Old 11-02-2012, 11:08 AM   #211
backdrifter OP
Wannabe rider
backdrifter's Avatar
Oddometer: 1,366
I went out in the garage to straighten out the swingarm this morning. Last time I worked on the swingarm was when I installed the oil seals. I had put everything together loosely, but I still managed to strip out the pivot pin locknut, and I had forgotten to install these spacers:
Getting the stripped locknut off of the pin wasn't too tough, but took some grunt. I was worried that the pin itself might be damaged too, but it looks like I lucked out:
The new nut screwed right on without issue:
You may recall my girlie bandage from yesterday. I wasn't sure what I had cut myself on yesterday. I was working on removing the forks, I never felt anything, and all of the sudden my finger was gushing blood. Well it happened again today, this time on my thumb:
Sorry for the shaky picture, that photo was taken left handed! This time I figured it out though. Turns out that hole cut in the front axle has VERY sharp edges! Lesson learned....
I installed the swingarm, spaced it evenly as measured by a Vernier caliper, and then tightened the pins and locknuts down. The bike is now ready to accept the wheels and become a true roller again. Wooohooo! It will be the first time in over a year that the bike has been able to roll around without the help of my Craftsman jack!
The wheels aren't quite ready yet (they still need to be trued), but I couldn't resist throwing them on and taking a look:
Ah yes..... not too shabby at all! I'm very happy with my decision to powdercoat the rims black. It was a decision that I went back and forth on for long time, and one that I'm happy with. It's one of the few subtle diversions from the stock look (others being the Euro low bars, and I'm going to ommit turn signals and use a much slicker tail light). Just different enough to clean up the lines and make the bike look a bit more muscular, in my opinion.
And finally, I couldn't leave well enough alone, so I went ahead and ordered a new top not. Not installed yet, but you get the idea:
Next I'm going to try to rig up a stand to use in an effort to true the rims on my own. If I'm successful, the bike may be a roller by early next week!
"We are very good at preparing to live, but not very good at living."
-Thich Nhat Hanh
1973 BMW R60/5:
http://www.advrider.com/forums/showthread.php?t=608166
backdrifter is offline   Reply With Quote
Old 11-06-2012, 01:16 AM   #212
Packer
Packer's Avatar
Location: Scotland, wonderful biking when it's dry (rarely)
Oddometer: 333
That is some learning curve you've been riding. The satisfaction you'll feel on the first sunny ride out will make you feel as though your vocabulary is impoverished.
Can't you just fit the bearings and true the wheels in the frame?
Packer is offline   Reply With Quote
Old 11-06-2012, 08:02 AM   #213
backdrifter OP
Wannabe rider
Oddometer: 1,366
Hi Packer - you're not kidding, I've learned more than I ever expected to when I started this project. It's funny to think back to how clueless I felt when I first removed the valve covers. I'm still learning and I'm certainly no guru, but I'm starting to feel like I know this bike inside and out, which is exactly what I was hoping for. I've worked on plenty of other bikes, but never at this deep of a level. It's been a blast! And I'm sure you're right - that first sunny ride is almost going to be a life changing event!
I definitely think I could true the wheels on the bike, but I'm thinking it will be easier to set up a stand and ensure that the axle is level on the stand than it would be to level the entire bike. The bike is just strapped to a jack right now. Plus, it's getting cold here, and as you can tell from all the pictures, I prefer to work in the comfort of my kitchen (when the wife isn't home )!
Well, I wasn't going to post this, but decided I truly want to document every step of the build, so here we go. I'm a complete dumbass. I went into the garage the other day to look at the wheels and start contemplating how the hub internals went back together when I noticed that the rear wheel (shown mounted loosely on the bike above) didn't have a drive spline. What did I do wrong? Yep, you guessed it - I laced the rear wheel to the front hub and vice versa. Damn! Oh well, honestly, lacing was kind of fun and I could use the practice. And in the long run, it actually ended up being beneficial for a few reasons. First, I ended up taking the hubs in to a local machine shop to have the inside bearing races removed. I'm confident they would've banged up the rims if the wheels were still together. As it is, they put a few scratches in the hubs. Secondly, I ended up placing the hubs in the oven to heat them up so the new bearing races would be easier to install. It worked like a charm, and I wouldn't have been able to do this with the rims laced up.
I pulled out my bag of goodies and started trying to figure out how it all went back together. The wheels were some of the few items that I didn't label and organize as well as I should have during disassembly. This is mainly because I was in a rush to get the wheels to the powder coater, so I didn't remove everything systematically and place all of the parts on a string in order as I should have. It took me a few times of trying out different arrangements before I got the correct "stack". Speaking of, has anyone else noticed that the Clymer manual is absolutely WORTHLESS for /5 hub/wheel details? I have no idea what they were showing, but they had LOTS of parts that I didn't have, and I had parts that they didn't show. I ended up remembering that Papa had had a very old Haynes manual, so I pulled it out and it was a huge help.
Once I started to get a feel for the stack arrangement, I put the hubs into the oven at 200F.
Then I pulled the wheel bearings out of the freezer and packed them with grease:
The wheel bearings and the grease in the hubs looked fresh, which made me think that someone had rebuilt the wheels fairly recently (which would have been 5 years ago at the most recent). I still replaced the bearings, cleaned out the old grease, and packed everything with Bel Ray waterproof grease for good measure.
With the hubs hot, I installed the bearings and all of the hub components and then let them sit outside for a bit to get back to room temperature. Once they had cooled, I installed new endcap gaskets and bolted the encaps down with shiny new stainless bolts (with anti-seize, of course).
One:
T'other:
And then it was back to square one with lacing the wheels:
I'm getting faster and faster, though, and in half an hour I had both rims loosely laced up again.
So that's where I currently stand - the wheels need to be trued, and then I can mount the tires, and then it will finally be a roller again! I'm hoping to buy a spoke wrench and attempt trueing the rims tonight. Then I need to get to a shop and buy some tubes and the rubber ring that protects the tubes from the spokes inside of the rim. Even with the setback of lacing the rims to the wrong hubs (), I still think I'm on schedule to have a roller by this weekend....
-Thich Nhat Hanh
1973 BMW R60/5:
backdrifter screwed with this post 11-06-2012 at 08:12 AM
Old 11-06-2012, 08:26 AM   #214
backdrifter OP
Wannabe rider
Oddometer: 1,366
I also won an auction for these handle bar mounts yesterday. Mine have some unusual issue with the aluminum actually cracking and fraying. I've never seen it before, but it's something that couldn't just be buffed or polished out.
I've been looking for some for quite a long time. Some of the decent ones I've seen have gone for $75 or more. These look better than most that I've seen and I got them for $29 including shipping.
These are the eBay pictures, I'll post some more of my own once I get them. They'll need a bit of polishing, but they're in much better shape than my current ones.
-Thich Nhat Hanh
1973 BMW R60/5:
Old 11-07-2012, 05:40 PM   #215
backdrifter OP
Wannabe rider
Oddometer: 1,366
Went shopping today and came home with everything needed to try to true the rims and then mount the tires.
New tubes front and rear, and the rubber tube protectors:
Small metric wrench set:
5.5mm wrench that will act as my spoke wrench:
Then I started working on my stand:
I used a level to ensure that it was all true, and used the old axles because I didn't want to scratch up the shiny new stainless ones.
I mounted the front wheels, got all of the nipples snug, and then made a few reference marks on the wheel at 180 degrees. From there, I would put two turns on three spokes at a time, rotate the wheel 180 degrees and put two turns on the spokes at the opposite end of the wheel. I continued this way until I had made it around the wheel. Then I went back and tuned each spoke until the notes they gave off when rapping them with the wrench were all the same. I've played guitar for 24 years and have a very good ear, so I'm sure I had all of the spokes at very even tensions (this, of course, assumes that each spoke is exactly identical, as variances in spoke length and diameter would also affect the tones). When I was all done with the front wheel and happy that it the spokes were under even tension, I gave it a good spin and used a straw mounted to the stand and lined up next to the rim for a reference point . Gave it a good spin and..... disappointment. Despite my best efforts, the wheel wobbled more than I would have liked. All I have to compare it to are some YouTube videos I watched about trueing rims, however, there is no doubt that theirs turned out much better than mine.
I was wondering if it was still good enough, so I decided to try the rear rim and see if I could do better. Nope, worse. Damn. I then played around with loosening the areas that I thought would need to be loosened, and tightening the opposite areas in an effort to straight the part of the rim where it seemed to wobble. I may have made improvements on both wheels, but I never felt like it was good enough.
I'm disappointed that I couldn't pull this off, especially since I would've been able to mount the tires and had a roller tonight. But, I'm glad I tried it, and no harm, no foul. I've come too far to cut corners now, and I just didn't feel like I was getting it right.
I'll call a few local shops tomorrow and see what they charge to true up two rims. Hopefully they can do them quickly so I can keep moving.
-Thich Nhat Hanh
1973 BMW R60/5:
backdrifter screwed with this post 11-08-2012 at 02:38 PM
Old 11-07-2012, 07:37 PM   #216
elite-less
As above, so below
elite-less's Avatar
Oddometer: 540
It's a finicky process. Took me about 2 hours per rim to true the wheels on my /5 for the first time.
I would attach a dial indicator to your setup. It'll make truing the side-to-side and up-and-down runout of the rim much easier.
Also, you need to measure the rim offset when truing /5 wheels. This will ensure both wheels are inline, when mounted on the bike, and adequately center between the front forks and rear swingarm. To determine the offset, just place a long straightedge on the drum side and use a caliper to measure the distance between the straightedge and rim. Whomever trues your wheels will need the below reference information.
Hope this helps and keep up the great work!
Slash 5 Revive
elite-less is offline   Reply With Quote
Old 11-08-2012, 12:51 PM   #217
backdrifter OP
Wannabe rider
Oddometer: 1,366
Thanks, elite-less, I appreciate the input. I was getting motivated to give it another shot tonight, but decided to make a few calls to see what the local shops would say. The local authorized BMW dealership said they don't have much luck trueing rims and wouldn't perform the work.
Really? With all of the BMW models past and present that have spoked wheels, they can't true a rim? Crazy.
So then I called a small local Triumph dealer. The gentleman there was very friendly and seemed very knowledgeable. He said he's been trueing rims for 30 years and could have it done in a day or two. I asked how much and he estimated $30 per wheel. SOLD!!!!
I'm dropping them off later today.
-Thich Nhat Hanh
1973 BMW R60/5:
Old 11-08-2012, 02:37 PM   #218
backdrifter OP
Wannabe rider
Oddometer: 1,366
Came back from dropping the rims off to be trued and my new handlebar risers had arrived. Look Ma, I can steer now!
-Thich Nhat Hanh
1973 BMW R60/5:
Old 11-08-2012, 03:20 PM   #219
brocktoon
brocktoon's Avatar
Oddometer: 257
That's some good info, elite-less. I need to have my wheels laced and trued. The shop nearest me that trues wheels is a motorcycle racing shop. Awesome guys, but they're not too concerned with Airhead arcana. The last time I was in they spent a good 30 minutes telling me why I should ditch the stock wheels on my /5 and use 17-inch rims instead. If I end up using them to do my wheel-building, at the very least I know I can hand them that sheet and ask them to follow it to the letter.
Let us know how the Triumph guy does. Did you give him the sheet?
brocktoon is offline   Reply With Quote
Old 11-09-2012, 08:51 AM   #220
backdrifter OP
Wannabe rider
Oddometer: 1,366
Yep, I brought the sheet in with me and gave it to them. Thanks elite-less, I'm sure that will be a big help!
There was a chance that he'd have the wheels done today. I'm not going to hold my breath, but I do hope I can pick them up today.
-Thich Nhat Hanh
1973 BMW R60/5:
Old 11-10-2012, 08:49 AM   #221
sdpc2
Just another Rally Rat
sdpc2's Avatar
Oddometer: 1,143
Hey Backdrifter
I've enjoyed reading your thread and just wanted to say that you are doing Jim very proud. I'm sure that riding that old girl will provide you a great deal of joy once she is done. Until then, i will be following along.
sdc
'12 R1200GS Rallye Edition, '99 R1100GS,'77 R100S
I lower my passenger pegs for those riders that have gone before me
sdpc2 is offline   Reply With Quote
Old 11-10-2012, 09:12 AM   #222
JonnyCash
turd polisher
Oddometer: 1,522
I just sold a set of those on ebay. I got one f-ing bid, $5 for shit's sake. I also got shit money for some very nice Guzzi valve covers too. I must be doing something wrong. Damn!
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 11-10-2012, 12:11 PM   #223
backdrifter OP
Wannabe rider
Oddometer: 1,366
sdpc2 - thanks much for the kind words, glad to have you reading along!
JohnnyCash - did you post them for sale here? I would've bought them from you in a second! I was really happy to find the ones I did for under $30. I've seen crappier ones go for far more.
I went out in the garage to prep the engine for swapping out the clutch water pump seal, and rear main seal, which I hope to do tomorrow. I decided to go ahead and remove the old oil filter and replace it with the new one, and put the new cover gasket in as well. I leaned the engine over as shown below. \
I pulled on something just a bit and the whole damn cart started to go over. Luckily, I was able to catch it before anything hit the ground. I quickly moved the engine to a less precarious position and moved on! I was shaken though - I don't want to think about what would have happened if the engine went all the way down.
I was surprised to find this underneath the oil filter cover:
Old filter. Oil didn't look too, too bad, but it was definitely time.
Spent the majority of my time scraping the old oil filter cover gasket off. It was a bear.
While I was thinking about it, I decided to start soaking the rear main seal in motor oil. I'll let it sit like this overnight, which I've read makes installation easier.
New oil filter about to go in:
New gasket, and then buttoned up:
Then onto the oil pan. I repositioned the engine again, this time making sure there was no chance of the cart tipping over!
I saw another inmate do this (my apologies to whoever I stole the idea from). Seemed like the cool thing to do, so here you go!
I was afraid the oil pan gasket would suck after the oil filter gasket, but it came right off with a razor.
Degreased and shined up a bit:
This is probably the cleanest this oil pan has been in 40 years, or will be for another 40 years!
And loosely back together:
I still want to do a bit more today, but it's a GORGEOUS day, so I'm off to spend some time with the wife and daughter. Hopefully more to come both today and tomorrow.
-Thich Nhat Hanh
1973 BMW R60/5:
Old 11-11-2012, 09:09 AM   #224
backdrifter OP
Wannabe rider
Oddometer: 1,366
Dead in my tracks today. Just realized I don't have the flywheel bolts, which can't be reused, so no point in going and disassembling the entire clutch/flywheel assembly. I have two BMW shops locally that might have the parts, neither of which is open.
Looks like a good day to call it and sit on the couch watching football.
-Thich Nhat Hanh
1973 BMW R60/5:
Old 11-11-2012, 01:14 PM   #225
backdrifter OP
Wannabe rider
Oddometer: 1,366
I guess I'm too ADD to sit on the couch watching football all day. I wanted to get something done on the R60. It's nothing major, but I decided to clean up the transmission housing. I don't have any great "before" pictures, but suffice it to say, it was dirty just like everything else has been.
Before:
I was pretty lazy on the photos today, but I used an engine degreaser and a wire brush, then dried and cleaned it off, and then used a drill with a wire brush attachment. The drill works the best by far. It's dirty work, but it cleans very quickly.
During, you can see what's been brushed and what hasn't:
After:
There are some delicate and hard to reach areas:
I plan to use a small Dremel wire brush attachment to clean those areas.
It's not perfect, but it's much better than before, and it will look perfect again after applying some Rub N' Buff.
OK, NOW it's time or some football and beer!
-Thich Nhat Hanh
1973 BMW R60/5:
Times are GMT -7.   It's 12:35 AM.
