Old 10-18-2011, 06:44 AM   #106
backdrifter OP
Wannabe rider
backdrifter's Avatar
Oddometer: 1,364
I had a couple of relatively easy work weeks the past few weeks, which is why I was able to jump back in and start making progress. I'm a bit more strapped for time now, but thankfully I moved far enough along while I did have free time to get myself motivated again. Case in point: I woke up at 5:30 this morning to spend an hour or so getting a few things done. And plan to do it again tomorrow.
Here's the stainless bolt kit I got from BMW Hucky. I'm very happy to have a complete new nut and bolt kit and to not have to worry about cleaning the old ones and sourcing new ones where needed. I know there is a heated debate about the usefulness of stainless as fasteners, but I work in industrial sales and have seen stainless fasteners used on far larger and more powerful equipment than my little R60. I have seen failures too, but I've found that if you use anti-seize and torque to the correct value, you'll be just fine. So that's what I intend to do.
The kit is very nice. It came in a box that made it look like it was going to be all loose pieces. I never opened it until yesterday. If I had, I could have saved myself some time during disassembly. I removed, bagged, and labeled every single nut and bolt from the bike. The pieces in the kit are so well grouped and labeled that I probably didn't need to. Oh well, better safe than sorry, right?
So, this morning's goal was to remove the tires and disassemble the rims/hubs. Remembering lessons I've learned in the past, I decided to start on the rear rim and tire, figuring it would be the more difficult of the two.
No problem!
Then on to the front one, which was a bear. Go figure! Not sure what it was, but the tire wouldn't give. The little tire that could:
Persistence prevailed:
I had planned on reusing the tires on the bike. They were a bit old, but they appeared to be in good shape. Today's inspection revealed this on the front tire:
Yep, some dry rot. Oh well, what the hell - what's a few hundred more dollars for some new shoes?
The next step was to get the angle grinder out and cut the spokes, since I'm going to replace them with new stainless spokes anyways. I'd much rather do this job outside than get the garage dirtier than necessary, and unfortunately it is pouring rain this morning, so I called it quits.
I'm hoping for dryer weather later today so I can finish the job. Then it's on to masking and cleaning everything to get ready for blasting later this week.
"We are very good at preparing to live, but not very good at living."
-Thich Nhat Hanh
1973 BMW R60/5:
http://www.advrider.com/forums/showthread.php?t=608166
backdrifter is offline   Reply With Quote
Old 10-18-2011, 03:47 PM   #107
backdrifter OP
Wannabe rider
Oddometer: 1,364
The rain let up, so I went back out to finish the job. Gotta love angle grinders, this would have been an hour job (or more) if I had removed each spoke individually. Instead it took 15 minutes. One down:
On to the next:
I had a sheet lying under the rim so it wouldn't get scratched while rubbing against the concrete. It caught fire.
I put it out and kept going. Done:
And done:
I'm a visual kind of guy, so I decided I needed to tackle some kind of aesthetic project to make me feel good about the day. I decided to go for the lower triple clamp. I was happy with the results on the fork tubes, so I planned to use the same method - wire brush attachment on the drill, clean, and then some Rub N' Buff. Before (sorry for the sideways photo):
After the wire brush:
There were some spots that I couldn't reach with the drill or a hand wire brush, so I decided to reserve this for blasting too, and apply the Rub N' Buff afterwards.
That's all for tonight. Time for a beer!
-Thich Nhat Hanh
1973 BMW R60/5:
Old 10-19-2011, 01:29 PM   #108
KLRUSERIOUS?
Farkle-whore
KLRUSERIOUS?'s Avatar
Oddometer: 2,299
Nice work! Keep them pics comin!
KLRUSERIOUS? is offline   Reply With Quote
Old 11-18-2011, 12:20 PM   #109
backdrifter OP
Wannabe rider
Oddometer: 1,364
Time for an update.
I cleaned up the lower triple clamp and applied Rub N Buff. Looks brand new!
Cleaned:
Rub N' Buffed:
Then I replaced the steering stem bearings. Getting the races out was a pain, but they finally came loose. I slathered the new bearings in this great stuff:
While pressing the inner race down onto the steering stem, I must've pushed in a wrong direction and suddenly I had an empty bearing cage and 21 little tapered rollers rolling all around my garage. I was discouraged, but determined to fix it.
Tedious work:
This is going to require some moral support:
Got it back together and started assembling the triple clamps and forks.
I plan to clean or replace the triple clamp top nut. It looks pretty bad, I may need to replace it. I'm very happy with everything else though - it's starting to look pretty good!
-Thich Nhat Hanh
1973 BMW R60/5:
backdrifter screwed with this post 11-18-2011 at 12:36 PM
Old 11-18-2011, 12:44 PM   #110
old2wheeler
Former nb
old2wheeler's Avatar
Location: La Veta, CO except for the wind, it'd be heaven
Oddometer: 720
understatement!!!!!!!!!!
"Pretty good."
Uuummm, I'd give it an "approaching motorcycle porn!" rating. Beeeu-teee-ful! Yea, you've made it so purty, that nut will HAVE to go...
Roderick (Rod) {AKA o2w} House
DEFINITION OF A VETERAN
A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
old2wheeler is offline   Reply With Quote
Old 11-18-2011, 06:41 PM   #111
backdrifter OP
Wannabe rider
Oddometer: 1,364
Thanks old2wheeler! Yeah, that old corroded nut will have to go, won't it?
I should post some photos of the gauges too. I sent these to our very own Terry (Wirespokes) for some rejuvenation. Unfortunately I didn't remember to take a good "before" picture, but rest assured that they look a whole lot better now! Nearly new, actually. Great, great work and Terry was an absolute joy to deal with. I can't recommend him highly enough!
Thanks again, Terry!
-Thich Nhat Hanh
1973 BMW R60/5:
Old 11-21-2011, 07:58 AM   #112
KLRUSERIOUS?
Farkle-whore
Oddometer: 2,299
[QUOTE=backdrifter;17335356]Thanks old2wheeler! Yeah, that old corroded nut will have to go, won't it?
Hey Backdrifter, can we get an update photo of what she looks like so far? I don't wanna hijack your thread so just tell me to bugger off if you want to maintain the suspense until the final unveiling.
But so far this is looking like a great build and I am curious as all hell!
Old 11-22-2011, 07:27 PM   #113
backdrifter OP
Wannabe rider
Oddometer: 1,364
Thanks for the interest! Nope, I'm not trying to build suspense or anything like that. The last pictures were all relative close-ups because I was trying out my new 50mm camera lens and I didn't have enough room to back up and get the whole bike in the shot!
I'll try to get a few more photos up in the next day or two. I just got swingarm bearings in the mail, so I hope to install the swingarm and shocks soon. Then it will almost look like a rolling chassis. Little by little!
-Thich Nhat Hanh
1973 BMW R60/5:
Old 11-22-2011, 07:41 PM   #114
Dusty_Bottoms
Adventurer Ordinaire
Dusty_Bottoms's Avatar
Oddometer: 842
Looking sweet.
Somehow Papa knew you were the only one that would do anything with her.
How'd those olde guys get so smart?
Dusty_Bottoms is offline   Reply With Quote
Old 01-29-2012, 11:00 AM   #115
KLRUSERIOUS?
Farkle-whore
Oddometer: 2,299
Updaaaaaaaaaaaaaaate!!!!
Old 02-01-2012, 07:34 AM   #116
backdrifter OP
Wannabe rider
Oddometer: 1,364
Thanks for the inquiry, but unfortunately I don't have any updates just yet. I took a hiatus on the project to get through the money perils of Christmas and just haven't started up again. Thanks for the wake up call though - I need to get going! Spring is right around the corner and I want to be riding!
-Thich Nhat Hanh
1973 BMW R60/5:
Old 03-26-2012, 04:54 PM   #117
KLRUSERIOUS?
Farkle-whore
Oddometer: 2,299
Knock knock....who's there....spring time
Old 04-30-2012, 11:25 AM   #118
backdrifter OP
Wannabe rider
Oddometer: 1,364
Damn if that isn't right! And guess who's not riding yet? Yep, you guessed it - ME!!!
Oh well, I've given up on getting frustrated with myself. My motivation waxes and wanes. I know the project will get done eventually and I just ride the tide when the motivation is there. Speaking of, I decided I needed some kind of carat to dangle in front of myself to get that motivation going again. I decided a few weeks ago that I would get the body painted. I've been working with a local painter that I highly recommend. I pick up the pieces tonight, so expect the first proper update of this thread in nearly six months (pathetic, I know). Paint was certainly not the next logical step, but I think seeing the shiny bits will really motivate me to get back on track.
I should add photos either tonight or tomorrow, so stay tuned.
-Thich Nhat Hanh
1973 BMW R60/5:
Old 05-01-2012, 09:16 AM   #119
backdrifter OP
Wannabe rider
Oddometer: 1,364
Pics as promised. Lots of them. The painter was a St. Louis area BMW fan named Larry. I highly recommend him and would be happy to put anyone interested in touch with him - just PM me.
I love this photo, it shows just how glass-like the finish really is:
Headlight bucket mocked up with gauges expertly restored by Terry (Wirespokes). Looks ready to ride!
Headlight ears:
One thing that I thought was really cool was that Larry masked and saved all of the initials from the original painters. He also added his own initials, which I thought was a really nice touch. Interestingly, all three pinstriped parts of my bike (front fender, rear fender, tank) were painted by different painters. Very interesting!
The original initials on top, Larry's mark on the bottom:
A closer look:
I'm taking all the necessary parts to be re-chromed soon. Once I get the tank plates back all shiny and new, Larry will airbrush the black "wings" in them and then reinstall them for me (so I don't scratch the wonderful new paint).
Now it's onto mechanical stuff. Next I need to change the timing chain, the main seal, and see what else I'm looking at.
Little by little....
-Thich Nhat Hanh
1973 BMW R60/5:
backdrifter screwed with this post 05-01-2012 at 09:26 AM
Old 05-01-2012, 09:45 AM   #120
azcycle
Chihuahua Wrangler
azcycle's Avatar
Oddometer: 704
Gorgeous!
1981 BMW r65 - Photos
azcycle is offline   Reply With Quote
Times are GMT -7.   It's 06:28 AM.
