Old 08-17-2010, 10:18 PM   #1
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,847
Replica 950 Rallye Tanks
OK Ive been wanting to increase the range of the 950 for a while now and it seemed the only way to go was the tanker replacement fuel tanks from safari - that 40+ litres is sure tempting but the tank movement has me a little concerned not to mention some reports of cracking windscreens. Other than that there are those from a couple of South African companies but after hearing and seeing their fit and finish ive decided on rallye aux tanks.
Now seeing as KTM didnt offer a version for sale to the public or the tanks as a part I decided to make my own. Thanks to barbasma for the detailed photos of Meonis R950 - a lot of very interesting detail to be seen if your looking.
http://picasaweb.google.com/KTMPETE/950RallyeTanks#
So where are we - the GPR has replaced the stock headers/X pipe and cans saving 7 kg. Next was the seat base and tail light/fender unit (2.4kg) leaving the subframe - which is obviously different to the rally's. The link to picasa shows where Im up to atm. Next step is fairing and finishing before moulding - so other than the great ideas Ive already been given by a few inmates here does anyone have any other ideas or bits that ive forgotten to "build into" them???
Ive done the infills (today) inboard of the frame and cutouts for the chain guars/swingarm/brake calliper/etc. Other than that Im thinking of the fillers and petcocks.
Pete
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 screwed with this post 08-17-2010 at 10:30 PM
Pete640 is offline   Reply With Quote
Old 08-18-2010, 02:08 AM   #2
seiko690
seiko690's Avatar
Oddometer: 60
Try here:
https://ssl.kundenserver.de/s7427041...dex.shopscript
How to clean an Adv.... http://www.youtube.com/watch?v=nUCY2cVCoxg
seiko690 is offline   Reply With Quote
Old 08-18-2010, 02:10 AM   #3
seiko690
seiko690's Avatar
Oddometer: 60
Search their product range, they've got some rally tanks that look just like Meonis...
Old 08-18-2010, 03:49 AM   #4
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,109
Gidday Pete. Are you just making the side tanks or are you also doing the rear fender as well ?
Looks great, any pics of them after the cut outs ?
Edit: doh I either missed them or you just added them.
Is the total width of the rear tanks narrower then the front tank?
Exciting project :)
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 screwed with this post 11-08-2014 at 04:46 PM
Deadly99 is offline   Reply With Quote
Old 08-18-2010, 03:59 AM   #5
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,847
Hi Deadly
Yep a couple of extra pics of the recessing to clear the swingarm/chain guide and disc caliper. The rhs tank looks off - but that was because of the midpipe bracket pushing it out.
...and there is a pic looking straight down showing the rh tank infill next to the shock.
...and yep - the rear tanks are much narrower than the front @450mm wide - or 18" depending where you live. Also making the seat base incorporating the rear fender and twin tail lights.
Pete
Pete
Pete640 screwed with this post 08-18-2010 at 04:11 AM
Old 08-18-2010, 06:21 AM   #6
Vassily28
TheFrenchCanadian
Oddometer: 320
Exemple
http://www.advrider.com/forums/showthread.php?t=486901
Vassily28 is offline   Reply With Quote
Old 08-18-2010, 08:06 AM   #7
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,109
I like the fact that your going to replicate the 950 rally tanks Look forwad to seeing the end product look like .......
Roaming Rally 2015
Deadly99 screwed with this post 08-18-2010 at 10:53 AM
Old 08-18-2010, 01:18 PM   #8
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Greetings,
Why is the Adv. Rallye tank setup so hard to come by? There seems to be plenty of interest, so why hasn't someone stepped up and offered a complete, bolt-on kit?
Or have they, and I've just missed it?
ktm950se
ktm950se is offline   Reply With Quote
Old 08-18-2010, 02:59 PM   #9
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,030
$$$ , everyone wants stuff cheap and are not prepared to pay
Originally Posted by ktm950se
Greetings,
ktm950se
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 08-18-2010, 05:56 PM   #10
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,847
I'll remember you said that atgreg
Having looked at some of the others made (I like the canadian one the best) none were able to be easily reproduced but frp allows you certain freedom in this regard. Ally with the welding and bending is more time consuming I guess but some products are truly brilliant.
Pete
Pete
Old 08-19-2010, 03:38 PM   #11
LukasM
Oddometer: 5,426
Hi Pete,
How would you go about mass producing a piece like this, do you lay up two halves in separate molds and then join them together somehow? Is there any issue of delamination if you fit the ground sometimes?
I have only seen the big tanks done with rotomolding plastic, or if using FRP the lost foam method which is obviously too time consuming for mass production.
Old 08-19-2010, 06:37 PM   #12
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,847
Yep - 2 halfs joined. Wont be a problem with delamination given the joining method and products used.
Not sure mass production is required atm - but if so Id investigate rotomoulding but that is a looooonnngggg way down the track. Yes I will mould it for manufacturing integrity and replacement but its just a custom part for me atm.
Pete
Pete
Old 08-22-2010, 05:00 PM   #13
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,109
Roaming Rally 2015
Old 08-22-2010, 09:19 PM   #14
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,071
wow. Go for it!
viola-tor is offline   Reply With Quote
Old 08-23-2010, 12:29 AM   #15
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,847
Pete
Pete
Times are GMT -7.   It's 07:41 PM.
