great, now
much easier to set the right angle since there's only one screw/stop nut to adjust.
Before:
tallguy-09 screwed with this post 01-26-2011 at 06:51 PM
tallguy-09 is offline   Reply With Quote
Old 01-24-2011, 10:49 PM   #847
bEnt_bars
bEnt_bars's Avatar
Oddometer: 129
I was thinking about the handguards as well but don't see them lasting that long there
Do you have a pic of your setup?
bEnt_bars is offline   Reply With Quote
Old 01-25-2011, 03:48 PM   #848
Jumper5392
Jumper5392's Avatar
Oddometer: 420
LEDs on my GS Adventure
Installed a set of these LEDs on my GS Adventure today. Very happy with the results.
They are the 24w LEDs with the wireless dimmer.
DSCN0635_DSCN0634
DSCN0637_DSCN0639
DSCN0643
Thanks John
ray
Alabama Tag-O-Rama Map
07 BMW GS Adventure
08 KLR 650
Jumper5392 is offline   Reply With Quote
Old 01-25-2011, 04:52 PM   #849
SMURPH
Jackass
SMURPH's Avatar
Oddometer: 397
Looks great!
Painting Strom > http://tinyurl.com/kyubg68
Follow me to Baja!! - http://tinyurl.com/mmvurcz
SMURPH is offline   Reply With Quote
Old 01-25-2011, 09:05 PM   #850
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
Thanks John
Nice install, where did you put the control box?
Is the pulsing of the lights just in the video?
Old 01-26-2011, 12:17 PM   #851
Jumper5392
Jumper5392's Avatar
Oddometer: 420
LED dimmer
John, Put the dimmer under the seat. I've got a centech fuse box under there so that's where I got power. The pulsing on the video is something with the camera. With the lights on their brightest setting it's hard looking at them straight on so it might be the camera telling me "stop doin' this will you".
ray
07 BMW GS Adventure
08 KLR 650
Old 01-26-2011, 07:24 PM   #852
appalachian
Ride fat boy ride
Oddometer: 248
Are these available when ever or a limited supply ? I'd like to have a set but its gonna be a while.
Takes the road less graveled.
appalachian is offline   Reply With Quote
Old 01-26-2011, 08:57 PM   #853
leeinmemphis
Oddometer: 1,150
I installed a set of the 24w version last night on my RT. Holy cow these things are bright! :) ......I am going to order another set for my GS. I LOVE THESE LIGHTS!!!!
'11 Yamaha zuma 125
'06 Buell Ulysses
'09 Yamaha T-Max
'06 Honda Silver Wing
'09 Stella 150 with sidecar
leeinmemphis is offline   Reply With Quote
Old 01-29-2011, 03:02 PM   #854
katoomryder
Oddometer: 84
liquorpig
here's how I mounted mine. I figured i rarely wheelie over backwards so they should be safe here.
2008 990 Adventure
2001 453 MXC - Sold
1995 250 EXC - Sold
Old 01-29-2011, 03:03 PM   #855
katoomryder
Oddometer: 84
here's a side shot. the switch is for the heated grips, not the lights
2008 990 Adventure
2001 453 MXC - Sold
1995 250 EXC - Sold
Times are GMT -7.   It's 12:14 AM.
