Old 08-07-2010, 04:24 PM   #1
HayBailEY OP
Groovy
HayBailEY's Avatar
Oddometer: 32
Scotts and HDB
Howdy!
Just wanted to share that the HDB topclamps mates to the Scotts damper kit just fine.
HayBailEY is offline   Reply With Quote
Old 08-08-2010, 11:46 AM   #2
GeckoRider
GeckoRider's Avatar
Location: Oakland, CA, USA, Thrid Rock from the Star Sol
Oddometer: 446
Wanted a point of clarification. Some instructions I have seen online for mounting the Scotts indicate that you need to do some cutting and/or welding to mount the tab to the bike. I am not sure if this comes from copying and pasting instructions for other models of the Scotts or if it is true of the F800GS version. Can you confirm or deny?
F800GS Mag/Black 2009 "Faucon GriS"
Farkles; Garmin GPSMap478 in a TT cradle, Airhawk seatpad, Pivot Pegs, SW-motech bars, MOD skid plate, Altrider headlight guard, HDB handguards, Maier Mudguard.
GeckoRider is offline   Reply With Quote
Old 08-08-2010, 12:01 PM   #3
gr8ridn
gr8ridn's Avatar
Oddometer: 405
Renazco Racing responded to this in the vendors section. In essence they stated the F800GS kit is a straight bolt in installation requiring no cutting or welding. You are probably right, the cut and paste was applied incorrectly to this kit. On Renazco's site it now states the F800GS kit is a bolt in installation.
2014 R1200GSAW
Racing Blue, Premium Group, DWA
gr8ridn is offline   Reply With Quote
Old 08-08-2010, 01:04 PM   #4
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,795
The only modification needed on my bike was to grind a little plastic on the black trim piece that mounts over the key.
Mine was the prototype, so it is possible the design was changed.
johngil is online now   Reply With Quote
Old 08-08-2010, 01:14 PM   #5
Renazco Racing Store
Parts, Gear & Such
Renazco Racing Store's Avatar
Oddometer: 242
We were in entirely too much of a hurry to get the new mount kit on the site, and committed the copy/paste error when grabbing the text from Scotts Performance.
Bolt-on. One of our guys tells me it took him about ten minutes, half of which was spent trying to get the lid off his beer.
Renazco Racing
Online store: http://www.renazcoracing.com
Phone (0800-1600 Mon-Fri, Pacific or off-hours if we can take your call): (707) 902-DIRT
Email: store@renazcoracing.com
Renazco Racing Store is offline   Reply With Quote
Old 08-08-2010, 03:54 PM   #6
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 693
I just did this install a little while ago. You have to trim/sand/grind about 1/8 of an inch from the black plastic part of the faux tank in order to accommodate the torx security bolts that hold the ignition as those bolts secure the pin for the stabilizer. No welding necessary. Doesn't take long and the alteration is hard to see if you are not looking for it.
Ride on.
:: Furious Basterds: Velox, Vehemens, Oblivio
:: "For those who don't understand, no explanation is possible. For those who do, none is necessary."
Bartron screwed with this post 08-08-2010 at 10:30 PM
Bartron is offline   Reply With Quote
Old 08-08-2010, 05:22 PM   #7
GeckoRider
GeckoRider's Avatar
Oddometer: 446
Good news then, very doable by my standards. Have to work some more overtime I guess.
Old 08-08-2010, 05:42 PM   #8
anodyne
anodyne's Avatar
Oddometer: 235
Piece of cake ... aside from losing one of the the clips/fasteners (part# 46637658638) for the center cowl somewhere in the bike (can't seem to shake it loose or find it with magnet). Slight use of dremel tool on plastic center cowl. Instructions are easy to follow.
anodyne is offline   Reply With Quote
Old 08-08-2010, 05:47 PM   #9
GeckoRider
GeckoRider's Avatar
Oddometer: 446
Oh I remember another question I had. The Scott kit comes with a riser no? If so it was about 20mm or what is it? If that is the case it would kill two birds for me as I feel like the handle bars are a tad too low when I am standing on the pegs so it would be just about perfect 20mm or more higher.
Old 08-08-2010, 06:15 PM   #10
Hedge36
Chasing parts.
Hedge36's Avatar
Oddometer: 44,982
The SUB mount jacks the bars up about 20mm and forward about 3mm.
"When I joined ADV I was a fuckin brain surgeon, but 24,745 clicks from you and I can barely wipe my ass." Bender, former brain surgeon.
Hedge36 is offline   Reply With Quote
Old 08-08-2010, 09:10 PM   #11
OlyRider
Oddometer: 1,259
Scotts
Bought mine from Renazco. Installed it today. Went on very easy with a little grinding on the black plastic covering the security bolts. Had to grind five or six times so i didn't remove any unnecessary material. But nobody would notice the difference without removing the cowl piece and examining it.
Thanks, Renazco!!!
Olyrider
Ob-la-di...Ob-la-da
OlyRider is offline   Reply With Quote
Old 08-09-2010, 03:51 PM   #12
Parts, Gear & Such
Oddometer: 242
Thanks, Renazco!!!
We'll have to get together some time in the next couple of weeks so I can see this beast firsthand.
Renazco Racing
Old 08-09-2010, 11:12 PM   #13
OlyRider
Oddometer: 1,259
Dampers
Hey Scott,
So far I have the damper and the Vario levers installed. Also, I put on the Wunderlich lowered pegs, and the new Aerostich tinted screen. Going up to Seattle Wednesday for Alt-Rider to put on their crashbars and belly pan. Stopping by Touratech to get a few farkles. Put on the Woody's superlace front wheel yesterday. Waiting for my Renazco seat & LV pipe. Adding the Denali LED aux lights. I put on the LED blinkers today from Weiser. I think there's more, but I can't remember!
Paul
Olyrider
Ob-la-di...Ob-la-da
Old 08-09-2010, 11:45 PM   #14
klarue
klarue's Avatar
Oddometer: 235
Hey Scott,
Paul
Jumpin' Jehosophat!! That sounds like a foot-stompin' combo!!
'09 Magnesium F800GS - the classic
klarue is offline   Reply With Quote
Old 08-10-2010, 12:01 AM   #15
Hedge36
Chasing parts.
Hedge36's Avatar
Oddometer: 44,982
And when I have him test/review the FasstCo Flexx bars...
Times are GMT -7.   It's 03:11 PM.
