Thread Tools Search this Thread Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 10-04-2013, 11:13 AM   #46
mcnut
Oddometer: 1,365
When building map sets of regions be sure to somewhat overlap the coverage otherwise if traveling near the boundary you will be constantly switching cards.
Bruce
mcnut is offline   Reply With Quote
Old 10-04-2013, 11:20 AM   #47
PHILinFRANCE
PHILinFRANCE's Avatar
Oddometer: 1,127
The simple things are always the best , storing the cards between the batteries , great idea
I,M HERE FOR A GOOD TIME NOT ALONG TIME
PHILinFRANCE is offline   Reply With Quote
Old 10-05-2013, 02:26 AM   #48
PHILinFRANCE
Oddometer: 1,127
Sorted !!!! took our of fucking about !!!
Thing is Garmin say something like 2500 maps !!! no way !!!
Started with 254 maps , nearly all of city nav !!!! after 4hrs down loading "ERROR unsuccessful"
Down to 196 maps same thing
Down to 154 maps and wooohooo success
Must add these are on a 2GB cards , but nowhere does it tell you how much info is on each tile so no way of knowing how many tiles you can put on !!!!
All trial and error but got there in the end
All that said just put the whole of Morocco on a 2GB in 5mins
Thanks again to all that helped
Phil
Old 10-05-2013, 09:55 AM   #49
NorthernTraveler
Long time Adventurer
NorthernTraveler's Avatar
Oddometer: 435
Map size
In Mapsource at the bottom of the 'Maps' tab it tells you how many map segments you have selected, and the total size of the map segments selected.
With up-to-date firmware a 60/76 can have up to 2025 map segments and a combined map file up to 4gb.
You can even name the map set load at the bottom of the map tab. Make it something descriptive because when you turn the GPS on and it loads the map set it gives you the name of the map set on the startup screen.
NorthernTraveler is offline   Reply With Quote
Old 10-06-2013, 01:04 AM   #50
PHILinFRANCE
Oddometer: 1,127
Cheers mate but my 60 is an old girl but happy with what i've managed to sort
Phil
Old 10-14-2013, 10:16 AM   #51
5hortbus
Oddometer: 114
Buy a 60csx?
Seeing as you are all fans. I have an opportunity to buy a 60csx for $150.
It seems like it is the original ADV GPS standard.
It's going to be my first real GPS. Does it make sense to go wither this tried and true performer, or look at newer "cooler" options.
I'll really just use it to keep myself from becoming hopelessly lost riding in new areas. And for following tracks of guys who have "been there and done that" in cool places.
What are your thoughts? Sorry for minor hijack. I'll get a HUGE card for it. (For the sake of keepin with the thread)
Chicagoland Dual-Sport Riders
5hortbus is offline   Reply With Quote
Old 10-14-2013, 10:18 AM   #52
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,521
If you do buy it, don't bother getting anything larger than an 8 gig card.
Old 10-14-2013, 10:33 AM   #53
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,433
Go for it. I bought my 76Cx for $150 new off ebay. They're still great receivers (and better than the newer stuff IMO).
+1. 8GB is MORE than enough for anything you'll throw on it, and the GPS may not work with higher-capacity cards.
Spewer of the poignant non sequitur
SnowMule is online now   Reply With Quote
Old 10-15-2013, 09:36 PM   #54
5hortbus
Oddometer: 114
Thanks folks! Got the new GPS in hand. I have NO idea what to do with it, other than buy a new SD card.
Gonna start reading and searching to figure out what maps to get, how to get them, etc.
Thanks for the advice.
Old 10-15-2013, 11:07 PM   #55
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,433
This might come in handy:
http://advrider.com/forums/showthread.php?t=907105
Old 05-18-2014, 12:40 PM   #56
Paulie
Paulie's Avatar
Oddometer: 308
76cx problem fixed with microsd
My 76cx suddenly started doing this weird thing. Power on, looks normal for a few seconds, screen fades out, byebye. Did a master reset, changed power source, you name it, same ole shit. WTF? Thot I hadta spend a bunch of time on the fone with Garmin support. Ah geez.
But before I called em, I took the 2gb microsd card out, put it on the puter & ran a format on it. Success!
Paulie is offline   Reply With Quote
Old 05-18-2014, 06:20 PM   #57
Countdown
Oddometer: 5,324
Hard to believe that data on card would power it down. I would toss the $7 card, sounds more like a short in the card that is somehow address sensitive.
Jerry Counts
Countdown is offline   Reply With Quote
Old 05-18-2014, 08:44 PM   #58
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,433
Happened to me before. I can usually get away with a file system check on the computer, and a master reset on the device though.
Times are GMT -7.   It's 01:39 PM.
