Old 08-09-2010, 11:09 PM   #16
OlyRider
Oddometer: 1,297
Farkles
Yep....and the hyperpro springs and 15-tooth sprocket have helped, but I'm going to try the G2 throttle tamer.
Olyrider
Ob-la-di...Ob-la-da
OlyRider is offline   Reply With Quote
Old 11-06-2010, 11:53 PM   #17
bumbee800
Oddometer: 69
top clamp bolt pattern dimensions
What is the appropriate dimensions of the bolt pattern for the HDB top clamp that mates withe scotts risers? I am planning on ordering the scotts stabilizer and HDB hand guards but do not know what dimension to order for the top clamp. Any one who has the HDB and scotts please post the dimensions. I think they should be etched into the HDB top clamp.
thanks in advance
bumbee800 is offline   Reply With Quote
Old 11-09-2010, 05:49 PM   #18
Scotts Performance
Oddometer: 42
Scotts bolt pattern
thanks in advance
The Scotts barclamp bolt spacing is 98mm from hole to hole for the F800-
Thanks-
Eric
Scotts Performance Products
818-248-6747
www.scottsonline.com
Scotts Performance is offline   Reply With Quote
Old 11-11-2010, 01:11 AM   #19
OldCrock
OldCrock's Avatar
Oddometer: 111
Just do do it!
To quote bartron.
" just did this install a little while ago. You have to trim/sand/grind about 1/8 of an inch from the black plastic part of the faux tank in order to accommodate the torx security bolts that hold the ignition as those bolts secure the pin for the stabilizer. No welding necessary. Doesn't take long and the alteration is hard to see if you are not looking for it."
This is the same actions needed to fit the Ralleye Moto Steering Damper.
Don't be afraid to take to the plastic with a small grinder, which ever damper you choose, the result is worth far more then the $$ you have outlayed. Every person that takes a F800GS off road should have a damper of some brand. makes the ride %100 better
Cheers from someone that has one.
OldCrock is offline   Reply With Quote
Times are GMT -7.   It's 01:38 PM.
