Old 08-07-2010, 12:58 PM   #1
newcastleadam OP
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,422
KLR650 Engine Noise?...now with video!
I picked up this 2001 KLR650 with 29400 miles locally, PO said it had a diagnosis of an engine bearing needing replacement (earlier thread here). Got it running the other day and now want to address the engine bearing question. The engine is noisy, but this is my first KLR so I'm not sure what's good noise and what's bad noise. So....youtube video time!
http://www.youtube.com/watch?v=24n-MDVmxpM
What I've done:
-changed oil
-changed coolant
-checked oil screen (clean)
-changed brake fluid
-replaced front brake piston seals
-replaced bulldog'ed oil drain plug with cool low profile magnet plug
-peeled off rhinoliner from plastic body panels
-left rhinotank in place ;-}
-cleaned carb with bucket of gunk (twice)
-replaced petcock diaphragm (p/n 43028-1033)
-upgraded subframe bolts
-checked valve clearances, all in the middle of spec
-changed front and rear tires
Not sure if the above info will help, but rather have too much than the reverse. Took it by my neighbor who has more engine experience than I and he said it sounds like a metal on metal noise that may be a spun bearing.
I understood a bearing might need a replacement when I got it, and it was factored into the price. At this point I'm trying to confirm that diagnosis and figure out a plan of attack.
My thoughts are:
1. Drop entire bike off at my local mechanic
2. Take engine out and have local mechanic/other pull bearing(s)
3. I attempt to pull the bearing(s)
I'm reasonably confident in my ability to take the engine apart, determine that it's too big a job and then go with option #2. Since the case would be cracked it would be a perfect time to throw a hop up kit in there (685, 705, whatever), but I'm leaning towards getting it running and then playing with it.
Anyway, your feedback is appreciated.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 08-07-2010, 01:30 PM   #2
Huzband
Team Dirt
Huzband's Avatar
Oddometer: 2,658
That sounds bad. Based on what I heard, I wouldn't run it until it was pulled apart & fixed.
Whether or not you do it yourself is up to you, but I highly recommend it. Having someone else do it would easily exceed any return value on the bike. I'd also hold off on a top end kit till the bottom is squared away.
Danny
'03 Golden Retriever (Farley, beloved & missed)
'08 R12RT
'90 RM250
'93 Aprilia 280R Climber
Huzband is offline   Reply With Quote
Old 08-07-2010, 01:34 PM   #3
Kjharn
Hrmph?
Oddometer: 1,124
My KLR sure never sounded like that
-Kyle
Kjharn is offline   Reply With Quote
Old 08-07-2010, 01:43 PM   #4
Pigford
British
Pigford's Avatar
Oddometer: 743
Eek
Check cam chain tension & doohicky
Does it still make same noise with clutch in/out ???
Any smoke????
Pigford is offline   Reply With Quote
Old 08-07-2010, 05:07 PM   #5
Chicken Helmet
I'm A Stumper™
Chicken Helmet's Avatar
Oddometer: 3,879
And Danny knows these as well as anybody locally.
Sean
1988 KLR 650 Parts For Sale PM for Details 2009 KLR 650 1994 DR 350
Originally Posted by RonSavage View Post
KLR's are chick magnets.
Chicken Helmet is offline   Reply With Quote
Old 08-07-2010, 05:25 PM   #6
DirtyDog
Lust for dust...
DirtyDog's Avatar
Oddometer: 6,052
I can't really tell from the video. Sorry.
Try to isolate the location of the noise by focusing your hearing somehow. Put in one earplug and use a paper towel roll or something on the other ear and maybe it will help you locate the actual source. Just an idea. Never tried it.
Otherwise, you'll be disassembling blindly.
... grease, grit, and mud are runnin' in my blood.
DirtyDog is online now   Reply With Quote
Old 08-07-2010, 07:08 PM   #7
tofire409
Geared up and ready.
tofire409's Avatar
Oddometer: 512
The 685 or 705 would make sense if you are getting the piston exposed.
As for the bearing, crack the cases your self, as you spin the "fly wheel" to TDC listen for noise. How was the tension on the cam chain and guide chain? Was there room for the doo to take up slack?
I don't know about the shops around you, but it could be fairly expensive to have them repair it.
Good luck, I hope it's easy for you.
Damn I wish all roads were dirt.
Current ride : 2011 White F800GS, 9500 km's
Past ride : 2006 KLR with 41,000 kms -gone to a good home-
Toronto to Maine and back
Toronto to Boston -The Long way
tofire409 is offline   Reply With Quote
Old 08-07-2010, 07:46 PM   #8
jsmithy
ADV Poser
jsmithy's Avatar
Oddometer: 190
Any smoke????
This was my thought. I've heard one carry on like that with a broken doohickey. Pretty easy to check if you haven't done it yet. Might start there.
jsmithy is offline   Reply With Quote
Old 08-07-2010, 08:29 PM   #9
newcastleadam OP
Artful Tagger
Oddometer: 3,422
Thanks for the feedback. Here's the game plan for the morrow.
1. Check doohickey
2. Drain oil, check for metal
3. Check under clutch cover (believe may be able to eyeball some bearings; easier than other side)
4. Start disassembly
Adam
Old 08-08-2010, 07:17 AM   #10
guns_equal_freedom
Oddometer: 5,051
Spun bearing? KLR?
Have you looked at the engine diagram of a KLR650?
I suggest that you look at Bike Bandit and their parts breakdown.
Did you get any metal out of the engine, oil or filter?
Shavings, chunks, bits?
Shadetree mechanic tip -
Take a long screwdriver and put the tip on the cylinder head cover, then put your ear to the handle (you'll need a long screwdriver).
More than likely you will be able to isolate the noise to a specific area of the engine.
I would be doing one of four things - Looking at rebuilding the engine, looking for a good used engine, finding a KLR that's in better shape and using your current KLR as a parts bike and finally I would hold the throttle WFO until whatever is making that noise lets go.
guns_equal_freedom is offline   Reply With Quote
Old 08-08-2010, 07:27 AM   #11
leonphelps
Rode TAT/Prudhoe Bay
leonphelps's Avatar
Oddometer: 1,023
My advise: NEVER START THE ENGINE AGAIN until its fixed. That sound is more stuff getting screwed up with each revolution of the piston/crank/whatever else.
bite the bullet and pull the engine and take it apart. Its got almost 30K on the engine. Its time take it all apart to give it a once over.
Use it as a learning experience and do it yourself. There is a TON of knowledge on here and people with help you if you have any questions.
leonphelps is online now   Reply With Quote
Old 08-08-2010, 07:34 AM   #12
john0270
Blood soaked RIDER
john0270's Avatar
Oddometer: 17
#1 thing not to do is to take it to a mechanic in pieces. At least let him hear it run first before pulling it out of the frame, It might be something he can fix in the frame.
The k&n air filter sticker is a bad bad sign if its actually been driven off road.
At least turn the engine over by hand(counter clockwise on the rotor bolt) and just listen or feel for something.
Planning trip to Baja in august-september(will be at the EM tech day in Sandeigo aug. 21) PM me with any tips and places of interest.
john0270 is offline   Reply With Quote
Old 08-08-2010, 11:11 AM   #13
Gypsysteel
Gypsysteel's Avatar
Oddometer: 21
Originally Posted by guns_equal_freedom
Spun bearing? KLR?
I piece of old water hose with a stick shoved in it works too, my grandfather taught me that one
Gypsysteel is offline   Reply With Quote
Old 08-08-2010, 11:24 AM   #14
newcastleadam OP
Artful Tagger
Oddometer: 3,422
My first attempt at making a doohickey wrench failed. While I wait for the heat to die down, let me answer a few questions.
1. Any metal out of the engine? Just drained the oil after running it for 4 miles; no metal on magnetic drain plug nor after running a magnet through the drained oil. Have not checked oil screen. Oil screen after initial oil drain was fairly clean; no significant metal.
2. No exhaust smoke.
3. Same noise with clutch in/out
4. Have not visually checked doohickey yet, need to reweld wrench.
There seems to be two camps: a) take engine out and repair and b)swap with good engine, parts bike it, etc. I've looked around on eBay and there are several complete bottom ends available from 06 and 07 models from $160-$280 delivered. Further details would be required but that option is interesting (new cases with good bearings versus swapping bearings in old cases). As I stated in the OP, I got it for a great price with the understanding that it would require some $$ to fix. So kinda on track ;-}
Again, thanks for the feedback.
Adam
newcastleadam screwed with this post 08-08-2010 at 11:29 AM
Old 08-09-2010, 04:06 PM   #15
CA Stu
CA Stu's Avatar
Oddometer: 42,649
What is up with head pipe?
Do you have a huge exhaust leak?
CA Stu is offline   Reply With Quote
Times are GMT -7.   It's 12:03 PM.
