Go Back   ADVrider > Riding > Regional Forums > New Zealand
Old 11-10-2013, 12:29 AM   #1531
Padmei OP
enamoured
Oddometer: 3,761
Originally Posted by NordieBoy View Post
Drinking from eels is a bit too Bear Grylls'ish isn't it?
Not at all. if you grab them, blow deep into their mouths then quickly dunk them into the water they fill up real quick. They are slippery suckers to carry over to the tent like that tho.
Padmei is offline   Reply With Quote
Old 11-10-2013, 08:04 PM   #1532
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,724
That's a nice party trick. I'll be sure to bring you a live eel, just to see it done by the experts. Finding a comma might be easier than holding on to a slippery eel, not to mention kissing one.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 11-11-2013, 12:04 AM   #1533
msmckeon
Just ahead of the sweeps
msmckeon's Avatar
Oddometer: 92
Originally Posted by Kokopelli View Post
Finding a comma might be easier than holding on to a slippery eel.
msmckeon is offline   Reply With Quote
Old 11-11-2013, 12:39 AM   #1534
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
A 1954 Comma would be a good start.
Sleeps 4 no problems when sorted...
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 11-11-2013, 10:14 AM   #1535
Mark_S
Fair Weather Faggot
Mark_S's Avatar
Oddometer: 2,056
Such variety
last year it was blowing seals
this year its blowing eels
whats next year?
chunks?
These are the best days
Mark_S is offline   Reply With Quote
Old 11-11-2013, 09:34 PM   #1536
Padmei OP
enamoured
Oddometer: 3,761
Originally Posted by Mark_S View Post
Such variety
whats next year?
chunks?
well today I had hot feet so blew into my shoes but I guess shoes doesn't rhyme...
Old 11-11-2013, 11:24 PM   #1537
msmckeon
msmckeon's Avatar
Oddometer: 92
What is going on in Nelson? Obviously North Island help with both punctuation and spelling is required. I sense the need for a Molesworth/Rainbow trip.
Michael
Old 11-14-2013, 07:26 PM   #1538
Padmei OP
enamoured
Oddometer: 3,761
Oh come on are you guys really going to leave me hanging? Shoes - something about them that rhymes with eels & seals????
Old 11-14-2013, 07:37 PM   #1539
Padmei OP
enamoured
Oddometer: 3,761
Gave Schmidt some love last nite - a wash, fresh oil, cleaned air filter & a ride around the block.
I also took it out today & realised the lurching & noise is only happening in 1st gear. Feels/ sounds like it is slipping in & out of 1st gear when ridden along.
I have posted in the GSers gearbox thread to see if there are any easy fixes. If not I may do a box transplant tomm morn.
Old 11-16-2013, 12:52 AM   #1540
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,393
Keep those ribs safe Padmei...just in case you are following trends again.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 11-16-2013, 03:32 PM   #1541
Padmei OP
enamoured
Oddometer: 3,761
Gearboxes & broken ribs do seem to go together
Old 11-16-2013, 06:45 PM   #1542
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,724
Yep, you have a suspicion that something is wrong, but you don't know how bad it is.
R1150GS
R80GS Basic
Old 11-16-2013, 11:18 PM   #1543
Padmei OP
enamoured
Oddometer: 3,761
OK. Quandering time (like that? I just made it up)...
I posted a query on the GSers gearboxes thread to any idea what could be the cause of the lurching/ jumping from the gearbox in 1st gear. Here's some of the answers
Before you do much else drain the oil from the box and see what you get out maybe its nipped a tooth off
Drive shaft shock absorber slipping? Broken spring on same?
As 'Packer' says, it could be the shock absorber cams if the spring is broken:
There are two different designs, depending on whether you have a 6-spline or a 12-spline input shaft.
Alternatively its possible that the output shaft drive flange is slipping on its taper under high torque loadings - as in 1st gear.
The output flange nut is torqued to 162 Lbs/Ft, I would be inclined to check that (if possible) with the box still attached. If its at the right torque then I'm afraid its a box strip .
Bob.
Took the driveshaft etc off today & checked whether the output flange of the gearbox was loose. I put as much pressure as I could on the bar but it wasn't budging anymore so I'd say the output flange is pretty tight & not spinning under high torque situations.
I dropped the oil out of the box & had a look. It was pretty filthy & there was swarf on the plug.
I stopped there to think about what i'm going to do. Since half the gear is off I could throw on Berlinas box & ride that while taking the recon one apart again to see what the fault is....or just button it back up together, put my head in the sand & see if the problem goes away. i wonder what would be the worst case scenario if I just ride the fricking thing - blow the gearbox up? Maybe that could be the best thing for it.
Hmmm. I'll do some more research on what could be the problem - seems really strange how i couldn't get it to jump out of gear again.
Old 11-17-2013, 07:57 PM   #1544
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,393
"We're only here for a while and we are sum of our experiences ... So, it all tends to blur together if you don't punctuate it with adventure."
Old 11-17-2013, 10:58 PM   #1545
Oaters
Oaters's Avatar
Oddometer: 697
Excellent vid Steve! Hope you're doing okay after Takapari Road
Oaters is offline   Reply With Quote
Times are GMT -7.   It's 10:54 AM.
