Old 11-29-2004, 01:47 PM   #1
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,234
Replacement/Upgrade horn on the KTM LC4 Adv
Oi!
I am going to ask Santa for a horn for christmas and curious about choices and what not. I know there are a few but these were the ones I focused upon.
They do offer the single horn which would be easier than trying to fit a double (it is a one horn bike I believe).
The big question is... wattage; specifically 72 of em. Is this not a problem for a short burst thing? Are the stockers similar?
Hella Twin Supertone Horn
Compact horn with outstanding sound. Rugged black body with red protective grille. Comes with bracket for screw-mounting. Kit includes horns, relay, mounting bracket, and installation instructions.
Voltage
12V
Frequency
300Hz low tone
500Hz high tone
Sound level
118 dB
Connection
Flat plug
Power consumption
Max 72W
Dimensions
4-27/32" dia. x 3-11/32" depth
http://www.hella.com/produktion/Hell..._Supertone.jsp
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 11-29-2004, 02:09 PM   #2
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,732
dont panic about wattage unless you ride around with them on all the time. you've got enough juice to honk those badboys for a couple good 30 second blasts per ride
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 11-29-2004, 02:11 PM   #3
meat popsicle OP
Ignostic
Oddometer: 14,234
Old 11-29-2004, 02:11 PM   #4
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
If you were behind me and pushed the button on those things... after I got back up, I'd shoot you repeatedly.
They are loud as hell.
So... how's tricks?
creeper is offline   Reply With Quote
Old 11-29-2004, 02:12 PM   #5
meat popsicle OP
Ignostic
Oddometer: 14,234
ok, seriously, maybe just one of em. since its a one horn bike and would need wiring/fuse work to use two. that be ok fer ya old man?
Old 11-29-2004, 02:17 PM   #6
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Originally Posted by meat popsicle
ok, seriously, maybe just one of em. since its a one horn bike and would need wiring, fuse work to use two. that be ok fer ya old man?
Hell no! get 2, or even 3 of the things. Great for waking up overworked soccer moms drifting into your personal space.
Say it loud... yer' Meat and yer' proud!
So... how's tricks?
Old 11-29-2004, 02:57 PM   #7
meat popsicle OP
Ignostic
Oddometer: 14,234
I'm Meat!
Now off to hunt for wiring upgrade and fuse info... two upgrade horns will likely fry the stock wiring or just trip the fuse when I reset the pacemakers on those oblivious seniors in their Buick Landyachts.
I thought I saw something by bentspoke regarding wiring upgrades with more power requirements on the HID thread.
Old 11-29-2004, 03:25 PM   #8
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
I'm Meat!
Na... you just use a relay to step down the amp draw to the switch. Easy as pie... should come in a horn kit.
So... how's tricks?
Old 11-29-2004, 04:15 PM   #9
meat popsicle OP
Ignostic
Oddometer: 14,234
Ah, see that in the kit. Excellent...
And a lil tidbit for the kiddies out there who didn't know (like me):
"Stock horns typically have an output of 97 dB. The decibel scale is logarithmic and therefore the sound pressure doubles for every increase of 3 points, i.e. a horn with 118 dB is approximately seven times as loud as a stock horn."
http://www.rallylights.com/hella/horns.asp
Old 11-29-2004, 04:24 PM   #10
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
As in "loud as hell"...
So... how's tricks?
Old 11-29-2004, 05:57 PM   #11
BlitzBike
LC4 Pilot
BlitzBike's Avatar
Oddometer: 800
Me so HORNY!
I briefly had a 139Db Striebel Air horn on my bike (adventures work shop). Great horn but, it was way too bulky and the only space I could find to mount it was back on the luggage rack so I'd wake myself up with each horn blast. Unfortunately, being exposed on the luggage rack, it gobbled up a whole lotta sand when I did my infamous Power-endo ground loop and has not been the same since. Now it emits a pitiful 2Db (yes two!) Db whispering whirring noise when activated and now sits in the "its no good" bin . I was contemplating Fiamms until I saw your post.
BlitzBike
BlitzBike is offline   Reply With Quote
Old 11-29-2004, 10:20 PM   #12
meat popsicle OP
Ignostic
Oddometer: 14,234
Originally Posted by Swampy
I briefly had a 139Db Striebel Air horn on my bike (adventures work shop)... I was contemplating Fiamms until I saw your post.
Hmmmm, 3dB ~ double the air pressure so 97dB stock to 118dB for the Hellas is 7 times louder... therefore, 139dB Striebel is 14 times louder than stock.
HOLY BLEEDING EARS BATMAN!!!
Um, the Fiamms might be groovy, the Hellas have a name I know - there is also another one... Check out this site: the wife apparently is musical and gives a critique of the horn:
The Supertones:
http://www.rallylights.com/hella/supertone_horn.asp
Note that the ones from India are "dissonant" so in this case you get what you pay for!
Old 11-29-2004, 11:03 PM   #13
Darin
WYSIWYG (WIZ-zee-wig)
Darin's Avatar
Oddometer: 594
I mounted a set of Fiamm horns (130db), one on each side of the headlight assembly. Just tapped into the old horn wires and presto instant ear bleeding, dual horns. I love seeing illresponsible drivers knee jerk the wheel back into their lane causing them to almost oversteer and spin out of control. No more nappy time for them.. I purchased the dual horns from JC Whitney in Dec02 for $30.00. No problems noted so far.
Darin
GUN OWNERS OF AMERICA
We do not compromise. You shouldn’t either.
If guns kill people, then…
- pencils miss spel words
- cars make people drive drunk.
- Spoons made Rosie O’Donnell fat.
I'm a firm believer of the 2nd Amendment
http://ktmdarin.smugmug.com
Darin is offline   Reply With Quote
Old 11-30-2004, 03:40 AM   #14
overlandr
Dystopist
Oddometer: 5,883
Think that site's physics is awry as found several references to figures that support the following table. A 20db increase would only increase perceived loudness by 4 times. :
dB Change Voltage Power Loudness
3 1.4X 2X 1.23X
6 2.0 4.0 1.52
10 3.16 10 2
20 10 100 4
40 100 10,000 16
overlandr is offline   Reply With Quote
Old 11-30-2004, 06:17 AM   #15
meat popsicle OP
Ignostic
Oddometer: 14,234
thanks overlandr,
that's right, the log scale should never be linear! so it is less difference at low dB changes and ALOT of difference at high ones. therefore, the hellas are only 4x louder than stock (still purdy loud as heck) and the Striebels are actually over 16x louder than stock.
3 1.4X 2X 1.23X
6 2.0 4.0 1.52
10 3.16 10 2
20 10 100 4
40 100 10,000 16
Times are GMT -7.   It's 12:52 PM.
